1 hour ago, 3D-Kraft.com said:
I do not consider it impossible to integrate an AF mechanism into an M-body in the next iteration.
How would this be compatible with the register distance of an M-body? Just curious.
vor 39 Minuten schrieb lct:
The current Techart Pro adapter can move the lens about 4.5mm, which is enough for lenses up to 50mm focal length (longer focal lengths would need some prefocusing).
There would be two options:
  • You could either think about a mechanism that moves the sensor but this would require the bayonet mount to protrude slightly from the housing.
  • The other option would be to have a kind of tube with a larger diameter (e.g. in the size of an L-mount) and some mechanics moving inside this tube that has an M-mount bajonet, similar to the construction of the Techart Pro LM-EA9 (using 4 small servo motors).
In order to maintain the form factor of the M housing, it would of course mean sacrificing the rangefinder coupling mechanism. This would mean that it would no longer be an "M", but would still have the form factor and would allow the M lenses to be used with autofocus.
If you ask Grok-3 what that could look like, you get the following suggestion (but Grok still tries to keep the view-/rangefinder 😄😞
Don't take it too serious. Also Grok seems to have problems to think out of the box and is bound to traditions...
Edited by 3D-Kraft.com
vor 13 Minuten schrieb jdlaing:
Show the engineering drawings. Especially the part where a mount like shown above would totally block the viewfinder.
If you pay for, I would do that.
But you are still making a mistake in your thinking. The blockage of the (optical) viewfinder would no longer be an issue, since it can be replaced by an EVF also in an AF variant. At least we had already come that far in this thread.
17 hours ago, charlesphoto99 said:
It may be easier now to make lots of 'good' photographs, but it's just the same trying to make a 'great' photograph as it was with film. It's important to make that distinction.
Sort of.
A great photograph is still truly rare - it probably feels even more rare because we are so inundated with the stuff. But a lot of past stuff that holds up - at this point because of its historical value primarily - wouldn’t be strong today. And there are less technical impediments towards making a great image now. Maybe the most accurate thing to say is that the goalpost has moved significantly for what defines “great” - I would buy that, I think the bar now is a lot higher and has to be to break through - but that would be the only way I’d say there are no more great photos now than there were decades ago. I’ve been a professional for years and am not sure I’ve ever made a great photograph yet myself, yet I know I’ve made ones that are just as strong as some historically significant images (without the historical significance..so far at least, on my part) - they just get lost in the sea of other photographers who make stuff that’s even better these days.
Didn't Contax tired something like that with their Reflex cameras do maintain compatibility with the manual focus lenses?
Not the same register. About 45mm vs 28mm IIRC.
So why have a viewfinder? The base problem we have is that some people want an M shaped SL body which only takes M lenses. I can understand the M shaped SL body which actually makes a lot of sense in many ways. Its the M lens only bit that doesn't. A cleverly built adapter could fit onto an M shaped SL body almost seamlessly. What doesn't seem usable about an M shaped SL with a really well taylored adapter for M lenses?
You know what these people do first? They buy a handgrip🤣
  • Haha 2
vor 27 Minuten schrieb pgk:
My description also said, it would not require an (optical) viewfinder anymore, but the Grok AI model still sticked to that tradition in further renderings even after asking it explicitely to remove it from the rendering. Seems to be hardcoded in the model (and also in some heads) that an M needs an optomechanical range-/viewfinder to be an M...
That's also my question (including the AF capability).
  • Haha 1
3 hours ago, TeleElmar135mm said:
The worst cast scenario is getting worse ... not only the price :) ... hopefully it's a rumor and stays that way
https://www.mirrorlessrumors.com/rumored-leica-m12-specs-smaller-and-with-hybrid-viewfinder/
Ah right, so a sort of FF Fuji Xpro camera but smaller.   I can just see it now; image stabilisation, the bright coloured light of focus peaking, image stabilisation and spirit level in the EVF to make sure one gets their composition straight.  And most importantly an M camera with a bright red Leica badge (not a L/CL/SL camera, I mean it just hasn't got that same status has it).  A successful hit with instagrammers/Youtubers/those that can't be arsed with all that challening exposure triangle stuff no doubt.   If that rumour's true of course.
Edited by Ray Vonn
Quote
Rumored Leica M12 specs: Smaller and with hybrid viewfinder?
OMG no!  Don't make it smaller!!
The same people who yelled about the M240 being fat will yell about the M12 being too small!!  😳
Edited by Herr Barnack
Leaving aside technical discussions of what is possible, I think the benefits and challenges of focusing an OVF v EVF based M camera have been done to death in this thread, and many threads previously (at least since the first CMOS based M camera, the M(240)).  For anyone with remaining doubts, perhaps re-read this thread and get out and try you digital M with and without the Visoflex.
The odd question is - what image this would have on your photography.  Or, more generally, what impact has digital technology had on your photography?  I bought a motor drive for my FM2 back in the 1980s.  I liked the grip, didn’t like the increase in bulk and weight and found I didn’t take more images because my hit rate didn’t improve.
My F5 could focus bracket and exposure bracket, but again I never used those functions.
Has having even more functional SL & X2D EVF based cameras changed the way I photograph?  No, not really.  I take different images with them, but that is really more to do with their use.
