01af Posted June 15, 2011 Share #81 Posted June 15, 2011 Advertisement (gone after registration) But were the f/2.8 and f/4 versions? The latest firmware has codes for all three! So have the previous versions. Anyone else notice that there is a coding profile for the Apo-Telyt-M 135 mm lens in the new firmware? There always used to be an entry for the Apo-Telyt-M 135 mm in the lens menu. The new thing, however, is this: They assigned a new code point to this lens (53-2), so now it can actually get 6-bit-coded ... that wasn't possible with the previous code point (9-0). Link to post Share on other sites More sharing options...
Advertisement Posted June 15, 2011 Posted June 15, 2011 Hi 01af, Take a look here The old 1.162 firmware (changed title) . I'm sure you'll find what you were looking for!
Åmund Posted June 15, 2011 Share #82 Posted June 15, 2011 I love the liveview option !!! This is irony, right? Or have I missed something in the menu. If so, where do I find the live-view option? BTW, the upgrading went well for me, but when I put the card back into the camera it asked (as it did on the last upgrade) if I wanted to upgrade to version 1.001. I felt brave and answered "yes" and when I checked it was the correct version. Regards Åmund Link to post Share on other sites More sharing options...
Double Negative Posted June 15, 2011 Share #83 Posted June 15, 2011 So have the previous versions. There always used to be an entry for the Apo-Telyt-M 135 mm in the lens menu. The new thing, however, is this: They assigned a new code point to this lens (53-2), so now it can actually get 6-bit-coded ... that wasn't possible with the previous code point (9-0). Ahh, okay - thanks for clearing that up. I never bothered to check for a code let alone set one for the 4/135 I picked up a few weeks ago. Link to post Share on other sites More sharing options...
Rick Posted June 15, 2011 Share #84 Posted June 15, 2011 This is irony, right? Or have I missed something in the menu. If so, where do I find the live-view option? Regards Åmund Actually, it was sarcasm. Link to post Share on other sites More sharing options...
UliWer Posted June 15, 2011 Share #85 Posted June 15, 2011 Actually, it was sarcasm. This time it worked. For further upgrades of firmware it was always autofocus - and nobody took it for serious. Link to post Share on other sites More sharing options...
sydkugelmass Posted June 15, 2011 Share #86 Posted June 15, 2011 It seems that issues with SanDisk 8Gb speed level 6 has been solved. M9OS stable now. No more hanging up on play/zoom/pan operation during save operations (DNG UNcompressed). Too early... Hang up problem with SanDisk 8Gb speed 4 (four, not six as I wrote) card seems less frequent but is always there... Link to post Share on other sites More sharing options...
sblitz Posted June 15, 2011 Share #87 Posted June 15, 2011 Advertisement (gone after registration) Updated no problems been out shooting and so far so better. Dealers in my steer me away from Sandisk and I have listened. Btw should coding change now for zeiss lens. Biogon 21 f 2.8? Using 21 pre asph as before Link to post Share on other sites More sharing options...
1JB Posted June 15, 2011 Share #88 Posted June 15, 2011 Okay so the "top level" and root directory is the one called DCIM? Link to post Share on other sites More sharing options...
Åmund Posted June 15, 2011 Share #89 Posted June 15, 2011 Actually, it was sarcasm. Good one, and the laugh´s on me. I have often wondered what the difference between irony and sarcasm is, and I´m still not sure. Regards Åmund. Link to post Share on other sites More sharing options...
1JB Posted June 15, 2011 Share #90 Posted June 15, 2011 Okay so the "top level" and root directory is the one called DCIM? I got it. Same level as the DCIM not in the DCIM. Update successful. Link to post Share on other sites More sharing options...
delander † Posted June 15, 2011 Share #91 Posted June 15, 2011 Okay so the "top level" and root directory is the one called DCIM? No! it is the one above, the card itself. Best to format the card in a computer before you put the FW update file on it. Jeff Link to post Share on other sites More sharing options...
250swb Posted June 15, 2011 Share #92 Posted June 15, 2011 Okay so the "top level" and root directory is the one called DCIM? No, that is a folder already on your card. You want to just highlight the SD card itself on your PC and save it to that, not a folder. Link to post Share on other sites More sharing options...
M. Valdemar Posted June 15, 2011 Share #93 Posted June 15, 2011 Okay so the "top level" and root directory is the one called DCIM? DCIM is a FOLDER. Don't put the firmware file in there Do this. Erase everything on the SD card. Then put the unzipped firmware file on the SD card. If you don't understand files and directories this makes it fool proof. Link to post Share on other sites More sharing options...
markgay Posted June 15, 2011 Share #94 Posted June 15, 2011 Anyone with experience of how these changes affect the Zeiss 15mm f/2.8 for better or for worse? Link to post Share on other sites More sharing options...
loman Posted June 15, 2011 Share #95 Posted June 15, 2011 I don't have luck with 21/3.4 so far. It improves a little bit, and is more easy to get it fixed in Lr. Have I done something wrong ? 21/3.4 @f3.4 iso400 Link to post Share on other sites More sharing options...
ArtZ Posted June 15, 2011 Share #96 Posted June 15, 2011 I don't have luck with 21/3.4 so far. It improves a little bit, and is more easy to get it fixed in Lr. Have I done something wrong ? 21/3.4 @f3.4 iso400 Argggg! I have reserved a M9-P but after seeing this picture, I'll keep my two M8 until a real FF rangefinder breaks into the market. M9 is not a serious camera if you cannot use wide angle lenses on it. Sorry guys. Come on, Leica! Link to post Share on other sites More sharing options...
Olsen Posted June 15, 2011 Share #97 Posted June 15, 2011 Loman, How did you code the 21 mm 3,4? Try code it manually with the WATE alternative. Link to post Share on other sites More sharing options...
Overgaard Posted June 15, 2011 Share #98 Posted June 15, 2011 Argggg! I have reserved a M9-P but after seeing this picture, I'll keep my two M8 until a real FF rangefinder breaks into the market. M9 is not a serious camera if you cannot use wide angle lenses on it. Sorry guys. Come on, Leica! The current old 21/3.4 is special in that it goes so way back in the camera body that it covers the light meter. I would b surprised if they could fix anything in the firmware for that lens. Link to post Share on other sites More sharing options...
MaxJ1961 Posted June 15, 2011 Share #99 Posted June 15, 2011 I upgraded this morning and did NOT lose my settings. Link to post Share on other sites More sharing options...
jaapv Posted June 15, 2011 Share #100 Posted June 15, 2011 Argggg! I have reserved a M9-P but after seeing this picture, I'll keep my two M8 until a real FF rangefinder breaks into the market. M9 is not a serious camera if you cannot use wide angle lenses on it. Sorry guys. Come on, Leica! It does as badly on the M8... Come on, this is one of three lenses out of hundreds going back eighty years that has a problem on a camera that is more than half a century its junior. Like complaining you cannot fit carbide lights on your 2011 Mercedes:rolleyes: Link to post Share on other sites More sharing options...
