On 5/7/2021 at 6:03 PM, SrMi said:
In case some are not aware of it, here is Erwin's post:
https://photo.imx.nl/technique/Analysis/page80.html
TLDR
Well yes, I did read it but I agreed with none of it. It's bullshit theorising. At any point in time there will be a camera that suits a person, it may be the worst Leica M ever designed, or it may be the best.
1 hour ago, 250swb said:
TLDR
I would love to hear points where you disagree. I do not own a film Leica yet. As I am learning about the various models, I would appreciate any form of shared knowledge.
TLDR
Honestly, if that’s your conclusion, it is not supported by the words on the page.  One could hardly describe setting out the differences between models as “bullshit theorising”. Perhaps your criteria for bullshit are different from mine (or general commonsense).  What do I know …
Edited by Mute-on
The late Tom Abrahamsson had an interesting (but not identical) discussion on the various M's on the rangefinder forum.  This was long ago, circa 2007.  The only issues I ever took with Putts is that he was generally a lab bench tester, as opposed to someone like Tom A who developed beliefs/ reached conclusions by actual use of the items in the field.  Not saying one is better then the other, but I tend to gravitate to the latter, but each had their biases.  Anyway, if any one is interested, just search "M Build Quality" on the rangefinder forum.
Here's a portion of the discussion thread:
It is difficult to narrow down issues like build quality. It depends on usage and care more than anything. Today we expect our DS M3"s to work perfectly after 50+ years!
My own experience of the various M's is as follows:
M3/ Early double stroke ones. The shutter brake tends to give up and you occasionally find them with either black rangefinder patches or severely faded "half" mirrors. It is still the M with the smoothest advance and the softest release of them all.
Later single stroke M3's are among the best built cameras ever. If it has been serviced regularly and not abused, they tend to work perfectly, even after 1000's of rolls. The weak spot is the finder. They can black out through de-lamination of the prism (usually through impact).
M2/ Because it is a simpler camera, there are less things to go wrong. The finder is robust and though it can dim through oxidization of the mirrors, it can still be fixed. The advance on some of the earlier M2's (button advance) could get rough with heavy use. If the shaft springs are worn, you can get overlap on the negatives when the shaft turns inside the take up spool.
M4/ leica put everything into this camera! It is very well built, but check for bent re-wind cranks and worn take up "tulips". The finder usually hold up well and has the advantage of having many parts in common with the M2 and later M4P's and M6's. It is usually easier to find a "mintish" M4 than M2/M3 as these earlier Leica were the only game in town for press photographers in the 50's. In the 60's the SLR came into play and the pro's switched, mainly because of the ease of using long lenses.
M5/ I have had several of these, but I never got along with it. Too big and a bit clumsy. Again, the mechanicals are very good, though the bottom rewind can act up and one of mine decided not to retract the meter arm. Interesting object cluttering up the sky on a whole roll!. The meter sensor can age badly (like most of us) and loose sensitivity and it does use the #625 style battery too.
M4-2/ The earliest of these had a problem with the shutter brake and the shutter speed regulator would go 'kabloonk" occasionally. Part of the problem was mis-communication between Wetzlar and Midland. The good news is that most of the M4-2's available now have been fixed. Leica started to add a lot of shims to the various shafts and locks and with time these springs shims get tired and you get misaligned locks on the base plate and interior drives. The film rewind was made from alloy and would bend or "buckle" if you hit it.
The M4-P/ This is a generally good camera and it can take a lot of film. The problems with the shutter was rectified. The film rewind is still alloy and occasionally you have to replace it(expensive) or simply bend it back and file off the flange at the bottom. I still have my 1981 M4P and it has had 10 000's of rolls through it. It was my bench tester for Rapidwinders and also primary camera for a lot of trips. The inter mediate drive (motor coupling) came apart once and was replaced and the gear in the advance wore out and was replaced. A couple of curtains got pin holded (not the cameras fault).
M6/ The first version of the M6 had problem with the meter "chip" and they frequently died or showed only one of the diodes. Leica replaced most of these under warranty in the mid 80's and after that the M6 is as good as even the earlier M2/M3/M4's. It is a very robust cameras, the alignment in the rangefinder can go out if you bang it hard, but this is rare. There have been problems with a 'grommet" that seals the meter information transfer wires and you could get light leaks. Some of the Titanium M6's had a film counter spring that failed and needed to be replaced.
M6TTL/ Initially these cameras had a problem with battery drain. There are a couple of contacts at the bottom of the battery well that would drain the batteries in a matter of hours. The solution is to push these contacts down, below the surface of the bottom. These are "test" connections for probes. Otherwise the TTL is a good camera and as most confirmed M-users prefer the old style shutter speed dial, a good deal too. On a couple I had problems with information transfer from the back door to the diodes (both after having been banged hard against unyielding car doors and door frames).
