dkmoore Posted January 22, 2017 Share #21 Posted January 22, 2017 Advertisement (gone after registration) Just to clarify, it is not the ear behind the rings that would cause the issue. Some straps have thick connections where the ring is attached. It is that part of the strap that will wear the paint off the side of the camera. 1 Quote Link to post Share on other sites More sharing options...
Advertisement Posted January 22, 2017 Posted January 22, 2017 Hi dkmoore, Take a look here Which strap for the M10? {merged}. I'm sure you'll find what you were looking for!
Guest Posted January 22, 2017 Share #22 Posted January 22, 2017 any recommendations for the proper strap for the M10? Eddycam Elk I have the thinnish one on the SL. Lovely strap, comfortable and has nothing near the connection points to scratch the camera with. Quote Link to post Share on other sites More sharing options...
6bit Posted February 1, 2017 Share #23 Posted February 1, 2017 Anyone using a cross body strap that or may not connect to the tripod mount? Would love to hear what you are using and the length. I have thought about the Monarch BOA JCh strap but I generally use crossbody strap if I use a strap at all. Quote Link to post Share on other sites More sharing options...
Infrandom Posted February 1, 2017 Share #24 Posted February 1, 2017 Monarch can custom make the BOA to any length you require. I'd imagine the length would be entirely dependent on your body size. I'm a larger guy, just received my 55" BOA JCH, very comfortable and that's with the weight of the MP240. I also wear it crossbody, but using the split rings to attach it. I just can't come around to letting it hand upside down from the bottom plate mount. 2 Quote Link to post Share on other sites More sharing options...
}{B Posted February 1, 2017 Share #25 Posted February 1, 2017 The Artisan & ArtistACAM100. It's adjustable in length so that I can wear it bandolier fashion and it has thin leather protectors to keep the attachment rings from rubbing on the camera body. As the M10 has no plastic body protectors straps with hard leather ends will tend to rub the camera body. http://www.artisan-n-artist.com/product_detail.php?id=15 3 Quote Link to post Share on other sites More sharing options...
ebf Posted February 1, 2017 Share #26 Posted February 1, 2017 The urushi from Harry Benz. https://www.harrybenz.com/shop/urushi Sent from my iPhone using Tapatalk 1 Quote Link to post Share on other sites More sharing options...
Vec Posted February 1, 2017 Share #27 Posted February 1, 2017 Advertisement (gone after registration) Right now the 125cm Nevada from Tie Her Up. https://tieherup-camera-straps.myshopify.com/products/nevada-camera-strap?variant=21693502913 1 Quote Link to post Share on other sites More sharing options...
GMB Posted February 1, 2017 Share #28 Posted February 1, 2017 The Eddycam 35 mm in black http://www.eddycam.com/index.php?force_sid=016643a608a9a61190f9e711d8a4ed31&&cl=start&redirected=1#&panel1-5 Quote Link to post Share on other sites More sharing options...
dkmoore Posted February 1, 2017 Share #29 Posted February 1, 2017 The urushi from Harry Benz. https://www.harrybenz.com/shop/urushi Sent from my iPhone using Tapatalk It was reported that the Harry Benz straps will rub the paint off of the sides of the M10. Just a note. I put my HB back on my 246 and purchased a Leicatime trap that doesn't have the thick leather end. If you don't mind scuffing your camera then it doesn't matter but figured I would mention it. 1 Quote Link to post Share on other sites More sharing options...
Steve Ricoh Posted February 1, 2017 Share #30 Posted February 1, 2017 Ok, I'm on the outside of this elitist M10 group, but I've ordered a Peak Design cuff wrist strap and a slideLITE for my M240. Benefit: both are interchangeable in a flash without messing with the camera lugs. 1 Quote Link to post Share on other sites More sharing options...
