jhonzatkl Posted March 21 Author Share #21 Posted March 21 Advertisement (gone after registration) 1 hour ago, UliWer said: Did you change the focus for each f-stop? (Camera placed on a tripod and avoing all sorts of shake by using a cable release). First of all the Live View is not always reliable with wide angle lenses of high contrast. Even if you use focus peaking it will show you too much as being "sharp" which in reality is slightly out of focus. With wide-angles the rangefinder is unsurpassed for exactness - as long as it is calibrated exactly. If you did not change the focus for each f-stop you will have to accept a slight amount of focus shift with this lens. Focus shift means that the focus at f/2 will not be the same as with f/2.8. The larger depth of focus for smaller f-stops will compensate for this focus shift: stepped down photos will look sharper. So I'd recommend to try again using the rangefinder with f/2 and look what happens if you step down. Thank you for you comment. I'l definitely try it again. Quote Link to post Share on other sites More sharing options...
Advertisement Posted March 21 Posted March 21 Hi jhonzatkl, Take a look here Summicron 35/2 ASPH II - wide open performance. I'm sure you'll find what you were looking for!
Al Brown Posted March 21 Share #22 Posted March 21 There definitely is focus shift with Summicron 35 ASPH. Red dot is the point of most critical sharpness. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/391263-summicron-352-asph-ii-wide-open-performance/?do=findComment&comment=5122273'>More sharing options...
lct Posted March 21 Share #23 Posted March 21 1 minute ago, Al Brown said: There definitely is focus shift with Summicron 35 ASPH Not on mine. Never has been since i got it in 2010. I would not say the same about the Summicron 35/2 v4 though. Both my Canadian and German copies suffer a bit from that at around f/4. Quote Link to post Share on other sites More sharing options...
35photo Posted March 22 Share #24 Posted March 22 I've had my ASPH I for almost 25 years.... Have never had an issue with its sharpness as all! Have you had it CLA'd lately? I had a focusing issue with my my pre ASPH 35 1.4 that was resolved with the focusing mechanism being overhauled. Quote Link to post Share on other sites More sharing options...
jhonzatkl Posted March 22 Author Share #25 Posted March 22 This lens was produced in 2018 and wasn't used heavily. I don't think, there is need for CLA as soon as after 5 years of usage? Quote Link to post Share on other sites More sharing options...
yizhilelexia Posted March 22 Share #26 Posted March 22 I have 2 leica m11s(one black version and one silver version) and several copies of 35 1.4 FLE(11663 and 11675). In sharpness perspective, leica 35 FLE is just not comparable with modern lenses made by sony, even some very cheap ones. The dng file came out from this combo wide open is not sharp. Almost all the reviewers said the lens is sharp. But the truth is the FLE is an old lens and it won't be able to match the 60 mp sensor wide open. 1 1 Quote Link to post Share on other sites More sharing options...
Al Brown Posted March 22 Share #27 Posted March 22 (edited) Advertisement (gone after registration) 42 minutes ago, yizhilelexia said: I have 2 leica m11s(one black version and one silver version) and several copies of 35 1.4 FLE(11663 and 11675). In sharpness perspective, leica 35 FLE is just not comparable with modern lenses made by sony, even some very cheap ones. The dng file came out from this combo wide open is not sharp. Almost all the reviewers said the lens is sharp. But the truth is the FLE is an old lens and it won't be able to match the 60 mp sensor wide open. My 11675 is STELLAR, this lens really shines wide open at infinity but of course cannot be as sharp as the APO wide open, it is after all f/1.4... But yes, most M summilux lenses are already old by today's standards, my Sony 50/1.2 G Master beats every single one of my M luxes wide open. To address your last sentence, EVERY LENS IN THE WORLD can match a 60mpix sensor. The sensor only brings out flaws of the lens more. There is no such thing as a sensor outresolving a lens or vice versa. Edited March 22 by Al Brown 2 1 Quote Link to post Share on other sites More sharing options...
