Showing results for tags 'high iso'.
Hi. I can't find exactly this problem reported here, so apologies if it's here somewhere. During the lockdown I've been trying different kinds of home-based photography. Yesterday I was playing around with high-speed shots, dropping ice and strawberries into coloured water, that kind of thing. I've just opened the images in LR and in PS and found there is a small line across the images when shooting at ISO higher than 640. Is it some kind of banding? I don't know the ISO level where it starts to appear, I would have to do more tests to determine the tipping point. However, it's not there at 640 and is there at 1600 and above. See three attached images. Same lens and body, ISOs 640, 3200 and 4000. Shutter speed 1/4000 on all three. Apertures from f4 to f6.8. Of course I am assuming it is to do with the ISO, not the f-stop. I was shooting on high speed shutter, so maybe something to do with the heat generated or recycling time? Lens is APO-Summicron-M f2. 90mm. Camera body Leica M10. No flash. Remote cable release for high-speed shutter. Any thoughts appreciated.
I am slowly managing to get out more now, ands back in my usual coffee shop yesterday. I couldn't resist taking a candid image of this young lady at the counter because of her height. She must have been about 1.8 metres. Leica M240 + 35mm Summarit f2.5 @ 1250 iso. 1/250 @ f2.8 and post-processed in Lightroom Classic. Gerry
- 2
- high iso
- leica m240
- (and 6 more)
I obtained a customer-release—not pre-release/beta—M10-R and compared it side-by-side with the M10 Monochrom (hereafter referred to as the M10-M) on a test scene at high ISO values. The firmware version for both was the latest firmware currently available to the public: 10.20.27.20 for the M10-R (upgraded from the initial released 10.20.23.49 firmware that was pre-installed in the new camera), and 2.12.8.0 for the M10-M. Methodology: all shots were taken on a tripod with a 2-second delay to minimize vibration. The same Leica 50 APO lens was used for all tests. The aperture was set to f/5.6 for all tests, at which the resolving power of the 50 APO is about as high as possible among commercially available 35-mm format lenses. The ISO value and shutter speeds were as follows: ISO 6400, 1/60 s ISO 12500, 1/125 s ISO 25000, 1/250 s ISO 50000, 1/500 s ISO 100000 (M10-M only), 1/1000 s To the best of my ability, the M10-R and the M10-M were treated equally. The test shots were taken in one sitting, with the same tripod position 2.2 m from the target, and under the same lighting. The images were focused by rangefinder and confirmed by live view for each camera. The subject distance (2.2 m) was farther from the test scene than my earlier M10-R tests (1.3 m) because I anticipated that the M10-M might have no trouble resolving all the details of the scene from 1.3 m, even at absurdly high ISOs. To keep the test as pure as possible, all the test shots were taken as DNG files, then transferred and opened in Adobe Photoshop 2020 with Camera Raw 12.3 (which has native M10-R support) with no corrections or adjustments to the default image settings, other than clicking “B&W” to convert the M10-R images to monochrome. Therefore, this test does not really answer the question of how the performance between the cameras compares if one were to bring the full power of modern post-processing, noise removal, AI-driven scaling and sharpening, etc. to bear on the images. It also does not exploit the important ability of adjusting the levels of different colors when converting color files to monochrome files—arguably the largest advantage of using the M10-R to generate monochrome photos instead of the M10-M. Instead, the purpose of this test is to compare the acuity and noise level of the two cameras at ISO 6400 to ISO 50000. Overall, both cameras take remarkably good monochrome photos, even at ISO levels such as 12500 that would previously be considered out-of-reach. Here are 100% crops from a small portion of the center region of both cameras (M10-R on the left, M10-M on the right). Click on the image below to view it at 100% to avoid scaling artifacts. I would have no hesitation using ISO 12500 monochrome images from either camera for virtually any application. But of course there are substantial performance differences. Finding #1: The M10-M captures higher acuity levels than the M10-R across the ISO range tested (6400 to 50000). As expected, given the lack of a Bayer color filter array (CFA) and no need to de-mosaic the red-, green-, or blue-filtered pixels, the M10-M offers significantly higher acuity than the M10-R. To my eye, the advantage persists even if you give the M10-R an advantage of one or two stops: compare the sharpness of the fine features of the scene as captured by the M10-M at ISO 25000 vs. the M10-R at ISO 6400, or the M10-R at ISO 25000 to the M10-M at ISO 100000—a remarkable testament to the M10-M’s ability to capture a scene down to the smallest details, even zooming in to 100%. Notice also that at the same ISO level, aperture, and shutter speed (chosen by each camera’s