lct Posted October 28, 2023 Share #81 Posted October 28, 2023 Advertisement (gone after registration) 18 minutes ago, elmars said: I selected the lens profile for the Summicron. And every time I put the Summaron on it it is recognized as the Summicron. Works like firmware 1.6.1 from this viewpoint but in the thread below, we've seen that selecting a lens profile manually can be useless under the new firmware in case of faulty adapter. Am i missing something? Link to post Share on other sites More sharing options...
Advertisement Posted October 28, 2023 Posted October 28, 2023 Hi lct, Take a look here Leica M11 Firmware V 2.0.1. I'm sure you'll find what you were looking for!
don daniel Posted October 28, 2023 Share #82 Posted October 28, 2023 vor 7 Stunden schrieb elmars: I tried a Z9 and a D800 from a friend with fixed whitebalance to sunlight. Tint was 0 in both cases. Far too green in my eyes. I'll try fixed whitebalance on the Z9. But usually I don't use a fixed setting because the automatic white balance is perfect in almost every single shot. And I'll show a comparison between the automatic WB in the Nikon and in the M11. 1 Link to post Share on other sites More sharing options...
jeri Posted October 28, 2023 Share #83 Posted October 28, 2023 UHS-I SD card owners beware of the V 2.0.1 firmware Well, I was tempted and did the firmware update (2.0.1). Everything was going smoothly, until I decided to view the photos that were previously on the SD card. To my surprise, I suddenly receive an error message - there is no information on the external SD card in the camera. Ok, maybe a little glitch in the system, I thought to myself. Well, I turned off the camera, pulled out the battery, and waited for about a minute. I then put everything back in place, turned the camera back on, and everything seemed to be working fine. At least that's what I thought, because even though I could view the images normally on the monitor, still a few seconds later, the same error message is received again on the camera monitor. And of course nothing works and you can't take a picture. It is important to note that in the default setting, the photos I take are saved on the external SD card. Then I remembered that Leica indicates that problems may develop when the camera is combined with UHS-I SD cards, and this is exactly the 'problematic' card that is in my camera. A memory card that until the last firmware, worked without any problems. Thank God I have another UHS-II type SD, with which everything seems to be working fine now. I hope that the latest firmware update will not open a new Pandora's box. 1 Link to post Share on other sites More sharing options...
LikameLeica Posted October 28, 2023 Share #84 Posted October 28, 2023 53 minutes ago, jeri said: UHS-I SD card owners beware of the V 2.0.1 firmware Well, I was tempted and did the firmware update (2.0.1). Everything was going smoothly, until I decided to view the photos that were previously on the SD card. To my surprise, I suddenly receive an error message - there is no information on the external SD card in the camera. Ok, maybe a little glitch in the system, I thought to myself. Well, I turned off the camera, pulled out the battery, and waited for about a minute. I then put everything back in place, turned the camera back on, and everything seemed to be working fine. At least that's what I thought, because even though I could view the images normally on the monitor, still a few seconds later, the same error message is received again on the camera monitor. And of course nothing works and you can't take a picture. It is important to note that in the default setting, the photos I take are saved on the external SD card. Then I remembered that Leica indicates that problems may develop when the camera is combined with UHS-I SD cards, and this is exactly the 'problematic' card that is in my camera. A memory card that until the last firmware, worked without any problems. Thank God I have another UHS-II type SD, with which everything seems to be working fine now. I hope that the latest firmware update will not open a new Pandora's box. I always make sure to follow these steps when upgrading firmware. Download all current photos from SD Card Reformat the SD Card in camera Reformat the Internal Memory (new step with M11 due to internal memory) Export User Profiles to the newly formatted SD Card (just in case they somehow get corrupted in the upgrade process [old Leica SL issue and experience]) Upgrade the Firmware - (I now do this using the Leica Foto App and it has worked flawlessly) Hope that this helps. Link to post Share on other sites More sharing options...
