cannonballjoe Posted May 14, 2017 Share #1 Posted May 14, 2017 (edited) Advertisement (gone after registration) I currently have a 35mm Summicron v1 8-element lens that I absolutely adore because of the small size, ergonomics, and the character of the images it produces. However, I'm going to be going back to a film body from digital and have been thinking it would be nice to have an extra stop with a Summilux... but I'm not entirely sold. Part of me thinks that I can still get by with shooting the Summicron wide open with an ISO 1600 film (either rated or pushed), but another part of me thinks that I would need a Summilux, especially when traveling and shooting at night or with low light. If I were to go to the Lux, the version I've been thinking about was the Pre-Asph version (probably the later Titanium version built in Germany since people say it has better coating on it). How much of a change should I expect (in terms of character, image quality, etc.) between the Cron v1 that I have with a Pre-Asph Lux? Or will they both be about the same and I'm just paying for the extra stop (though the v1 8-element lens that I have is about the price of a later version/titanium Pre-Asph Lux, so it could just be a flat out trade...). Edited May 14, 2017 by cannonballjoe Quote Link to post Share on other sites More sharing options...
NB23 Posted May 14, 2017 Share #2 Posted May 14, 2017 The lux has an omnipresent macro-gamut in the lower values but lacks the cron's spectral textures in the lower apertures. Quote Link to post Share on other sites More sharing options...
rpittal Posted May 14, 2017 Share #3 Posted May 14, 2017 I also have the 35mm ver1 8 element summicron and love it to death, assuming I want Leica glow at f/2. Sharpens very nicely when closed down. I recently purchased a 35 summilux ASPH pre FLE which is very sharp at 1.4 (apparently not as "good" as the FLE at closer distances). It seems like you would save at least 2 or 3 stops of light with a newer Lux compared to the 8 element, not just one stop, if only comparing sharpness over the entire field. I feel they are very complementary lenses. Regards, Bob Quote Link to post Share on other sites More sharing options...
NB23 Posted May 14, 2017 Share #4 Posted May 14, 2017 (edited) Also, the nanolevel color separation is much better on the cron starting at about f4 while the summilux evens it at f8 Edited May 14, 2017 by NB23 mp58 1 Quote Link to post Share on other sites More sharing options...
michaelwj Posted May 14, 2017 Share #5 Posted May 14, 2017 I think you should look at it as trading a (pretty average) stop for 30cm of close focus. Which is more important to you? Wide open the pre-asph has "character", stopped down past f/2.8 it's not too different from what you have, it just doesn't focus as close. The macro-gamut and nanolevel colour separation are pretty similar in both I think. The pre-asph summilux has more pronounced globular enhancement which makes it far superior Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! TheBestSLIsALeicaflex and Universalb50 2 Quote Link to post Share on other sites More sharing options...
thompsonkirk Posted May 14, 2017 Share #6 Posted May 14, 2017 (edited) Globular enhancement aside, here's a note of caution about the 35mm pre-a Lux: I liked the lens' character/rendering, and its wide-open softness. But I finally gave it up because of its proneness to an unusual kind of flare. If there's a strong light source just outside the range of what you can see through your viewfinder, the lens sometimes produces a large new-moon shaped arc or swath of flare across the frame. And of course you can't see this through the RF in order to predict it – it sometimes just 'befalls' you. Particularly indoors and at night, you'll encounter just-out-of-view artificial light sources that provoke this behavior. So it's a toss-up: you might like the way the lens renders, but you'll from time to time lose what you thought would be a fine shot because of this unusual flaring. In some instances I was able to repair/clone the image in Photoshop, but it was hard to keep parts of the image from looking like a painting. I read that back-in-the-day when these were widely used as photojournalists' lenses, it was fairly commonplace to use a Summicron by day and then switch to a Lux as the sun went down. Perhaps a modern equivalent might be to keep the lens you have for general use, and then for your available-light photography acquire an inexpensive used hulking clumsy Voigtlander 35mm f1.2 that covers a chunk of the viewfinder. At large apertures the Nokton's rendering is similar enough to older/classic lenses for its images to blend into a mostly-Summicron portfolio. This was one of my solutions after missing a number of shots for the following series because of the Lux's flare: http://www.thompsonkirk.com/north-beach-changing (shot with 28 Cron, 35 Cron v4, 35 pre-A Lux, 35 1.2 Nokton, and 40 Cron.) Kirk Edited May 14, 2017 by thompsonkirk pico 1 Quote Link to post Share on other sites More sharing options...
NB23 Posted May 14, 2017 Share #7 Posted May 14, 2017 Advertisement (gone after registration) Fyi, peripheral globular enhancement Is present only in the asph version. Quote Link to post Share on other sites More sharing options...
michaelwj Posted May 14, 2017 Share #8 Posted May 14, 2017 The flare Kirk mentions is greatly reduced by using a different hood; http://www.rangefinderforum.com/forums/showthread.php?t=80916 http://www.rangefinderforum.com/forums/showthread.php?t=156103 Quote Link to post Share on other sites More sharing options...
