LUF Admin Posted January 17, 2020 Share #1 Posted January 17, 2020 Advertisement (gone after registration) Leica M10 Monochrom Technical Data Camera type: Compact digital view and rangefinder system camera with a dedicated black-and-white image sensor. Lens attachment: Leica M bayonet with additional sensor for 6-bit coding Lens system: Leica M lenses Leica R lenses with an optional adapter (available accessory) Sensor: B/W CMOS chip, active area approx. 24x36 mm, without color and low-pass filter Resolution: DNGTM: 7864 x 5200 pixels (40,89 MP), JPEG: 7840 x 5184 pixels (40,64 MP), 5472 x 3648 pixels (20 MP), 2976 x 1984 pixels (6MP) Data formats: DNGTM (raw data, compressed loss-free), JPEG File size: DNGTM: 40-60 MB, JPEG (40MP) 10-20 MB: Depending on resolution and picture content Buffer memory: 2GB / 10 pictures in series Storage media: SD cards up to 2GB/SDHC cards up to 32GB/SDXC cards up to 2TB Menu languages: German, English, French, Spanish, Italian, Portuguese, Japanese, Traditional Chinese, Simplified Chinese, Russian, Korean Exposure metering: Exposure metering through the lens (TTL), with working aperture Metering method: Light reflected by the blades of the 1 shutter curtain onto measuring cell. Metering range: At room temperature and normal humidity for ISO 200, at aperture 1.0 EV-2 to EV19 at aperture 32. Flashing of the left triangular LED in the viewfinder indicates values below the metering range Sensitivity range: ISO 160 to ISO 100.000, adjustable in 1/3 ISO increments from ISO 160, choice of automatic control or manual setting Exposure modes: Choice of automatic shutter speed control with manual aperture preselection - aperture priority A, or manual shutter speed and aperture setting Flash exposure control Via accessory shoe with central and control contacts Flash unit attachment: Optionally triggered at the 1st or 2nd shutter curtain Flash sync time: = 1/180 s; slower shutter speeds can be used, if working below sync speed: Automatic changeover to TTL linear flash mode with HSS-compatible Leica system flash units Flash exposure metering: Using centre-weighted TTL pre-flash metering with Leica flash units (SF40, SF64, SF26), or flash units compatible with the system with SCA3502 M5 adapter Flash measurement cell: 2 silicon photo diodes with collection lens on the camera base Flash exposure compensation: +/-3EV in1⁄3EV increments Displays in flash mode (in viewfinder only): Using flash symbol LED Viewfinder Construction principle: Large, bright line frame viewfinder with automatic parallax compensation Eye piece: Calibrated to -0.5 dpt.; corrective lenses from -3 to +3 diopter available Image field limiter: By activating two bright lines each: For 35 and 135mm, or for 28 and 90mm, or for 50 and 75mm; automatic switching when lens is attached. Parallax compensation: The horizontal and vertical difference between the viewfinder and the lens is automatically compensated according to the relevant distance setting, i.e. the viewfinder bright-line automatically aligns with the subject detail recorded by the lens. Matching viewfinder and actual image: At a range setting of 2m, the bright-line frame size corresponds exactly to the sensor size of approx. 23.9 x 35.8mm; at infinity setting, depending on the focal length, approx. 7.3% (28mm) to 18% (135mm) more is recorded by the sensor than indicated by the corresponding bright line frame and slightly less for shorter distance settings than 2m Magnification: (For all lenses) 0.73 x Long-base rangefinder: Split or superimposed image range finder shown as a bright field in the centre of the viewfinder image Effective metering base: 50.6mm (mechanical measurement basis 69.31mm x viewfinder magnification 0.73x) Displays In the viewfinder: Four-digit digital display with exposure alerts above and below On back: 3" colour TFT LCD monitor with 16 million colours and 1,036,800 pixels, approx. 100 % image field, glass cover of extremely hard, scratch-resistant GorillaR glass, colour space: sRGB, for Live-View and review mode, displays Shutter and shutter release Shutter: Metal blade focal plane shutter with vertical movement Shutter speeds: For aperture priority: (A) continuous from 16min to 1⁄4000s., for manual adjustment: 8s to 1⁄4000s in half steps, from 8s to 16min in half steps, B: For long exposures up to maximum 16min (in conjunction with self-timer T function, i.e. 1st release = shutter opens, 2nd release = shutter closes),(1⁄180s): Fastest shutter speed for flash synchronization, HSS linear flash mode possible with all shutter speeds faster than 1⁄180s (with HSS- compatible Leica system flash units) Picture series: Approx. 