The Leica M11 images thread
Al Brown
Bird on a wire.
35mm F8 iso 64
Tom Robinson Band
35mm f1.4 iso 500
Pretty happy with the way this came considering the lighting and the cider content.
Macca
35mm f6.8 iso 800
Not sure what lens you need to catch 200k people whooping with joy - but this isn't it.  Good memory for me all the same.
Pet Shop Boys
35mm f5.6 iso 1600
Just a fantastic set - superb!
M11 & 35 apo
  • Like 18
M11 with Summilux-M 75 mm
  • Like 13
3 minutes ago, hdmesa said:
S3 and M10-R share the same sensor tech. The M11 is more like the GFX 100S, IMO.
While they likely share the basic technology, the sensor toppings and the firmware are likely completely different
Big change between these generations of sensors that transcends that, namely FSI (M10-R/S3) to BSI and a redesigned IR/UV topping (M11). M11 and S3 don't share anything other than the Leica name and the same oversight to the pipeline. If anyone is seeing a similarity between the S3 and M11, it's because the S lenses render a lot like M lenses do.
M11 and GFX 100S are nearly impossible to tell apart at base ISO when the GFX is used in 35mm crop mode with GF lens and an M APO is used on the M11.
I will say the colours coming out of the M11 and applying slight edits are just *chefs kiss*
A test shot: M11 + VM Nokton 50mm f1.0 wide open (heavily cropped)
Edited by normie610
A night shot
M11 + Distagon 35mm 1.4 wide open
I agree- however the Fuji with Fuji glass is delivering far less (if any) chromatic aberration in high contrast areas....something I hope Leica address in future firmware upgrades....