Exodies Posted May 14, 2017 Share #9 Posted May 14, 2017 Is there an app to generate pataphysical lens descriptions or are these hand made? a5m, UliWer, rpittal and 3 others 4 2 Quote Link to post Share on other sites More sharing options...
michaelwj Posted May 14, 2017 Share #10 Posted May 14, 2017 Is there an app to generate pataphysical lens descriptions or are these hand made? We're old skool Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! You just have to think WWHSS! (What Would Homer Simpson Say) Quote Link to post Share on other sites More sharing options...
lct Posted May 14, 2017 Share #11 Posted May 14, 2017 Flare is indeed a problem with the 35/1.4 pre-asph, even with my late German version, and no hood can avoid that i'm afraid. BTW the 12526 square plastic hood referred to above doesn't vignette significantly on the 35/1.4 pre-asph but it rotates freely on the lens and it tends to get in the way when turning the aperture ring. What's unique in this lens is its "glow" (halos around highlights) at wide aperture but it is a soft lens at f/1.4 and my copy suffers a bit from focus shift which is not a problem in LV mode though. Now the lens is as sharp as Summicrons 35 from that era at f/2 and on and it is unrivaled amongst f/1.4 wides size-wise aside from the CV 35/1.4. The latter's SC version flares even more than the Summilux though and it shows no glow at all. michaelwj 1 Quote Link to post Share on other sites More sharing options...
NB23 Posted May 14, 2017 Share #12 Posted May 14, 2017 We're old skool Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! You just have to think WWHSS! (What Would Homer Simpson Say) So he's the one who came up with the macro/micro contrast BS? Quote Link to post Share on other sites More sharing options...
Stealth3kpl Posted May 14, 2017 Share #13 Posted May 14, 2017 I felt my 35 Summilux was a good copy but my 35 Summicron type IV was sharper at f2. I sold the Summilux. Pete Quote Link to post Share on other sites More sharing options...
pico Posted May 14, 2017 Share #14 Posted May 14, 2017 (edited) I am on my third 35mm Summilux, version 2. The previous two were damaged on the job. No publisher has rejected my wide-open images for technical reasons. . Edited May 14, 2017 by pico phototrope, friedeye and horosu 3 Quote Link to post Share on other sites More sharing options...
Michael Geschlecht Posted May 15, 2017 Share #15 Posted May 15, 2017 (edited) Hello Joe, Welcome to the Forum, After reading the above, it would more or less appear that the general opinion is: Both are good lenses. If you need the +1 stop of speed, then the Summilux is the choice. Otherwise they are both pretty much the same. Best Regards, Michael Edited May 15, 2017 by Michael Geschlecht Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 16, 2017 Share #16 Posted May 16, 2017 I have both Summicron V1 and Summilux preasph (btw, it's even older than the Summicron...) : have used them for lot of years (> 25...) and my mindset is simple : - Use Summilux only in "safe" light-source situations. (*) - At similar f stops, they have a very similar rendering. (*) provided that, it's really usable at 1,4, and no critical to focus. mp58 and lct 2 Quote Link to post Share on other sites More sharing options...
Guest )-( Posted May 17, 2017 Share #17 Posted May 17, 2017 Is the Summicron v1 less flare prone, or much the same? Quote Link to post Share on other sites More sharing options...
iaeaix Posted May 18, 2017 Share #18 Posted May 18, 2017 Is the Summicron v1 less flare prone, or much the same? Later batch of Summicron would be better in that regards for sure. Those early batch of Summicron is as much flare prone as Summilux if not more Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
Guest )-( Posted May 19, 2017 Share #19 Posted May 19, 2017 Thanks, I guess the lens coatings might account to some extent for the flare, although my 35mm Summilux 'v2' pre ASPH is from 1990 and still flares much as they all seem to? And the front element in the Summicron is maybe a tiny bit more recessed than the Summilux? The Summicron maybe is only single coated, the later Summiluxes - I don't know? The two lenses seem to often be described as "the same except the added stop", but looking at the design cross-sections, they appear completely different lens designs and I think they use different types of glass? One is 7 elements in 5 groups, the other is 8 elements in 6 groups in a symmetrical design. Courtesy of Ken Rockwell: http://www.kenrockwell.com/leica/images/35mm-f14/diagram.jpg http://www.kenrockwell.com/leica/images/35mm-f2-m3/diagram-0600.gif The 35 Summilux v2 is also often described as the same as the 35mm Summicron Type 4, except the v4 has been 'crippled' by the aperture not opening completely - the barrels certainly appear pretty much the same and the not-completely-opening aperture makes sense The v4 also has 7 elements in 5 groups, I can't find a cross-section. These are all subtle differences that make zero difference in making a good photograph, but since the topic is on, it'd be great to see some examples/delve a bit deeper - the 'they are very similar' line seems a bit like a lazy answer to me, especially where the 1st type Summicron is concerned. Quote Link to post Share on other sites More sharing options...
iaeaix Posted July 6, 2017 Share #20 Posted July 6, 2017 There are difference in terms of coating, between earlier and later V1 Summicron. You can easily tell the difference when put them side by side by seeing the color of the coating. By seeing the photos it seems that the later version has higher contrast. Wether it has higher resistance to flare than earlier ones, I never did comparison. The Summilux v2 might be more due to the larger front element, in terms of flare prone? I have not used it enough although I have one. Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
