LUF Admin Posted May 23, 2024 Share #1 Posted May 23, 2024 Advertisement (gone after registration) The new firmware v.2.1.1 for Leica M11, M11-M and M11-P is available today. The update includes a number of stability and performance improvements. The improvements: Camera did not start if the start process was previously interrupted by switching off the camera. Occasional generation of incorrect image data has been fixed. Various errors and causes of freezes have been fixed. Improving the stability of the firmware. You can download the firmware from the following links: Leica M11: v.2.1.1 Leica M11-M: v.2.1.1 Leica M11-P: v.2.1.1 8 5 Link to post Share on other sites More sharing options...
Advertisement Posted May 23, 2024 Posted May 23, 2024 Hi LUF Admin, Take a look here Did the May 2024 firmware update 2.1.1. solve your M11 freezing problems?. I'm sure you'll find what you were looking for!
Photoworks Posted May 23, 2024 Share #2 Posted May 23, 2024 Updated from SD card. the camera still works LOL initially, it was showing "IN" instead of "SD+IN", I had to take out SD and it was fine when I put it back in. 2 Link to post Share on other sites More sharing options...
chris7273 Posted May 23, 2024 Share #3 Posted May 23, 2024 I will wait some weeks this time 🙂 3 4 Link to post Share on other sites More sharing options...
Rollei35 Posted May 23, 2024 Share #4 Posted May 23, 2024 People with firmware 1.6.2, like me, do NOT update. Let the 2.0.2 people eat the crab first, they have suffered and they don't have anything to lose anyway. I will sit for about a couple of month until the dust settles down and come back to re-assess the situation. 1 7 Link to post Share on other sites More sharing options...
Malabito Posted May 23, 2024 Share #5 Posted May 23, 2024 To update or not to update that is the question.... I have 2.0.2 and my camera works i would say 99% without issues Will wait for the brave users.. would be nice if leica could somehow mention what was causing the issues. I know it's not going to happen.... Link to post Share on other sites More sharing options...
RobW0 Posted May 23, 2024 Share #6 Posted May 23, 2024 Just updated my M11-M. I have only had the camera about two weeks, with not problems so far. Will see how it does on the new firmware and then update my M11-P. 1 Link to post Share on other sites More sharing options...
nickditoro Posted May 23, 2024 Share #7 Posted May 23, 2024 (edited) Advertisement (gone after registration) I downloaded 2.1.1 for my M11 this morning, copied it to the root directory of my SD card, ensured that the camera's battery was at 100%, and proceeded with the update. Typically -- and I've been running firmware updates on M bodies for years -- I watch the progress bar and then follow the instructions when the update is completed. However, this morning, the camera powered off shortly into the update. I haven't done anything yet for fear that if I manually move the power switch to off and back on, I'll cause an issue. I put it in call to Leica USA and left a voice mail but I don't have a lot of confidence that I'll hear back. Anyone else ever have this happen? Edited May 23, 2024 by nickditoro 1 Link to post Share on other sites More sharing options...
jaapv Posted May 23, 2024 Share #8 Posted May 23, 2024 If you power on with the card in place and the camera goes into the standard update procedure I do not think that there is any harm done. If not you won’t have made things worse. Link to post Share on other sites More sharing options...
nickditoro Posted May 23, 2024 Share #9 Posted May 23, 2024 Thank you, jaapv! After reading your reply, I manually moved the power switch to off and back on. Camera booted up as usual. I checked and the firmware is now at 2.1.1. Must have been the quickest M11 firmware update ever. 1 Link to post Share on other sites More sharing options...
lct Posted May 23, 2024 Share #10 Posted May 23, 2024 Thank you Andreas. Just did the fw 2.1.1 update. My user profiles under 2.0.2 seem to work normally. Having had no issues under 2.0.2 i don't expect any under 2.1.1 either but i will report if i get any. Link to post Share on other sites More sharing options...
mboerma Posted May 23, 2024 Share #11 Posted May 23, 2024 I had no problems previously. Not with updating or anything else. This update, using the SD card, went smoothly. All seems to work fine. Link to post Share on other sites More sharing options...
Knightspirit Posted May 23, 2024 Share #12 Posted May 23, 2024 I just updated mine - worked perfectly. Fingers crossed! 1 Link to post Share on other sites More sharing options...
bcaslis Posted May 23, 2024 Share #13 Posted May 23, 2024 Updated both M11 and M11 Monochrom. No issues so far. Hoping this resolves the corrupt image issues with 2.0.2. Link to post Share on other sites More sharing options...
Aperture 2 Posted May 23, 2024 Share #14 Posted May 23, 2024 Updated my MP, no issues 😀 1 Link to post Share on other sites More sharing options...
Knorp Posted May 23, 2024 Share #15 Posted May 23, 2024 Smooth update to 2.1.1 Camera still working: no freezes or corruptions (yet). Back to business as usual ... 1 Link to post Share on other sites More sharing options...
normie610 Posted May 23, 2024 Share #16 Posted May 23, 2024 (edited) Updated both M11 and M11 Mono, and it seems so far the FW has solved a couple of issues: 1. consistent sharpness of JPEG preview of RAW file (previously only the first shot preview is sharp, though this doesn't affect RAW files); 2. much better AWB; 3. reduced magenta tint, which gives more accurate color overall; 4. no camera freeze so far (I didn't have that many to begin with). Very happy so far with firmware 2.1.1. and I'll keep my fingers crossed. Edited May 23, 2024 by normie610 3 1 Link to post Share on other sites More sharing options...
RMF Posted May 23, 2024 Share #17 Posted May 23, 2024 (edited) Thanks for letting us know about the update! Edited May 23, 2024 by RMF Link to post Share on other sites More sharing options...
UliWer Posted May 23, 2024 Share #18 Posted May 23, 2024 When you follow the link given in #1, you'll find the release notes. 1 Link to post Share on other sites More sharing options...
Alvin Greis Posted May 23, 2024 Share #19 Posted May 23, 2024 Works great. Don’t know the reason, but C1 started to recognize camera faster and don’t loose a connection as it was before. Camera has updated through the app, fast and smooth. 2 Link to post Share on other sites More sharing options...
Virtus Posted May 23, 2024 Share #20 Posted May 23, 2024 (edited) I'm leaving for an Arizona vacation tomorrow so I bit the bullet and I did the update. It went well although it took a while to process it. I'm still baffled why it asks you if you want to save the profile on the SD card if saving the profile on the SD card actually messes up the whole process and you need to format the card again and copy again the firmware file on it. Basically my experience was always that if I select "Yes" when asked about saving the profile on the SD card, that thing stops the process. But, fortunatelly, you can format the card and try again. Successfully. Edited May 23, 2024 by Virtus correction Link to post Share on other sites More sharing options...