auto-shutter speed setting to be the same at all ISO levels!), the M10-M images are only modestly brighter than the M10-R; I was surprised that the Bayer CFA didn’t dim the M10-R images more strongly. Perhaps the M10-R firmware partially compensates for the loss of light due to the Bayer CFA. Finding #2: The M10-M offers about a 1- to 2-stop advantage in high-ISO noise levels over the M10-R. Compare the M10-M at ISO 50000 to the M10-R at ISO 12500, or the M10-M at ISO 25000 to the M10-R at ISO 6400. The M10-M continues to blow me away with its high-ISO performance. Indeed, Bill Claff’s measurements at https://photonstophotos.net/Charts/PDR.htm rank the M10-M’s high ISO performance as fourth among all cameras tested to date, behind the Phase One IQ4, the Phase One IQ3, and the Fuji GFX-100—three current or recent top-of-the-line medium format cameras. Overall, Leica has created in the M10-M and the M10-R two current-generation sister cameras with outstanding overall performance. If acuity or high-ISO performance is more important than color for your particular application, than the M10-M outperforms the M10-R and is among the very best cameras to my knowledge, even joining some medium-format monsters. And if color is needed, either in the final image or to enable creative conversion to black and white images that allows easy sky darkening, face lightening, etc. during post-processing, the M10-R remains an option worthy of its current flagship status among Leica M cameras.
Dear all, I had the opportunity to handle the CL for a few minutes this week. I have been considering for some time now either : . to add a SL to my M(240) . replace my M(240) with a M10 in order to gain better high ISO IQ and easier use for my 2 favorite lenses (right) now, ie Noctilux 50 and Summilux 75 (I use the a lot to shoot pictures of my 6 week old daughter) I like the way the CL handles, and wonder if another solution would not be to buy one for use with those lenses : I don't mind the crop factor for this, compact size is nice to take it with the M, and the EVF looks pretty good (although in my view nothing beats the M OVF as a window to the world and frame as I want - but to focus difficult lenses, EVF seems nice...). Has anyone tried the Noct / CL combo, or at least the manual focus capabilities ? Thanks for sharing your experience and thoughts Didier
Dear all, how does the CL (JPEG / RAW) compare to M(240), to M10 and to SL regarding high-iso picture quality ? has anyone pictures ? thanks Didier
Last night I took a trip into the centre of the city to look at the temporary ice rink but also took the opportunity to photograph the latest city centre leisure complex consisting of 10 cinema screens and countless restaurants. The ice rink is visible as the blue area bottom left, but not the purpose of this image. I must be honest, it is probably a young persons place, and I am not a young person, but I was quite pleased with my efforts. Here is a sample image taken at 2500iso using the Leica M240 and 24mm Elmarit-M f2.8. Settings were 1/45 at f2.8 (no tripod). If you want a larger image go to https://gerrywalden.smugmug.com/TRAVEL-IMAGES/England-The-English/i-T2CLZVL/A Gerry
- 10 replies
- 8
- night
- Leica M240
(and 7 more)
Tagged with:
A young lady sits in contemplation at my favourite coffee shop. Leica M240 - 1/125th at f5.6 handheld @ 2,000 iso processed in LR Classic. Gerry
Dear all, I am the happy owner of a M(240), and more recently a CL and SL. I am coming from over 15 years of film M. I like shooting the rangefinder camera though I find a huge difference between my almost 5 year old M and the most recent (for me: I got the CL last january and the SL in October) cameras in image quality as soon as I shoot over iso 1600. I almost never shoot the M in color over iso 1600 since I don’t like what I can get out of lightroom @iso 2500 or more in color. i also have trouble with color consistency in mixed (daylight + artificial) lighting with the M. on both issues I find the SL is far superior and even the CL. Do you share the same experience ? do you think the M10 is much better in those areas ? thanks for sharing your experience didier
- 11 replies
- m(240)
- color fidelity
(and 3 more)
Tagged with:
I took my regular visit to my favourite city-centre coffee shop and when he served me the guy behind the counter said "Have you taken any good snaps yet today?". I hadn't, but whilst I sat there with my coffee and Danish this scenario appeared in front of me. It is a candid image, and they did not notice me at any time. I used my M240 fitted with the 50mm Zeiss Sonnar f1.5 and I was working at 1,000iso. Exposure was 1/60th @ f6.8. post-processing was in Lightroom Classic. Hope you like it! Gerry
I know that nearly everyone on this forum is more knowledgeable about Leica cameras than myself. I have a Q2 on order. Several reviewers have reported high ISO/low light issues with the new sensor. Do people think that these problems can be be rectified, or at least improved, in a future firmware update? Or is the camera stuck with them? Or do the issues not really exist?
