I feel a bit stupid, but I am really struggling with nose issues when using the SL3. I shoot Leica for decades, I am right eye dominant so even with digital cameras in general and Leicas in particular I hardly had issues regarding my nose interfering with the camera, but now with the SL3, which is my first not-off-centered-viewfinder-Leica I keep on doing things with my nose to the camera like asking it to change the patch size or moving the af patch. The good thing is I now manage to recenter the focus patch with a double nose tap, but I am not yet able to switch back to photo mode when I somehow again managed to put the camera in movie mode.
Why is Leica not enabeling to disable the touch function? Or is it worth to get a Michael Jackson nose job? Am I just too ham-fisted-nosed to be allowed to own and use the SL3?
it's annoying...
  • Haha 1
lol at double nose tap 😁
As noted above you can set the EVF mode to "Extended view" which only activates the rear screen when using the menu or changing settings (also saves battery very well). I thought there was also a setting to disable touch (but probably I was thinking of the setting to turn touch-AF off, in case you don't like to focus with your nose).
I am left eye dominant so my nose is even more on the screen but this hasn't been an issue for me, although I nearly always use EVF extended.
The extended Viewfinder option doesn't disable the function to change the size of the viewfinder patch, which I keep on activating. I will probalby have to adapt my way to hold the camera so that I avoid touching the LCD with my nose
EVF does not have any resize or moving AF field by Default.
You probably have turned on "Touch AF in EVF"
Solution:
Wikimedia/Fallout /creative commons
  • Haha 5
Am 2.5.2024 um 10:41 schrieb geesbert:
it's annoying...
No Problem: Wait for the SL3-D :)
  • Haha 2
  • 1 month later...
it's annoying...
Just got mine and having this issue constantly....
screen in general is quite sensitive compared to others... even carrying the camera cross bodies with my shirt rubbing on the screen moves the focus point..
A fix would be great, but love the camera and images so far...
... he had no problems :)
it's annoying...
Mine is somehow set up where this doesn't seem to be possible.  When i put my eye to the EVF the screen goes off.  Test it just by putting a finger over EVF, my screen goes completely black.  I think one of the FN buttons is defaulted to change the screen settings on, off, extended and whatever else.  In really going over the camera I pressed the corresponding FN button and almost never figured out how to get the screen back on.  Right now mine comes on when I take my eye away from the EVF.
  • 2 weeks later...
I'll join in here. I also have this "nose problem". Although I have completely deactivated "Touch AF" in the menu, I can still center the AF point with a double tap on the display. If I have the display on, even with a normal double-tap, with "EVF extended" this unfortunately sometimes also happens with the nose.
All of you with the shnoz issue like I used to have, here are my settings that have worked out (even if you don't have the nose issue:
In the Menu>Camera Settings>EVF<>LCD Set to EVF Extended
LCD Brighness I turned mine down one notch
EVF Brightness I left alone
Menu>Focus settings>Touch AF I turned OFF
Menu>AF in EVF I turned this off as well.
Menu>Auto Review ON
Settings- 5 seconds.
With these settings, the lcd remains off except for when I take a picture and pull the camera from my face, the photo shows up on lcd for 5 second review, other wise it shows as you are looking through the EVF. Dismissed with a partial shutter press.
I would also think this might save some battery power not having the lcd on all the time. I would absolutely probably never use the "Auto" setting for EVF-LCD. I found it annoying that it would go on and off when something is detected in EVF.
Another thing don't forget to save you settings that you like to a profile. You can keep fine tuning, SAVE AS and overwrite your last profile (or create new) This is really cool! Don't forget to "Export Profile", which saves the settings file to the CFe card. I also save those settings to my computer, since and I'm not positive on this, every time you format the card, your Exported Setting file on the CFe are erased. You would need to re-export. FWIW. Jonathan
Edited by Jonathan Levin
First of all, thanks for the tip.
However, apart from LCD brightness and Auto Review, these are also my settings.
I will test LCD brightness, but I don't want to use Auto Review.
I don't think the problem is all that bad either. After all, centering the AF field with a double tap is quite practical. That way I have an FN button free for something else. The only thing that can be annoying is accidental centering with the nose if it is not noticed immediately in the heat of the moment.
NingNing
Are you saying that with the settings you have which are almost identical to mine, somehow  the focus square is moving about? With my set up the only way I can move the focus square is by using the joystick, which I have set to AF-L when pressed. This works perfect for me for now.
8 hours ago, Ning Ning said:
Exactly. If I take the camera to the eye (EVF-Advanced), move the AF field with the joystick and then accidentally touch the display with my nose, it may be that the AF field is centered again.
Do you mean EVF-Extended mode? In that mode, the rear LCD is disabled and does not react to touch. The only way to move the AF field is with the joystick.
Edited by SrMi
