Popular Post LUF Admin Posted April 29, 2016 Popular Post Share #1 Posted April 29, 2016 (edited) Advertisement (gone after registration) Just received the press release from Leica: Finally the new firmware for Leica M240 / M262 / Monochrom 246! First things first: The annoying message (“check battery age”) is gone Leica M (Typ 240) FW 2.0.3.0https://en.leica-camera.com/Service-Support/Support/Downloads?category=&subcategory=93711&type=108942&language=68389 Leica M (Typ 262) FW 1.0.0.6https://en.leica-camera.com/Service-Support/Support/Downloads?category=&subcategory=129115&type=108942&language=68389Leica M Monochrom (Typ 246) FW 1.0.1.0https://en.leica-camera.com/Service-Support/Support/Downloads?category=&subcategory=124179&type=108942&language=68389Important: Don't forget to save your profiles before you update!Performance Improvements:• Implemented optimizations that prevent the camera controls from becoming unresponsive after a series of continuous burst photos fills the buffer.• The selected user profile will be displayed even when exposure compensation has been adjusted. Exposure compensation is no longer saved to the user profile.• Memory cards with a capacity up to 512 GB are supported• The default file format settings upon camera reset have been changed from „JPG“ to „DNG+JPG“• The time-out period for the last GPS Position, when no GPS signal is received, has been extended to 2.5 hours (GPS is not available with M (Typ 262))• It is now possible to display DNG files from the Leica M Monochrom (Typ 246) in all zoom steps, also with the M/M-P (Typ 240 and 262)• When using SD-cards that are too slow for movie recording, a message appears in the viewfinder display Bug Fixes:• Bugs, that led to a camera freeze when shooting fast sequences, have been fixed• The accuracy of the internal clock has been improved• When using „AUTO ISO in M mode“ the used exposure metering mode is now being displayed in play mode• Files larger than 2GB can now be transferred from the camera to the PC via USB• The display of the histogram has been optimized for high ISO values• The display of flash exposure compensation values has been improved in the menu• A misleading message (“check battery age”) has been removed• In case of Leica M Monochrom (Typ 246): A bug that led to black pixels in fine pattern has been fixed• Further system optimizations have been implemented Edited April 29, 2016 by LUF Admin Corrected links / Added Warning 27 Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 29, 2016 Posted April 29, 2016 Hi LUF Admin, Take a look here Firmware-Update Leica M240 / M262 / Monochrom 246. I'm sure you'll find what you were looking for!
dbane883 Posted April 29, 2016 Share #2 Posted April 29, 2016 Great. Thanks for the heads up 1 Quote Link to post Share on other sites More sharing options...
lct Posted April 29, 2016 Share #3 Posted April 29, 2016 Thank you Andreas. Folks, don't forget to save your profiles before the firmware update. 3 Quote Link to post Share on other sites More sharing options...
wlaidlaw Posted April 29, 2016 Share #4 Posted April 29, 2016 Andreas, Many thanks for the "heads up" on that. At last after more than two years and many emails from me to Leica chasing this up, the GPS mistake has been corrected. I have to admit to using the SL so much recently, that I barely noticed the "battery out of date" message. Wilson 1 Quote Link to post Share on other sites More sharing options...
kkcsm Posted April 29, 2016 Share #5 Posted April 29, 2016 I'm curious about the "bug that led to black pixels in fine pattern". Is this referring to the banding that can occur when lifting shadows? 1 Quote Link to post Share on other sites More sharing options...
matlep Posted April 29, 2016 Share #6 Posted April 29, 2016 Great! Was not expecting this Good work Leica! Quote Link to post Share on other sites More sharing options...
chris_tribble Posted April 29, 2016 Share #7 Posted April 29, 2016 (edited) Advertisement (gone after registration) Excellent - for information, as the update wipes your preferences it can be convenient to export these to SD card and keep this card to one side (or copy to a computer). You can then go ahead and follow the firmware update instructions. Once installed, you can import your settings and get back to where you were before the update. I've just done this myself and it works... Hope this saves a few people a bit of time and frustration. Edited April 29, 2016 by chris_tribble 3 Quote Link to post Share on other sites More sharing options...
jrh68uk Posted April 29, 2016 Share #8 Posted April 29, 2016 First thing I checked after installing this was whether they'd fixed the info display bug I reported to them some time ago. It's still there, unfortunately. I think that's two releases of firmware since I reported it. Quote Link to post Share on other sites More sharing options...
ghoonk Posted April 29, 2016 Share #9 Posted April 29, 2016 Installed. Will be monitoring performance and issues. I have a trip coming up and will be depending on my Ms for the job. Quote Link to post Share on other sites More sharing options...
mirekti Posted April 29, 2016 Share #10 Posted April 29, 2016 I skipped the previous update. Can I go directly to this one? There is no mention of this requirement in the installation guide. Quote Link to post Share on other sites More sharing options...
pop Posted April 29, 2016 Share #11 Posted April 29, 2016 I skipped the previous update. Can I go directly to this one? There is no mention of this requirement in the installation guide. Yes, you can; at least, you always could so far, and if they don't say otherwise, I see no reason to assume otherwise. 1 Quote Link to post Share on other sites More sharing options...
Rick Posted April 29, 2016 Share #12 Posted April 29, 2016 Thank you crazy uncle Kaufmann! I'll try it out when on vacation in the Southwest... with my new 28 Summicron II. Rick 1 Quote Link to post Share on other sites More sharing options...
lct Posted April 29, 2016 Share #13 Posted April 29, 2016 [...] .. with my new 28 Summicron II. Stop feeding the GAS please. 4 Quote Link to post Share on other sites More sharing options...
samwells Posted April 29, 2016 Share #14 Posted April 29, 2016 Great…it works. Tho there seemed to be a lot of chess players taking over during the update process, which was rather worrying... Quote Link to post Share on other sites More sharing options...
helged Posted April 29, 2016 Share #15 Posted April 29, 2016 Thank you crazy uncle Kaufmann! I'll try it out when on vacation in the Southwest... with my new 28 Summicron II. Rick ...and please report back about corner sharpness and, if any, miscolouring towards the edges/corners. Particularly the latter. Have fun shooting! 1 Quote Link to post Share on other sites More sharing options...
menos I M6 Posted April 29, 2016 Share #16 Posted April 29, 2016 Any changes to start-up / wake up times? Is the EV display still taking the viewfinder hostage, when EV is set? Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted April 29, 2016 Share #17 Posted April 29, 2016 My M240 takes the same time from switch on to first shot: just under 2 secs. I haven't looked at wake-up times. 1 Quote Link to post Share on other sites More sharing options...
majortom Posted April 29, 2016 Share #18 Posted April 29, 2016 Thanx a lot! Quote Link to post Share on other sites More sharing options...
ho_co Posted April 29, 2016 Share #19 Posted April 29, 2016 Firmware is icumen in! Lhude sing cuckoo! But no mention of the time setting no longer being saved to the user profiles? :-( Quote Link to post Share on other sites More sharing options...
Jon Warwick Posted April 29, 2016 Share #20 Posted April 29, 2016 Could be a daft question, but I've never updated my M240 since I got it in early '14. If I update it with today's new firmware, does it add in the other firmware update(s) I've skipped? The update where LV has the inbuilt horizon level could be very useful indeed (and my horizon level is still on a black screen!)! Quote Link to post Share on other sites More sharing options...
