SL2 Multi Shot Mode
Recently Browsing 0 members
No registered users viewing this page.
Similar Content
By pele2010
Hey ,
I can't find an angle viewfinder for the SL2.
How do you manage to make low or high angle picture without using your phone.
Is there any DIY that you can recommend?
And apart of this:
is there a menu point to mirror the image of the camera? If so we could just use a mirror or something reflective
as a mirror.
And yes I know that you can take the picture and alter the framing. But sometimes its quit nice to see what you are doing.
I am enjoying both methods but I would like to achieve the method with more control.
Curious how you solve this challenge.
kind regards Peter
By chris_tribble
This may seem a bit obvious, but after having followed a general principle of having a 2 minute auto power off, and being left with 50% power after a day's walking and maybe 60 images, I decided to switch to a 10 second auto power off, and I'm finding I still have a full bar indicated after the same kind of use. If you've been unhappy with battery-life, I'd recommend playing with the power-off settings and seeing what improvements you can make. For information, I'm not experiencing significant start up delays either. Just touch the shutter button and everything's good to go pretty well immediately.
By Ciamprob
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! -
By Aaron Daniel
Hi all, I've noticed there isn't a dedicated thread for editing L-Log footage, so I will begin one here. I realize that colouring and re-touching video is a very subjective field, but I wanted to see how others work within Leica's limited literature surrounding post-production in video.
I've just updated my Atomos Ninja V to the latest firmware, which now allows for L-Log recording from leica (the past year with the SL2 was a little tedious working with both internally and externally recorded video footage). Now, with this update, BT2020 seems a lot nicer.
I've just done my first video about this update here:
By augustwest100
I was wondering if anyone has done side by side comparisons of the Sigma L mount 24-70 with the Leica Vario Elmarit 24-90.
I find that I use my Sony a9 mostly as follows:
75% of the time I have the excellent 55mm Sony Zeiss 1.8 on it due to the best balance of size, weight, sharpness, bokeh, every day use
20% of the time I use the excellent zeiss batis 25mm 1.8
5% of the time I think about using my 70-200 f4 Sony or my excellent 24-70 Sony G master f2.8...and then decide I don't really want to carry it around, so I take the 25mm and the 55mm instead and alternate use. This can be a pain when I need to swap them back and forth but is lighter option and sometimes I just take one.
So I am trying to figure out where I would start with a Leica SL2 system, as I only have a Leica M 35 summicron presently:
Go with a 24-90mm Leica Vario Elmarit (costly and heavy) and use my M lens when I want a lighter setup to walk around with.
Go with a Sigma 24-70 for general use, and then put money towards an autofocus Leica 35mm or Leica 50mm.
Neither of these setups will address the 70-200 lens that would be missing, but I rarely used it, so I can do without I think and either pick up a used 135mm manual focus lens, or maybe a 100mm macro lens and crop it.
At any rate, would be nice to get some feedback on the image quality of the Sigma 24-70 as that might help me decide. I am continually trying to choose between the SL2, SL2s and M10r and it doesn't seem to make sense to get the SL2 system without at least one autofocus general purpose lens. Otherwise, might as well just go with the M!
Thanks, all!