hansvons Posted March 22 Share #28 Posted March 22 I have the V1 of this lens, which shares the same lens design with the V2. It’s not a perfect 35mm by today’s standards. It’s from the film era and renders closer to the V4 KoB Summicron than to its modern-day APO sibling. It flares nicely, shows some fine glow wide open, and has a bent focal plane. It’s also not super sharp at full aperture. But it renders corners pretty sharp wide open, shows hardly any corner smear (none on film), and already shows peak sharpness at f4, which are notable improvements. It’s an overseen character lens with a warmer, more neutral colour reproduction compared to earlier Summicrons. If you were looking for a small but almost clinically rendering lens that is sharp from the very beginning and hardcore flare-resistant, I’d check out the 35mm Summarit, which was designed for digital sensors and also is an aspherical design. 1 Quote Link to post Share on other sites More sharing options...
Derbyshire Man Posted March 22 Share #29 Posted March 22 39 minutes ago, Al Brown said: My 11675 is STELLAR, this lens really shines wide open at infinity but of course cannot be as sharp as the APO wide open, it is after all f/1.4... But yes, most M summilux lenses are already old by today's standards, my Sony 50/1.2 G Master beats every single one of my M luxes wide open. To address your last sentence, EVERY LENS IN THE WORLD can match a 60mpix sensor. The sensor only brings out flaws of the lens more. There is no such thing as a sensor outresolving a lens or vice versa. But look at the size of it! I'd rather eat worms! I still have lots of top of the range Canon gear but the reason I never pick it up and instead go for Leica when manual focus and Fuji auto is dragging that stuff around outweighs the benefit except in obvious exception cases like sport etc. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/391263-summicron-352-asph-ii-wide-open-performance/?do=findComment&comment=5123690'>More sharing options...
Al Brown Posted March 22 Share #30 Posted March 22 13 minutes ago, Derbyshire Man said: But look at the size of it! I'd rather eat worms! I still have lots of top of the range Canon gear but the reason I never pick it up and instead go for Leica when manual focus and Fuji auto is dragging that stuff around outweighs the benefit except in obvious exception cases like sport etc. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! It does bring A LOT of money in so I am willing to happily suffer the size. 1 Quote Link to post Share on other sites More sharing options...
lct Posted March 22 Share #31 Posted March 22 Among compact lenses, my only 35/2 beating the Summicron 35/2 asph v1 in terms of sharpness at full aperture is the Ultron 35/2 asph. It is a tiny lens with a busier bokeh while the Nokton 35/1.5 asph has just a little less acutance with a smoother bokeh so the Summicron 35/2 asph v2 should still be the king (or the prince) of sharpness among compact 35/2 lenses, besides the apo version. Otherwise it would be of no interest to me but what folks say about it here make me even more reluctant to upgrade from my v1. Quote Link to post Share on other sites More sharing options...
jhonzatkl Posted March 22 Author Share #32 Posted March 22 There is still chance, my copy is defective and these result are therefore not representative. Quote Link to post Share on other sites More sharing options...
lct Posted March 22 Share #33 Posted March 22 14 minutes ago, jhonzatkl said: There is still chance, my copy is defective and these result are therefore not representative. Depends on where you focused your pics. If you focused this one on the rabbit's nose for instance, it looks normally sharp to me. https://photos.smugmug.com/photos/i-xn2vZkm/0/DLDZLSZN8MVR5RTxgQb7r4CRs6sLqQDpCDgPtjPhX/X4/i-xn2vZkm-X4.jpg Quote Link to post Share on other sites More sharing options...
Rezinator Posted March 22 Share #34 Posted March 22 My 35 asph v2 is sharper than my previous v1. This was clearly visible on my M11, forcing me to sell the v1. I’m very happy with the performance and size of the Summicron. 1 Quote Link to post Share on other sites More sharing options...
