P1505 Posted December 28, 2020 Share #261 Posted December 28, 2020 Advertisement (gone after registration) Q body, L Mount, weather sealed, proper shutter sound, minimal buttons, no video, all buttons 100% customisable. Insta buy. Link to post Share on other sites More sharing options...
Advertisement Posted December 28, 2020 Posted December 28, 2020 Hi P1505, Take a look here Hoping that CL2 = mini SL2 . I'm sure you'll find what you were looking for!
cirke Posted December 28, 2020 Share #262 Posted December 28, 2020 Actual play button is useless for me , I never use it Link to post Share on other sites More sharing options...
nicci78 Posted December 28, 2020 Author Share #263 Posted December 28, 2020 (edited) I think that they should use Q2 body It is slightly taller than CL one. But hopefully it should be big enough to house : IBIS + mechanical shutter + 26MP APS-C sensor + L-mount + BP-SCL4 battery + weather sealing + 3.6M dots EVF. I also hope that Leica will also release a kind of Pro TL lens alongside. Something like a TL 16-70mm f/2.8 weathersealed should be great. Edited December 28, 2020 by nicci78 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted December 28, 2020 Share #264 Posted December 28, 2020 I hate to say it but that Leicarumors post looks more like speculation based on an amalgamated wishlist from this thread, rather than an informed rumour. As to size: no higher, no wider, no heavier AFAIC. This is Leica's original Barnack in modern form, not a cut down M or Q. I would accept a slightly fatter body if it permitted IBIS, because it makes little difference in the hand or occupying bag space. 1 Link to post Share on other sites More sharing options...
lct Posted December 28, 2020 Share #265 Posted December 28, 2020 A bigger camera? Thanks no thanks. 2 Link to post Share on other sites More sharing options...
Chaemono Posted December 28, 2020 Share #266 Posted December 28, 2020 vor 1 Stunde schrieb nicci78: I think that they should use Q2 body ... They will have to. The question is, does the camera then still appeal to those who like the CL among other things for its size. Link to post Share on other sites More sharing options...
AdHox Posted December 28, 2020 Share #267 Posted December 28, 2020 Advertisement (gone after registration) 2 hours ago, Chaemono said: They will have to. The question is, does the camera then still appeal to those who like the CL among other things for its size. If I want a full frame sized body, then I'll use my FF system. If i want a smaller camera I'll use my CL. If the CL2 is chunky as my FF, then it's pointless for my needs. On the positive side, I read somewhere that cameras will continue to operate exactly as they have previously even after a new version has been released. This gives me confidence that the shame of obsolescence won't cause my CL to brick itself and we can continue to enjoy each other's company. 3 3 Link to post Share on other sites More sharing options...
jaapv Posted December 28, 2020 Share #268 Posted December 28, 2020 They cannot. The Q2 body is built around an integrated - thus compact- lens-sensor unit. A totally different design principle than an exchangeable lens camera. 5 hours ago, nicci78 said: I think that they should use Q2 body 1 2 Link to post Share on other sites More sharing options...
lct Posted December 28, 2020 Share #269 Posted December 28, 2020 The Q2 is an FF camera. Not sure why it should inspire the CL2 in any way. 5 1 Link to post Share on other sites More sharing options...
DirkS Posted December 28, 2020 Share #270 Posted December 28, 2020 26 MPix is not a big devellopment, but the other specs are so good, that I`d probably buy it. With 36 MPix I absolutly sure would buy it. 1 Link to post Share on other sites More sharing options...
vikasmg Posted December 28, 2020 Share #271 Posted December 28, 2020 On 7/24/2020 at 1:35 AM, nicci78 said: Dear Leica, please make us a mini SL2 with IBIS & weather sealing. Still with APS-C sensor within the CL body. From what I see on Leica Rumours, it looks like you’re about to get your wishes. 1 Link to post Share on other sites More sharing options...
Le Chef Posted December 28, 2020 Share #272 Posted December 28, 2020 10 hours ago, Chaemono said: They will have to. The question is, does the camera then still appeal to those who like the CL among other things for its size. Why? Link to post Share on other sites More sharing options...
Gregm61 Posted December 28, 2020 Share #273 Posted December 28, 2020 No doubt it’ll be as small as they can make it and include whatever it is they actually do include. I can’t see me not buying one. Link to post Share on other sites More sharing options...
nicci78 Posted December 29, 2020 Author Share #274 Posted December 29, 2020 (edited) 15 hours ago, lct said: The Q2 is an FF camera. Not sure why it should inspire the CL2 in any way. Because Leica is already using a modified Q body for the CL. Except top case, which is different : shorter than Q one. You can even use Q handgrip on CL. It’s handle is just slightly too tall, by hitting strap lug. Otherwise it is fine. So the idea is now to keep the same body, including the same height as Q2. For storing the extra electronics. Edited December 29, 2020 by nicci78 Link to post Share on other sites More sharing options...
nicci78 Posted December 29, 2020 Author Share #275 Posted December 29, 2020 Actually Leica has two means to achieve economy of scale : - using a modified Q2 body. Just like CL is a shorter version of Q. - using a modified SL2 body. Way shorter, no grip. SL2 slightly thicker body should be enough to house IBIS and BP-SCL4 battery. Modifying Q2 body should be easier. But not sure if it can house a bigger battery, IBIS and a shutter mechanism. Even in APS-C size. Link to post Share on other sites More sharing options...
LocalHero1953 Posted December 29, 2020 Share #276 Posted December 29, 2020 Leica is using a modified Q body for the SL just as it is using a modified M3 body for the Q. And that is just a modified Leica i. It's a statement of the obvious with no other implications for the future design and size of the CL2. Link to post Share on other sites More sharing options...
nicci78 Posted December 29, 2020 Author Share #277 Posted December 29, 2020 Of course, we don’t know how the CL2 will be. But we can still try go guess it. For the CL, Leica was ready to use more than 50% of Q body : same belt (same width, same thickness, same rounding), same battery door, same battery, same screen, same D-Pad, etc... They just make the CL shorter with another top case. Then switch full frame sensor with APS-C one and shutter mechanism. And add a proper lens mount. So how CL2 will be ? Still based on Q2 ? Or going to another direction ? Link to post Share on other sites More sharing options...
jaapv Posted December 29, 2020 Share #278 Posted December 29, 2020 Yes, or they just modernized the design of the Leica Standard. Of course a manufacturer will attempt to share as many parts as possible with other models - that is production efficiency = cost reduction. The real difference is on the inside, and there you will find many more shared parts, with X series, Q series, even SL and M - many of them branded Panasonic - there are experts who called the Q "just a Panasonic in a Leica skin". Link to post Share on other sites More sharing options...
lct Posted December 29, 2020 Share #279 Posted December 29, 2020 (edited) . Edited December 29, 2020 by lct Link to post Share on other sites More sharing options...
lct Posted December 29, 2020 Share #280 Posted December 29, 2020 . Link to post Share on other sites More sharing options...
