x
Please, What does this mean for my M 240 (from the upgrade description)
 It is now possible to display DNG files from the Leica M Monochrom (Typ 246) in all zoom
steps, also with the M/M-P (Typ 240 and 262)?
M-P240 -- FW Update -> Here we go  -- fingers crossed -- Done & Dusted  :)
Manoleica - this is my first firmware upgrade and I have the M240 P too, so I assume I need this file, not the "straight" 240 one?
FIRMWARE (2.0.3.0) LEICA M-P (TYP 240)
Thanks
Thought I should mention that someone in our Facebook group did this update and now has black and red stripe in his shots. He's not very happy about it either, which is understandable.  Anyone else have an issue? I may just wait.
Just did the update on the MM246, all is fine.
John
Am I doing this right ?  I've downloaded the firmware onto my formatted SD card (top menu) and then inserted into my M.  Pressed the info button at same time as turning on M.  But nothing happens !
Edit: forget that, its working now...flat battery
Edited by Kaneda
Firmware is icumen in! Lhude sing cuckoo!
But no mention of the time setting no longer being saved to the user profiles? :-(
No. They did not fix that one.
Excellent - for information, as the update wipes your preferences it can be convenient to export these to SD card and keep this card to one side (or copy to a computer).  You can then go ahead and follow the firmware update instructions. Once installed, you can import your settings and get back to where you were before the update. I've just done this myself and it works...
Hope this saves a few people a bit of time and frustration.
Great, but how does one export the settings?
Hello members!
Need HELP!
I tried to update my M-P  M240 and messed up something....after SD format on my Leica I could not install update "M240 2030.FW"
my Mac cannot open application, scrolling in to SD card doesn't do anything....message is that card doesn't have any files.
now I have empty SD card and I am with out any info .....
thanks
ETOR