MP/ Early MP's had a faulty seal around the eye-piece and dust would seep in to finder. It was fixed and Lieca actually supplied new and improved seals to "do it yourselfers". Thre was a bit of a flare problem in the finder with the 0.85 and 0,72 versions that could cause problems. Other wise I think that the MP is one of the best built Leica M's ever. The top plate is brass as a Leica top should be, the gears are remarkably smooth (film advance on a MP rivals that of a Double Stroke M3} and the fact that you have a choice of finder magnification adds to the attraction.
M7/ I had one for a couple of years and apart from going through batteries at an alarming rate and a tendency to shut down suddenly, it held up well. The electronics worried me though and the magnetic controls of the shutter would be sensitive to a heavy Gauss field ( a large electric motor starting up). I never liked the release on the M7 - very "jagged" feel to it. I loved the 32 second long exposure count though.
general problems encountered with M4-2/M4-P and some R6's. The top was made from die-cast zinc alloy and if you got a scratch that penetrated the plating the top turned into a galvanic element and started to bubble the black chrome. More common on the R6, but I have seen some M4-2 and M4-P's with the same problem.
The shutter curtains on old M's can dry out and get brittle and the adhesive that holds the 'straps" for the curtains to the shutter drum will loose 'power" with age and can come loose. There is also a felt trap in the track of the M's (up to M4P) that can came loose and jam the shutter curtain. It is again adhesive that gos brittle with age. It is aiways a good idea to CLA any older M' on a regular basis anyway (every 5-7 years) and beware of M's that have sitting idle for a long time. Lubricants dry out and curtains loose flexibility if they are not used.
What is remarkable is not the problems that occasionally occur with older M's - it is how well they still work after 40 or 50 years! There are few products available today that can claim that. Even battered old M3's and M2's will produce great pictures after decades of use. So the shutter speeds might be a bit off, learn to compensate, the finder could be brighter - use hyper focal, the rewind squeels a bit - dont worry, it will wear it self in! AND there a few products that have compatibility going back 80 years. You can put your nickel Elmar from 1927 on your 2007 MP or even on the M8. That is foresight in design and, yes a bit of german stubborness too - but it all benefits us, the users.
__________________
Bests to Everybody,
Tom A
http://flickr.com/photos/rapidwinder/
Edited by TheBestSLIsALeicaflex
  • Thanks 3
A little harsh, as I think Erwin took enough photographs with Leica M's to know what he was talking about. Puts with one 't' by the way.
Well, just my impression from reading some of his stuff, mostly with his discussions of optics, but also bodies.  I didn't always reach the same conclusion as Puts when it came to practical in the field use, as opposed to counting pixels, measuring lines on film,  meter sensitivity, ect.   In fact, many times I reached the opposite conclusion.  It wasn't intended as a knock; just reality, he had a more analytical/ scientific approach, as opposed to basing things on practical, field experience.  I'm not saying he was just an arm chair theorist.  By no means am I an expert on either individual, and the rangefinder community suffered a true loss when when these gentlemen passed away.  Anyway, sorry if anyone gets offended.
Totally agree with that. Let's hope they are discussing this right now at the great camera club in the sky!
Choice of a (used) film M camera comes down to:
Budget
Lens (frameline) preferences
Meter or no meter
What you can find for said budget
Personal preference (they do feel slightly different - best to handle a few to see what feels best)
Otherwise just buy a new one.
Budget
Meter or no meter
This is what I understood Steve's post to mean... just with a few more words.
<snip>
Thank you for sharing that post. The search term is actually "M Camera Build Quality".
IMO, Tom A gives complementary information about M camera bodies, it does not replace the information in Erwin's article.
I don't know enough about film M's to discern what statements are accurate or inaccurate.  But I like to learn the differences and both articles lay things out informatively.  At least there is no hyperbole (e.g. Ken Rockwell).
In addition, both articles seem to be factual correct and trustworthy. Ken's article often contain incorrect statements.
You may enjoy the Leica M - advanced photo school by Gunter Osterloh.
  • 1 year later...
__________________
Bests to Everybody,
Tom A
Thank you for this
So much more grounded and informative than Erwin Puts - What a guy Tom was (I wish I'd met him)
I just noticed this thread because of Jono's contribution. Erwin Puts and Tom Abrahamson certainly had rather different approaches, and their information could be complementary sometimes. I still use Erwin's Leica Compendium quite often, but when I tried to discuss certain things with him he never seemed to want that. I asked him for instance to explain his words about the Elmar 3.5/65mm, that its use as a macro-lens might be questioned. He replied that it was simply the case.
Tom always liked to exchange thoughts, althoug I only emailed with him, but his experience and his way of working with Leica camera's and lenses was exciting.
Lex
