x
ZĂĽrich
Amsterdam
Amsterdam
  • Like 12
Wetzlar
Nearby
16 hours ago, Artin said:
My daughter dropped in with her puppy so snuck in a portrait of Blue M11 50mm Lux asph
Is it me or are these images lacking some bite? The M11 images look soft.
11 hours ago, leo10691 said:
I received my M11 at lunch time yesterday, but only was able to shoot later in the evening.
Leica M11 + 50mm Summilux Black Chrome
Great colors!
Motion blur in that one. Some of these are also not sized down and sharpened. One can't simply size down straight from 60mp to web res without sharpening or without sizing down in two steps. Sizing down in Photoshop needs be using the right option. Also note you have to click on images here – the previews inline in the posts are alway soft.
I think you are seeing a combination of:
1) more dynamic range, and
2) probably a gentler contrast tone curve than the M10. Which was quite contrasty. (And contrast and saturation are linked, inextricably).
Same thing happened when the M(240) replaced the M9 - straight from the camera*, the M(240) colors were more subdued and "Portra-like" compared to the M9's "color-slide/Kodachrome" look. Shocked some people back in 2012 tha same way.
For that matter, even with the M9 (when I check back to the default settings I set up) - I had its saturation cranked up to +15 or so. ;)
That is exactly why Leica cranked the M10's default tone curve "up to 11" - to steepen the curve and get back some of that "default M9 punch." Both in jpgs, and for users who didn't really know how to handle raw processing with sophistication.
But Leica can't win - some folks hate(d) the softer pastel default rendering of the M(240) and probably the M11 - while others hate the M10's "excessive" default saturation.
There IS a reason raw processing software has all those sliders and curves to make the contrast and saturation what the individual photographer wants. And why there are JPEG settings for contrast and saturation as well.
_______________
*the Land of the Morons. ;)
SOOC is "one size fits nobody."
  • Thanks 5
Exactly. My default sharpening for reduced "web" images is simply the PS "sharpen" filter - faded 50% ± to avoid the strongest halos.
I avoid "Bicubic Sharper" in downsizing only because there is no way to "tune it" to match specific images (some need more "fading" of the sharpening, other need less).
Edited by adan
I avoid "Bicubic Shaper" in downsizing only because there is no way to "tune it" to match specific images (some need more "fading" of the sharpening, other need less).
Bicubic Sharper – I don't think that technically adds sharpening as we think of sharpening, rather it's a different way to interpolate the image data when sizing down. I've never seen an image resized that way display any sharpening artifacts – at least when sizing down 50-100mp files (R5/GFX 100S) in a single step.
Most often I simply export from C1/LR to the final pixel size but select "Sharpen for screen", which always turns out perfect for me.
Some also don't realize this forum can now handle 2480 px on the longest side. Traditionally sizing for IG/FB has been 2048 px as optimal. Some images in this thread are sized smaller than that and will look soft enlarged to fill the screen on a high res monitor.
Never understood spending a fortune on a camera (and lenses) that can produce infinitely malleable files, and settle for someone else’s interpretation (plus a seemingly broader lack of attention to, or perhaps lack of understanding of, other potential PP actions, screen/screen setting factors, let alone neglecting all the variables and potential relating to printing and display/lighting.
Sorry… back to images.
Jeff
Edited by Jeff S
_______________
I understand that. I took at look at Ralph Gibson's photos on Leica's M11 page and am a bit more relieved.
Pushed two stops approx at base ISO. Edited in the latest version of Lightroom using the M11 profile. It's showing more colour noise than I would like. But that isn't the bigger issue here that I see, it's the rendering and lack of fine detail that seems to already indicate NR has been applied/baked into the DNG. The files as a result end up looking mushy, and more so, after NR during post
Edited by Oswalt
Where exactly is the NR applied? The whole image, the shadows? Also what is the aperture and speed used?
BTW, you can post at 2480 pixels and not 1600 if you want us to see better what you describe.
Thanks
Edited by Daedalus2000
20 minutes ago, cboy said:
I understand the highlight recovery mentioned by red dot forum is 2 stops compared to the m10r. Can anyone confirm?
Two stops vs one stop, they say, so a stop advantage, as I recall.  Or was it three vs one? But I think this should be moved out of the image thread.
Jeff
Edited by Jeff S
Ă—
Ă—