While I was having coffee at my favourite place this guy was sat running his office over his cup of coffee. "Hi, it's Mike the Magician" he said down the telephone. Sadly the guy at the other end didn't seem to know who he was. I took this candid shot of him with the M240 + 50mm lens at 1600iso. I then processed it through Lightroom Classic. Hope you like it! Gerry
I have just acquired a 50mm Summicron-M f2 IV so I took it for a test run (which consisted of one shot) today. This was at 1250 iso 1/125 and f6.8 - Gerry
- 2 replies
- 3
- 50mm summicron-m f2
- leica m240
(and 4 more)
Tagged with:
Taken whilst having my morning coffee in my favourite coffee house in my home town of Southampton, England.
- 7 replies
- 11
- people
- street photography
(and 4 more)
Tagged with:
Taken at a BBQ held by a bespoke motorcycle dealership this morning. Leica M240 + 35mm Summarit f2.5. 1/100th &f5.6 @3200 iso (yes, guess who forgot to reset the iso when he came out of the workshops!) Gerry
Hallo zusammen, ich hatte vor eineinhalb Wochen das Vergnügen, im Leica Store mit der Q3 herumzuspielen und mit dem Mitarbeiter ein wenig zu quatschen (um auszuloten, ob sich für mich ein Upgrade von der Q2 lohnt 😉). Er teilte mir unter anderem mit, dass bei geringeren Auflösungseinstellungen (36,5 oder 18,6 MP) jeweils eine gewisse Zahl Pixel des Sensors für die Aufnahme zusammengefasst werden. Daraufhin kam mir die Idee, dass sich dadurch ja eventuell die High-ISO-Performance bei den Auflösungen 36,5 oder 18,6 verbessern könnte (ist vielleicht naiv von mir). Der Mitarbeiter verneinte, sagte aber, dass, wenn man geringere Auflösungen einstellt (36,5 oder 18,6 MP) , "sich der Dynamikumfang um bis zu ca. 1-2 Blenden verbessern" würde. Ist natürlich nur eine vage Aussage (was auch an meiner vagen Erinnerungsleistung liegt, die mir meine Frau regelmäßig vorhält), aber um der Sache auf den Grund zu gehen...hier meine Frage: Hat mal einer der Early-Q3-Users getestet, ob durch die Einstellung 36,5 oder 18,6 MP (statt 60 MP) der Dynamikumfang oder generell die Low-Light-Fähigkeiten der Q3 besser werden? Vielen Dank für Eure Antworten/Einschätzungen. P.S.: Übrigens kann ich bestätigen, was jmschuh hier schon geschrieben hat: Das Klappdisplay, welchem ich ziemlich kritisch gegenüberstand, macht einen wirklich soliden Eindruck, welcher meine Bedenken weitestgehend zerstreut hat.
- 89 replies
- q3
- dynamikumfang
(and 8 more)
Tagged with:
