piran Posted April 30, 2021 Share #21 Posted April 30, 2021 Advertisement (gone after registration) 4 hours ago, Cheesehead said: On a future update it would be nice if the photo/file number did not reset to zero. After updating, I loaded my saved settings back from the SD card but then had to manually bump up the photo number so that I don't have multiple photos with the same file number. Also still no way to put a Name, or copyright statement in the Exif file. I appreciate the update and will have to dive into the changes. My OLDER Canons had that problem. If I manually stored the last exposure back to the SD card (or CF or MicroDrive) the OS would very agreeably bump up the next new exposure taken to follow suit. Sadly my NEWER Leica is not so agreeable (tut tut). Derived a half-way house workaround. Put the last DNG exposure back onto the SD taking care to replicate its original DCIM directory (eg 101LEICA). Put the SD back in and find the zone 4 menu line 'Reset Image Numbering' > YES. This took the OS to the NEXT DCIM, so mine is now on 102LEICA, but at least I won't have duplicate or worse lower numbers out of sync. Another omission from the (un)helpful PDF... Link to post Share on other sites More sharing options...
Advertisement Posted April 30, 2021 Posted April 30, 2021 Hi piran, Take a look here Firmware-Update: Leica Q2 & Q2 Monochrome . I'm sure you'll find what you were looking for!
tnturnerx1 Posted May 1, 2021 Share #22 Posted May 1, 2021 I'm confused. First, on the Leica website it says "Firmware Leica Q (Typ 116)" not Q2, though instructions say Q2. Second, I downloaded two files: Q116_31_.quf and EN_Q2_Gen+FW-UPD+[PixMap+Touch-AF]+Release+Notes.pdf. I'm not sure which contains the update. Since a pdf doesn't sound or look like update code, I just put the quf file on the card and followed instructions. Message I saw was no firmware update was found on SD card. Then, I put the pdf file on, same response. ??? Link to post Share on other sites More sharing options...
piran Posted May 1, 2021 Share #23 Posted May 1, 2021 @tnturnerx1 Please take great(er) care... If you actually manage to succeed in your attempts to burn the wrong firmware into the wrong camera you are very likely to DESTROY your unspecified Leica camera. I don't even want to know exactly which camera you are trying update. It's your responsibility not mine, I just implore you to step back and re-evaluate your position. You appear to be in the wrong frame of mind to be attempting this procedure on whatever Leica camera in your possession. >>I'm confused. First, on the Leica website it says "Firmware Leica Q (Typ 116)" not Q2, though instructions say Q2. You're not only confused but mistaken too. The Q is Typ 116, I also have one. I have no idea as to what instructions you are looking that say to Q2. You must get it correct. >>Second, I downloaded two files: Q116_31_.quf and EN_Q2_Gen+FW-UPD+[PixMap+Touch-AF]+Release+Notes.pdf. Two files are usually made available - a quf and pdf. That Q116_31_.quf file is for the Q, I know because I have one and 31 is the last stable release issued. It would imply you are browsing the wrong area (unless you really are looking to update a Q). The other one you cite looks like it might be a helper PDF for a Q2... but I don't have a Q2 and will not comment further. The two do not fit together. Maybe you should clear your browser cache. What you are citing does not make entire sense. >>I'm not sure which contains the update. Since a pdf doesn't sound or look like update code, I just put the quf file on the card and followed instructions. Message I saw was no firmware update was found on SD card. The f/w update is contained in a quf file. Help is contained in a pdf file. To update the firmware you do put the correct quf file on the SD card and follow instructions. The message was probably correct in that it found no APPROPRIATE update file on the SD card (probably for the wrong camera etc). Basic checking is necessarily done to try to stop you destroying your Leica. >>Then, I put the pdf file on, same response. Please do not guess which file to use - updating firmware inappropriately can destroy your Leica. Clear your browser cache. Go back to this thread's original post. Choose the route URL according to whatever camera you have and follow instructions. I cannot advise anything further. Link to post Share on other sites More sharing options...
SrMi Posted May 1, 2021 Share #24 Posted May 1, 2021 2 hours ago, tnturnerx1 said: I'm confused. First, on the Leica website it says "Firmware Leica Q (Typ 116)" not Q2, though instructions say Q2. Second, I downloaded two files: Q116_31_.quf and EN_Q2_Gen+FW-UPD+[PixMap+Touch-AF]+Release+Notes.pdf. I'm not sure which contains the update. Since a pdf doesn't sound or look like update code, I just put the quf file on the card and followed instructions. Message I saw was no firmware update was found on SD card. Then, I put the pdf file on, same response. ??? Clicking on this link will (currently) download Q2 firmware 3.1: https://en.leica-camera.com/content/download/205103/5445293/version/1/file/Q2___31_.lfu Clicking on this link will (currently) download Q2 and Q2M firmware update instructions: https://en.leica-camera.com/content/download/205169/5445926/version/2/file/EN_Q2_Gen+FW-UPD+[PixMap%2BTouch-AF]+Release+Notes.pdf Link to post Share on other sites More sharing options...
brickftl Posted May 1, 2021 Share #25 Posted May 1, 2021 I'm having a problem I've never had before when updating the firmware. I downloaded the Q2 update file but the camera says file not found when I go to update. I even tried downloading directly to my SD card instead of downloading to my laptop and then copying to the SD card, and still the camera says it's not recognized. I wonder if Edge is doing something to the download. Link to post Share on other sites More sharing options...
iRandom Posted May 1, 2021 Share #26 Posted May 1, 2021 I too had a weird experience. If you click on the Downloads navigation link on the Q2 page it takes you to a page that has download buttons for all the Q2 FW update documentation as well as all the Q2 documentation and brochures. The FW download button at the top of the list is actually for 'FIRMWARE LEICA Q (TYP 116) - VERS. 3.1' and gives you Q116_31_.quf. Clicking the Firmware navigation link (instead of Downloads) takes you to the correct page with Q2 FW (which is actually at the bottom of the document list). 1 Link to post Share on other sites More sharing options...
brickftl Posted May 1, 2021 Share #27 Posted May 1, 2021 Advertisement (gone after registration) 9 minutes ago, brickftl said: I'm having a problem I've never had before when updating the firmware. I downloaded the Q2 update file but the camera says file not found when I go to update. I even tried downloading directly to my SD card instead of downloading to my laptop and then copying to the SD card, and still the camera says it's not recognized. I wonder if Edge is doing something to the download. okay now it worked AFTER I installed Chrome and downloaded from it instead of Edge. Go figure. Link to post Share on other sites More sharing options...
fumigatus Posted May 1, 2021 Share #28 Posted May 1, 2021 I didnt have any problems. Downloaded to desktop on my Mac (Safari) dragged to the SD card, and no probl updating the camera. Maybe differences with the browsers? Link to post Share on other sites More sharing options...
Mickysixty Posted May 1, 2021 Share #29 Posted May 1, 2021 Used this link for Q2 https://uk.leica-camera.com/Photography/Leica-Q/Leica-Q2/Firmware?utm_source=CRM&utm_medium=email&utm_campaign=7011i0000005bZQAAY&utm_term=https%3a%2f%2fuk.leica-camera.com%2fPhotography%2fLeica-Q%2fLeica-Q2%2fFirmware. No issues using IPad and then coping to SD card. Link to post Share on other sites More sharing options...
M11 for me Posted May 1, 2021 Share #30 Posted May 1, 2021 vor 10 Minuten schrieb Mickysixty: Used this link for Q2 https://uk.leica-camera.com/Photography/Leica-Q/Leica-Q2/Firmware?utm_source=CRM&utm_medium=email&utm_campaign=7011i0000005bZQAAY&utm_term=https%3a%2f%2fuk.leica-camera.com%2fPhotography%2fLeica-Q%2fLeica-Q2%2fFirmware. No issues using IPad and then coping to SD card. Well, this is the link from post #1. Do you want to restart the thread 🤣 Link to post Share on other sites More sharing options...
tnturnerx1 Posted May 1, 2021 Share #31 Posted May 1, 2021 Regarding my previous comment about having a problem updating. I went to sleep and woke up with the answer. I should've seen it when I saw ref to "3.1". Implies there was a version 3, which I missed. I DID notice the ".1" but most software is cumulative, and 3.1 (my thought) would have also contained changes for 3.0. Firmware, rightfully so, doesn't do this. I downloaded 3.0, updated, then did 3.1. All Ok. Thanks for responses. Link to post Share on other sites More sharing options...
Giguchan Posted May 18, 2021 Share #32 Posted May 18, 2021 Hey all, Has anybody used the "Red dot Forum" as a source for the updates? I am curious if there's any difference between them and the Leica website. I think it will be the same. I did my update using the RDF forum instead of the Leica site.I wasn't paying attention.. it was successful anyhow. Link to post Share on other sites More sharing options...
M11 for me Posted May 18, 2021 Share #33 Posted May 18, 2021 vor 3 Stunden schrieb Giguchan: Hey all, Has anybody used the "Red dot Forum" as a source for the updates? I am curious if there's any difference between them and the Leica website. I think it will be the same. I did my update using the RDF forum instead of the Leica site.I wasn't paying attention.. it was successful anyhow. Why should that be different? Why do you not diwnload from official Leica site? Link to post Share on other sites More sharing options...
Giguchan Posted May 19, 2021 Share #34 Posted May 19, 2021 No Particular reason.. I was just curious if everything was the same. Next update i will be sure to get from the Leica site. Link to post Share on other sites More sharing options...
Paul2660 Posted May 19, 2021 Share #35 Posted May 19, 2021 Surprising that Leica does not make the firmware updates cumulative. That’s pretty much standard in any product with firmware updates. Good to know that you have to upgrade in manual steps. Paul Link to post Share on other sites More sharing options...
