x
 recently discovered the significant advantage of using an SD card the hard way: deleted photographs can easily be restored by inserting the card into a card reader and using recovery software. Unfortunately, I couldn't find any method to recover deleted photographs from the M11's internal memory.
Used to split RAW and JPG between external and internal, but that was largely out of force of habit from the GFX line with its two card slots.
I switched some time back to INT = SD, for many of those reasons mentioned above.
I would ALWAYS use some kind of external storage. I'd use the internal storage only as a backup source. Something happens to the camera and it doesn't turn on, isn't recognized by the computer, usb port damaged cause you put the cable in a rush. A whole host of issues that can happen and now your images are stuck inside the camera.
so are you having images written to internal drive and SD at the same time?
Since the M11-P launch day I use the internal storage and had never had that happen.  No matter what freezes and how, it does not lose the stored photos.
That's what I'm doing at present, DNG only though. If I travel without a computer I'll turn JPG on again so I can grab a few for posting to friends while on the road.
The internal storage in the camera will be more robust than any SD card, so I'm not concerned about wearing it out, but if I was, I'd have no issues for most purposes writing only to the SD card. I like to think I"ll turn on mirroring when I do really need it, but am realistic and acknowledge I may forget.
The new FOTOS with the background transfer can let you do this easily from an iPhone.  So no need for internal JPGs at all.  But I have them for redundancy and OOC original JPGs.:). The problem is Lightroom is not ingesting them together with the DNG but rather as two separate files and I have to stack them choosing 0 time interval.
Oh cool. I wondered if there was a raw converter in FOTOS (Android here, I am not an Apple user) and do plan to test out what is possible as I'd really like to leave my laptop behind for other reasons.
I turn on JPGs when shooting an event so I can send them to the organizer or other parties with zero processing after quick culling.
When importing in lightroom it does get tiresome waiting for the ingestion process to display all the images; at that point I deselect ALL and select only the range of DNGs, if I happen to have JPGs turned on. DNG only does make it cleaner/easier.
Edited by MikeW