chris_tribble Posted February 1, 2017 Share #31 Posted February 1, 2017 (edited) I'm currently using a 15mm oil tanned leather strap with industrial 10mm nylon ends & leather protectors to stop the split rings from rubbing against the body. Original Leica split ring! Total cost (if you've got a robust sewing machine + some leather work tools) around £4. Best strap I've ever used - seriously It wraps round a wrist if needed, goes across the body or over a shoulder, is very easy to pack in a Domke reporter satchel and doesn't slip. The leather feels good, and the nylon has been doubled, so while it's not it's secure and very flexible + it's the least likely material to abrade the camera body Leather: http://www.ebay.co.uk/itm/191890744248?_trksid=p2060353.m2749.l2649&var=490939489324&ssPageName=STRK%3AMEBIDX%3AIT Webbing: http://www.ebay.co.uk/itm/10mm-Black-nylon-webbing-Tape-x-10-/121737588368?hash=item1c58202e90:g:U8sAAOSwmLlX9qSn Why pay more? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited February 1, 2017 by chris_tribble 4 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/268427-which-strap-for-the-m10-merged/?do=findComment&comment=3202207'>More sharing options...
Rambot-M Posted February 1, 2017 Share #32 Posted February 1, 2017 Ok, I'm on the outside of this elitist M10 group, but I've ordered a Peak Design cuff wrist strap and a slideLITE for my M240. Benefit: both are interchangeable in a flash without messing with the camera lugs. I plan to use the same. 1 Quote Link to post Share on other sites More sharing options...
Mike Rawcs Posted February 1, 2017 Share #33 Posted February 1, 2017 I'm a bit concerned about using any strap with split rings. I've read on the forum about split rings working their way out of the strap lugs. Any thoughts on this phenomenon and ways to stop it happening? I'm not writing about the supplied M10 strap specifically, just straps with split rings in general. Quote Link to post Share on other sites More sharing options...
Neko Posted February 1, 2017 Share #34 Posted February 1, 2017 I like the one that comes with the camera. A bit stiff, but with use and the help of a leather conditioner will became softer and floppier. Quote Link to post Share on other sites More sharing options...
satureyes Posted February 1, 2017 Share #35 Posted February 1, 2017 Right now the 125cm Nevada from Tie Her Up. https://tieherup-camera-straps.myshopify.com/products/nevada-camera-strap?variant=21693502913 I was thinking this - is the side of the leather that's treated in the vintage way rough to the touch though? Quote Link to post Share on other sites More sharing options...
satureyes Posted February 1, 2017 Share #36 Posted February 1, 2017 I have the thicker version of this - but I want to try the narrow version. I like how it can convert to neck strap or over the shoulder. downside is all the plastic buckles and things can be a little annoying. http://www.artisan-n-artist.com/product_detail.php?id=387 Quote Link to post Share on other sites More sharing options...
satureyes Posted February 1, 2017 Share #37 Posted February 1, 2017 Am I being a bit silly - but what is the issue with straps rubbing at the side - what's different in the M10? Quote Link to post Share on other sites More sharing options...
satureyes Posted February 1, 2017 Share #38 Posted February 1, 2017 I see what the issue is. What about these (or something similar? http://m.ebay.co.uk/itm/Camera-Strap-Lug-Ring-Protector-suits-Leica-Nikon-Canon-etc-/192069696992 2 Quote Link to post Share on other sites More sharing options...
satureyes Posted February 1, 2017 Share #39 Posted February 1, 2017 Stumbled this chap on eBay- do any of you know him or his work? http://stores.ebay.co.uk/1901fotografi?_trksid=p2047675.l2563 Quote Link to post Share on other sites More sharing options...
edw Posted February 1, 2017 Share #40 Posted February 1, 2017 I highly recommend the Classico Dritto by Ulysses, specifically the 120cm (~47.25") version. I have two: one for my Q and another for my M-D. They're simple, well-made, thin, and age beautifully. I don't like things like shoulder pads or multi-segment straps or adjustable elements because they tend to get tangled with my messenger or camera bag, or just plain get twisted. Our cameras are light; they're not going to be cutting into your shoulder with a thin leather strap unless you have an enormous lens on them. I personally wish I could get these in 130cm or so. (Or I could just lose 10kg…) http://www.ulysses-photo.com/product/28 Quote Link to post Share on other sites More sharing options...
