  • 2 weeks later...
M2+Visoflex 3+ 65mm Elmar.
50th at f16 on Ilford Pan F in Moersch Tanol, scanned from darkroom prints.
M8, Visoflex III, Telyt-V 6.8/400mm
Don't remember well,
maybe with Apo-Telyt-R 3.4/180 (without Visoflex)
or more probably M8 and Telyt-V 6.8/400 with Visoflex III
  • 3 weeks later...
≈ tilt limit with E. Leitz Tele-Elmar 135mm ...
( on Flickr )
Number cruncher
The 8080 can be regarded as the first of the early 8-bit fully functional microprocessors and was introduced by Intel in 1974.
Here is a slightly different field of values for the calculation logic.
Z80  microcomputer board with  SARGON - A COMPUTER CHESS PROGRAM by DAN AND KATHE SPRACKLEN ( Winner - 1978 West Coast Computer Faire!)
Integrated circuits,  lenshead  E. Leitz Tele-Elmar 1:4 / 135mm and tilt-/shift-bellows with M-mount  from the ≈ same age of manufacturing!
Here you can find a side remark about the chess program SARGON and further photos. ( www. ..  &  Flickr)
Thorsten
  • 2 months later...
Monochrom, 1/3 000 at 1 600 ISO
Visoflex III, Telyt-V 6.8/560
  • 1 month later...
Leica Standard+Visoflex1+extension tube+lenshead off 1949 135mm f4.5 Hektor.
3 seconds at f16 on HP5 in Rodinal, scanned from darkroom print. (Watermark on the right is from condensation under the glass on the scanner, not sure how to get to it to clean it).
  • 4 weeks later...
Testing camera as a scanner. TL + Bellows II + Tele Elmar gives full frame 24 x 36 repro.
TL + Bellows II + Tele Elmar 135mm
In hindsight, a computer screen is not the most perfect light source, so maybe better in B&W.
  • 1 month later...
I received my Visoflex III this morning - mounted on my M9 and rushed into the garden.
Here is my fist attempt - at the bottom of the learning curve - feedback welcome.
Looks very nice! Which lens or lens head did you use on the Visoflex?
Lex
Have a Visoflex question, I bought a 400 f5.6, and a Viso 2 because I didn't know infinity is variable on a Televit. I use the lens mostly with my CL, but just started to work with it on my M3, interesting. Then I tried to fit it on my M8 and I couldn't get the eyepiece on. I noticed a lot of digital Ms in this thread, is this an M8 variation or does the Viso3 work with the digital Ms while the Viso 2 can't?
Hooded Merganser, CL 400 f5.6 Telyt
Lex
Thanks Lex.
The shot was taken with a Canon LTM 135mm f3.5.
The two shots below were taken with the Leica Tele-Elmarit M 90mm mounted on the Visoflex
M Leicas including the M6TTL and later (and maybe the M5) were all slightly taller that the earlier M cameras. This required a revision of the visoflexes – the upshot being that the Visoflex II doe not fit onto an M6TTL or later camera. The Visoflex III does fit. Mainly, for purposes of this conversation, the prism is different.
This is all too bad since the prism on the Visoflex II is nicer – the eye piece is adjustable, whereas the Visoflex III prism requires eye piece correction lenses (which are very difficult to find, and then worse to determine which one you need).
FWIW, the Visoflex III works on all M cameras.
  • 4 months later...
Underdown Farm
Leica 111c + Viso 11
4/200mm Telyt  Ilford FP4 125
Tulips
M3, Viso II, 400 f5.6 Telyt
Ducks in a Row
CL, 400 f5.6 Telyt
  • 1 year later...
M240 with Visoflex I and Schneider Componon 2,8/50mm
Ballpoint / Kugelschreiber  M240, Visoflex I, Componon 2,8/50mm
  • Thanks 2
