Recently Browsing 0 members
No registered users viewing this page.
Similar Content
By NicholasT
I've been shooting with Sigma 100-400 for couple of months.
As others have mentioned I find that this lens punches way above its price point in terms of IQ. Also due to its compact size and weight I find myself bringing this lens along far more often than I've ever done with a lens with 400mm reach.
Today I decided to test the lens to try to answer a couple of questions I had about the lens:
1. I was finding some inconsistency in sharpness even when shooting on tripod. There's been speculation in various posts that this could be due to mechanical shutter. I wanted to test this out.
2. I also have the TC-1411 teleconverter, but have not been making much use as I was uncertain about its impact on image quality. I've seen several reviews that report little to no IQ degradation from its use so decided to test it out.
To answer the first question I took 3 exposures using mechanical shutter and compared the results. I found wide variation in the results. I repeated the test 3 times with the same wide variation. The test was conducted on a tripod (top of the line Really Right Stuff) at 100 ISO with 12 second shutter delay shooting from indoors ( no wind or other impacts).
I then repeated the test several times with electronic shutter. While there was some variability between shots the differences were minor.
Based on this relatively simple test I'm satisfied that the speculation that mechanical shutter impacts image quality in a noticeable way is in fact correct. I will be using electronic shutter with this lens from now on.
In order to answer the second question I took a series of 3 images at 400mm and then at 560mm focusing on a group of junction boxes on top of a building ( distance about 230 meters or 750 ft. I chose this subject because the boxes have numbers on them which helped with subsequent comparison between images. Also the texture on the wall surrounding the junction boxes offered a further reference point.
From each set of images taken at 400m and 560mm I selected the best one (differences were minor based on use of electronic shutter). I then compared the image taken at 560mm with 200% magnification with the one taken at 400mm with 300% magnification. I used these settings as I figured it would "roughly" equalize the result between using lens with teleconverter versus doing a more aggressive (equivalent) crop in post.
All images were shot at 100 ISO in the case of 400mm F6.3 & 1/125 and in case of 560mm at F9.0 & 1/60
Below I've attached the comparison between the two. I will share which is which in subsequent post but thought I'd share and get some initial reaction to the comparative difference.
By chris_tribble
I'm currently wrestling with which lenses to keep / sell / add - and wonder if others are dealing with similar issues.
At the moment I'm using two systems. L mount and M mount.
The L mount system is one SL2 body and the following lenses:
VE 24-90
VE 90-280
Sigma 45 f2.8 DG DN
The M system is two M10 bodies and:
15 Voigtlander Super-wide Heliar III f4.5
28 Summicron Asph
35 Summicron Asph
50 Summilux Asph
50 Summarit f2.4
75 Summarit f2.4
90 Macro-Elmar + macro adapter
135 M Apo-Telyt f3.4
In the current circumstances, my daily carry everywhere is the SL2 + 24-90. I never thought it would be so easy to manage - but it is. Because of how life is at the moment, I'm hardly using the VE 90-280. This means there is a large lump of money sitting in a lens that is little used. However, I got it for a good price used and I'll hold on to it for a year or two and then review. I don't use the Sigma 45 so much since I got the VE 24-90 (which is SUCH a good, well behaved lense), but I still like the images I make and I am happy to retain it for now. I'm also not using the M's much at present. This isn't a reason for getting rid of them - but the retained lenses are another issue. If I look back through thousands of images in my Lightroom archive, the three M lenses that dominate are 28 / 35 / 50. The others account for only about 5% of images. I loved the 90 Macro when I first got it - but I was mainly using it as a compact medium telephoto on the M10, and not really using it for macro! AND The Sigma 45 (with its near macro capability) on the SL2 was so much easier to work with! Likewise, I've had the 135 A-T for a long time, and it's a flawless lens (which works great on the SL2), but how much do I use it? Very little at the moment. I use the Voigtlander 15 Super-wide Heliar very little too - but I know that it's essential for certain kinds of interior and landscape
Now that I have the SL2, the lenses that are really redundant are the 50 & 75 Summarits + the 90 Macro-Elmar. Off to Ffordes they will go. But then what. What am I lacking. My current feeling is that it's a really good portrait lens and (possibly) a dedicated medium telephoto / macro lens. Which leads me to Sigma. It seems that the new 85 1.4 DG DN is a candidate as is the 105 Macro DG DN. I'm also tempted by the 35 f2 DG DN - though this overlaps with the 35 Summicron (which works beautifully on either M or SL).
SO - does anyone have experience with the two Sigma lenses mentioned above (85 / 105). Does anyone have other thoughts? I'm toying with the Sigma 14-35, but I'm not sure if I'd use it that much. Heigh ho - I suppose this is all to do with too much time on my hands during the pandemic - though I did get out this morning in beautiful sunshine and snow (with the SL2 and 24-90!). Examples here:
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
Thanks for any thoughts...
By lecycliste
I’m using an Atomos Ninja V 5” monitor driven by the SL2’s HDMI port. It displays the viewfinder image just fine, but none of the AF tracking and exposure data shown in the viewfinder. This gives me a very viewable display at low camera angles - the eyepiece no longer gets in the way, and I can actually see what I’m shooting.
** Is anyone else using an external monitor, and how do I get the AF tracking point and exposure info I see in the viewfinder to appear in the external monitor?
Right now all I get is the viewfinder image. I have to place the AF tracking point in the middle of the viewfinder and put the subject there when I’m using the external monitor without knowing if I’m AF tracking or not.
Thanks..
By sillbeers15
Two shots taken same day within a couple of minutes apart.
One shot was taken with the SL2 single shot with SL16-35 and another with M10R with WATE.
Both shots taken at ISO100 / M mode / F9 / 1/20 sec on tripod.
Can you tell which shot is taken with SL2 + SL16-35mm lens?
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!untitled-1001471 by sillbeers15
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!untitled-1020091 by sillbeers15 -
By jonoslack
Hi There
Several people have asked me about this, and so it seemed to be worth doing it!
All the files were originally shot on DNG - the sharpening and noise reduction sliders in Lightroom were all zeroed. The SL2 files were opened in Photoshop and the Image size reduced without any noise reduction help. They were then exported as 100% jpg quality 12 jpg files. I've then done an XY comparison zoomed in to approximately 100% and taken a screen shot. I'll put this on to the Review thread as well, but I thought it was worth putting it up as a separate thread.
As you would expect - downsizing the SL2 images does help with the noise - but even so, at higher ISO there is still at least a stop difference. In each case the SL2-S is on the left. To me this is a little like angels dancing on the heads of pins, and it's also open to methodology questions - and anyway, why would you not use noise reduction?)
First of all, the Scene:
100 ISO:
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 400 ISO
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 1600 ISO
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 6,400 ISO
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 12,500 ISO
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 25,000 ISO
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 50,000 ISO
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Finally 100,000 on the SL2-S and 50,000 on the SL2
