Leica Q -general-
x
  • Replies 447
  • Created
  • Last Reply
I believe the photo and specs are real, but we will know for sure in a week from now. Looks nice, but how practical is a fixed 28mm lens? I am sure that Leica has checked out consumer preferences very thoroughly, but I would not buy a camera with a fixed 28mm. I use a 35mm far more often than the 28.
250swb, on 25 June 2015 - 20:56, said:
It is, or will be, a full frame fixed lens camera based on the available technology from the parts bin. The interesting thing will be that like the offspring of the X series, the T, will this evolve into an interchangable lens camera in the future? In which case that is where the Leica evolution, slow as it is, truly gets stood on its head.
Steve
Yes Steve, that would be very interesting.
Not exciting at all
I wonder if it is not the right time to sell all my Leica gear
I don't trust that company anymore
Well, at least it is better than an MP 70 years Korean Independence model.
If genuine, the big remaining question.......is the EVF built-in? (Is that a viewfinder eyecup just visible on the left-hand edge of the body/right-hand side of the image?).
Although all the hype suggests it has a built in EVF, I say it doesn't
It looks too much like the 113 design and I think Leica is quite happy with the add on EVF for its X and T cameras at the moment
I also have to assume that the EVF is indeed build-in.
1. You can see the ring on the right side of the camera. What else then an EVF this could be?
2. If Leica would add the EVF from the T series it would have GPS, and this would have certainly been mentioned in the specs.
3. The stated resolution of the ?build-in? evf is around 3.7 million dots. If I remember well the resolution of the external is higher
So 3 arguments that go for the build-in!
John
Looks odd:
it seems to have to rings, out of which the one close to the camera has a some labels - for focusing.
There are grips close to the lens mount that suggest that aperture is set there.
What's the third ring (all the way to the front) for? Cannot be aperture as there are no labels.
The picture certainly suggests a built in viewfinder that can be seen at the top right - looks like the rubber on an M rangefinder.
strap lugs with no protective piece of plastic above it - that's the first time Leica does this
lens looks like it will extend - yuck
we'll in a couple of days
Silly question: if the lens is fixed to the body, why has it the focal lenght written on the tube right next to the camera body where M lenses show their focal lenghts, too?
When you really look close, you see a knurled part on the right side of the tube, nearest to the body, on which a normal lens can be attached. It is highly unlikely, but is it a T-lens (FF) on a Q-body. Or is this just wishful thinking?
Can also be a preliminary model?
Because it looks awesome!
I think the knurled part looks like the aperture ring, its not flush against the body, there is another ring of metal behind that. All very nice.
28mm is great for the iPhone generation, group shots and so on. But basically you can crop from 28 to 35 (and 50) but not from 35 to 28. And it would also not put the camera directly in competition with the X (Typ 113).
Built-in seemingly.