4.5 pictures/s Shutter release button: Two-stage, 1st step: Activation of the camera electronics including exposure metering and exposure lock (in aperture priority mode), 2nd step: Shutter release; standard thread for cable release integrated. Self-timer: Delay optionally 2s (aperture priority and manual exposure setting) or 12s, set in menu, indicated by flashing LED on front of camera and corresponding display in monitor. Turning the camera on/off: Using main switch on top of camera; optional automatic shutdown of camera electronics after approx. 2/5/10 minutes; reactivated by tapping the shutter release Power supply: 1 Lithium-ion rechargeable battery, nominal voltage 7.4V, capacity 1100mAh.; maximum charging current/voltage: DC 1000mA, 7.4V; Model No.: BP-SCL5; Manufacturer: PT. VARTA Microbattery, Made in Indonesia, Operating conditions (in camera): 0°C - + 40°C Charger: Inputs: 100-240V AC, 50/60Hz, 300mA, automatic switching, or 12V DC, 1.3A; Output: DC 7.4V, 1000mA/max. 8.25V, 1100mA; Model No.: BC-SCL5; Manufacturer: Guangdong PISEN Electronics Co., Ltd., Made in China, Operating conditions: 0°C - + 35°C GPS (only with Leica Visoflex Viewfinder attached, available as an accessory): Optional (not available everywhere due to country-specific legislation, i.e. enforced automatic shutdown in those countries), data are written to EXIF header in picture files. Wi-Fi Complies with IEEE 802.11b/g/n standard (standard Wifi protocol), channel 1-11, encryption method: Wifi-compatible WPATM/WPA2TM encryption, access method: Infrastructure mode Camera body Material: All-metal die cast magnesium body, synthetic leather covering. Brass top panel and base, black chrome plated finish Image field selector: Allows the bright-line pairs to be manually activated at any time (e.g. to compare detail) Tripod thread: A . (.") DIN stainless steel in bottom Operating conditions: 0–40 °C Interfaces: ISO accessory shoe with additional contacts for Leica Visoflex viewfinder (available as an accessory) Dimensions: (width x depth x height) approx. 139 x 38.5 x 80mm Weight: approx. 660g (with battery) Scope of Delivery: Charger 100-240V with 2 mains cables (Euro, USA, varies in some export markets) and 1 car charging cable, lithium ion battery, carrying strap, body bayonet cover, cover for accessory shoe More about the Leica M10 Monochrom Leica M10 Monochrom Technical Data Leica M10 Monochrom Manual & Quickstart Guide Leica M10 Monochrom Sample Images Leica M10 Monochrom Reviews Leica M10 Monochrom Survey 1 Link to post Share on other sites More sharing options...
Advertisement Posted January 17, 2020 Posted January 17, 2020 Hi LUF Admin, Take a look here Leica M10 Monochrom Technical Data . I'm sure you'll find what you were looking for!
mmradman Posted January 17, 2020 Share #2 Posted January 17, 2020 Some nice improvement over M246 Longer ISO range starting at ISO 160 and past 25,600. Compressed lossless RAW retained but 14Bit. Longer max exposure, 16 minutes, probably ISO dependant. Link to post Share on other sites More sharing options...
FrankF Posted January 17, 2020 Share #3 Posted January 17, 2020 Would the owner please check the English versions...... as far as I can read, only the Tecg specs are in English. The rest of the pages, inclusing Jono's evaluation are in German. Thank you Frank Link to post Share on other sites More sharing options...
Bewithabob Posted January 17, 2020 Share #4 Posted January 17, 2020 Is the leaf shutter in the M10 M the same new quiet shutter as what’s in the M10-P? Link to post Share on other sites More sharing options...
Likaleica Posted January 17, 2020 Share #5 Posted January 17, 2020 21 minutes ago, Bewithabob said: Is the leaf shutter in the M10 M the same new quiet shutter as what’s in the M10-P? Yes Link to post Share on other sites More sharing options...
LUF Admin Posted January 17, 2020 Author Share #6 Posted January 17, 2020 vor 35 Minuten schrieb FrankF: Would the owner please check the English versions We have everything in German and English: English Leica M10 Monochrom Jono's Field Report Technical Data (this thread) Leica M10 Monochrom Sample Images German Leica M10 Monochrom Jono's Test Leica M10 Monochrom Technische Daten Leica M10 Monochrom Leica M10 Monochrom Beispielbilder 1 Link to post Share on other sites More sharing options...
FrankF Posted January 17, 2020 Share #7 Posted January 17, 2020 Advertisement (gone after registration) When I opened the articles about the new MM, from the EMail that was sent out to users, I found them only in German. Now I have read them in English. I do not know why, but I appreciate the dedication to respond to my predicament. Thanks Frank Link to post Share on other sites More sharing options...
xiaubauu2009 Posted January 18, 2020 Share #8 Posted January 18, 2020 What is the bit rate of the RAW files? 12 bit like the M246 or 14bit like the MM1? Link to post Share on other sites More sharing options...
