2 hours ago, TheGodParticle/Hari said:
I guess ... but how come it screws onto the 50lux v2 E43 but not onto the bc?
if you have a 13417, does it screw onto the bc?
the heliopan works on both lenses 🤯
I have not the bc but i understand that it has not the same thread pitch as the v2. Do a search on the forum we discussed about this last year if i remember well. The 13417 should not fit on the bc then. Now i do not understand how the Heliopan can work on both lenses. You did not screw it too tight hopefully.
20 hours ago, TheGodParticle/Hari said:
Quite strange.
Will take a short trip to Wetzlar after operations are resumed ...
Baffling!!
please ask them to make at least a UV and orange filter to work with the lens hood. 😂😂😂
3 hours ago, TheGodParticle/Hari said:
Will do ... this is just irritating 🤷‍♂️
Agreed although I knew it before buying so my own darn fault.
And I’m not interested in the retro fit hood solution as it’s ugly.
Agree, which is why I wanted to use the filter so I could leave the hood behind. Let’s see what solution is proposed.
Worst case scenario I’ll continue to use the heliopan filter on the bc, and the uv/ir on the v2. I do prefer the pull out hood of the 50lux asph. So much more practical. Waiting for it to come back after some magic dust is sprayed on it at the Mothership.
  • 2 months later...
13 hours ago, lmak said:
Curious if anybody has tried the new B+W 43mm T-Pro Filter with the hood. It alleges to be an even thinner filter than their XS-Pro... Maybe this would allow our infamous hoods to finally clip on?
May try this out. Thanks.
  • 2 months later...
As a reasonably priced hood to use with a filter, I recommend the Haoge LH-B43P 43mm.  I bought it for £38 from Amazon.  The build quality is excellent and it even comes with a metal cap.  The look is pretty modern and I personally like the contrast to the black chrome’s retro look.
  • 1 month later...
Hi
I have the 50 lux BC as well. And I am also one of those preferring filters for protection.
So I have as many in here, been searching for solution. But found non that I could grasp. So for the time being I have grinded down a 43mm filter from front (to become 3mm thick) flipped it around and slipped it in from front of the hood. See pictures.
And no vignetting.
I have tested a couple of filters being not more than 3mm thick from new, but those have been marginally too wide to slip into the hood.
19 minutes ago, pedaes said:
I guess I will probably end up that way. But too bad not using that very much nicer brass Leica hood.