SrMi Posted January 18, 2020 Share #9 Posted January 18, 2020 12 minutes ago, xiaubauu2009 said: What is the bit rate of the RAW files? 12 bit like the M246 or 14bit like the MM1? English manual, page 134 Color depth DNG: 14 bit Link to post Share on other sites More sharing options...
xiaubauu2009 Posted January 18, 2020 Share #10 Posted January 18, 2020 4 minutes ago, SrMi said: English manual, page 134 Color depth DNG: 14 bit This is good, so it's 14bit now. Sweet! Link to post Share on other sites More sharing options...
Jeff S Posted January 18, 2020 Share #11 Posted January 18, 2020 Is there a RAW histogram display? Jeff Link to post Share on other sites More sharing options...
Likaleica Posted January 18, 2020 Share #12 Posted January 18, 2020 24 minutes ago, Jeff S said: Is there a RAW histogram display? Jeff Jono might know for sure but I don't think so. Also, it's small and located in the upper left of the display. Link to post Share on other sites More sharing options...
mujk Posted January 18, 2020 Share #13 Posted January 18, 2020 3 hours ago, Jeff S said: Is there a RAW histogram display? Jeff The small histogram is explained on page 85 of the manual. I didn't find information on whether it's generated from raw data or the jpg preview. From the manual: The histogram is always based on the brightness displayed; depending on the settings used, it may not represent the final exposure. In picture mode, the histogram should be regarded as a "trend indicator”. The histogram during rendering may differ slightly from the one during exposure. Histogram is available only in full screen mode. 1 Link to post Share on other sites More sharing options...
nicci78 Posted January 18, 2020 Share #14 Posted January 18, 2020 OMG M10 Monochrom with 41MP can produce lossless compressed DNG with an old Maestro II ! Why Q2 and SL2 can’t do such thing with their 47MP sensor ? Link to post Share on other sites More sharing options...
Jeff S Posted January 18, 2020 Share #15 Posted January 18, 2020 5 hours ago, mujk said: The small histogram is explained on page 85 of the manual. I didn't find information on whether it's generated from raw data or the jpg preview. From the manual: The histogram is always based on the brightness displayed; depending on the settings used, it may not represent the final exposure. In picture mode, the histogram should be regarded as a "trend indicator”. The histogram during rendering may differ slightly from the one during exposure. Histogram is available only in full screen mode. I suppose it could be similar to the MM1, when shooting RAW, whereby the initial JPEG histogram is then rendered in RAW after a short delay. But the language is unclear. I’m not sure how the M246 operates. I’ll ask Jono on his review thread. Jeff Link to post Share on other sites More sharing options...
SrMi Posted January 18, 2020 Share #16 Posted January 18, 2020 3 hours ago, nicci78 said: OMG M10 Monochrom with 41MP can produce lossless compressed DNG with an old Maestro II ! Why Q2 and SL2 can’t do such thing with their 47MP sensor ? In his review, Jono noted slow image processing and writing times on M10M. If that is caused by the compression algorithm, I would have preferred uncompressed DNGs. Link to post Share on other sites More sharing options...
stickan1 Posted January 20, 2020 Share #17 Posted January 20, 2020 (edited) How about the weather proofing? I guess it is the same as for the M10. I have a M10 now and have been very gentle with it. I had a M240 that I tested once in a rain shower and it gave me a scare as I got moisture inside the range finder window. It dried out after a couple of hours but after that I always used a plastic bag if it was raining. I think that the M10 generation is supposed to be better protected, but is it enough for landscape work in bad weather. Edited January 20, 2020 by stickan1 Link to post Share on other sites More sharing options...
Jeff S Posted January 20, 2020 Share #18 Posted January 20, 2020 (edited) M10 platform provides better protection than the M240, but is not sealed to the degree of the SL (IP52) or SL2 (IP54). M lenses also aren’t sealed as SL lenses, but close tolerances and lubricants help. Many, however, manage to use M bodies of all kinds in inclement weather, with a bit of common sense. Jeff Edited January 20, 2020 by Jeff S Link to post Share on other sites More sharing options...
Photoskeptic Posted January 21, 2020 Share #19 Posted January 21, 2020 A couple of questions, one which i asked in Jono’s thread but I’m sure he didn’t know. will there be a chrome version? who makes the sensor? One person said Sony, but is that correct? 1 Link to post Share on other sites More sharing options...
mujk Posted January 22, 2020 Share #20 Posted January 22, 2020 Seems like the White balance setting listed in the original version of the tech specs (including the PDF version) has been removed now 🙂 Link to post Share on other sites More sharing options...