DadDadDaddyo Posted October 28, 2023 Share #85 Posted October 28, 2023 (edited) The release notes for 2.0.1 prompted me to make the jump from UHS-I to UHS-II cards. I'm not aware of having had any issues as a result of using the UHS-I card up till now, but the liner notes were more specific and explicit than any of the advice I recall from Leica before regarding SD cards. Received the new cards, formatted each with SD Card Formatter employing the 'overwrite' option, then formatted each card in-camera. Edited October 28, 2023 by DadDadDaddyo Link to post Share on other sites More sharing options...
jeri Posted October 28, 2023 Share #86 Posted October 28, 2023 1 hour ago, LikameLeica said: I always make sure to follow these steps when upgrading firmware. Download all current photos from SD Card Reformat the SD Card in camera Reformat the Internal Memory (new step with M11 due to internal memory) Export User Profiles to the newly formatted SD Card (just in case they somehow get corrupted in the upgrade process [old Leica SL issue and experience]) Upgrade the Firmware - (I now do this using the Leica Foto App and it has worked flawlessly) Hope that this helps. The SD card was completely formatted (it is important to note that this is another card that I do not use, except for needs such as hardware upgrades, etc.), before the new firmware file was installed on it. After the installation, I returned the original SD card to the camera. As mentioned , the photographed material that was on the original UHS-I type SD card was not lost. It is there on the SD card. The only problem is that the camera, after installing the new firmware, sees the aforementioned SD card as empty. Thanks for your response. 1 Link to post Share on other sites More sharing options...
Fatih Posted October 29, 2023 Share #87 Posted October 29, 2023 Advertisement (gone after registration) On 10/26/2023 at 6:00 PM, hmzimelka said:Is this a new feature in 2.0.1? The custom function buttons can now be programmed with a "Centre Frame" option that resets the LV cursor back to centre screen. Thanks so much for this. I didn't know it existed before. I programmed it to my back dial button, which wasn't used that very often. The top button enables focus aid now, and I can easily center back the focus point by pressing the back dial button. Link to post Share on other sites More sharing options...
don daniel Posted October 29, 2023 Share #88 Posted October 29, 2023 M11, SL50mm asph. auto white balance LR shows: Temperature: 5600, Tint: 22 Ridiculous amount of magenta in the Leica picture. An M10-R or an M10 would never do this! Z9, Nikkor Z24-120mm at 50mm, auto white balance A1 LR shows: Temperature 5500, Tint: +16 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/383478-leica-m11-firmware-v-201/?do=findComment&comment=4884740'>More sharing options...
don daniel Posted October 29, 2023 Share #89 Posted October 29, 2023 Same cameras, but white balance set to "sunny". The Leica picture has got even more magenta (temperature: 5100, tint: +25!) , both pictures are too cold, because I did not take them in the golden hour, but right now on grey morning. You can correct the Nikon file (temperature: 5150, tint: +14!) by simply adjusting the temperature slider. It then becomes warm, but there is no magenta or green cast. But in the Leica pictures I have to adjust both sliders: temperature and tint. This is annoying! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/383478-leica-m11-firmware-v-201/?do=findComment&comment=4884750'>More sharing options...
elmars Posted October 29, 2023 Share #90 Posted October 29, 2023 That is strange. With my M11 the values for sunny are 5150 and +21 (from memory). With the friend's Nikons, the tint was also significantly different from yours. I don't really understand it that way. In any case, it remains that the tint on the M11 goes too much in the direction of magenta. 2 1 Link to post Share on other sites More sharing options...
Viv Posted October 29, 2023 Share #91 Posted October 29, 2023 The shutter closing when a lens is removed is a great feature. 1 Link to post Share on other sites More sharing options...
BJN Posted October 29, 2023 Share #92 Posted October 29, 2023 Going from Live View to Play, for a split second I see the level gauge on the screen, I do not have the level gauge selected in live View? Link to post Share on other sites More sharing options...
lct Posted October 29, 2023 Share #93 Posted October 29, 2023 On 10/26/2023 at 5:00 PM, hmzimelka said: The custom function buttons can now be programmed with a "Centre Frame" option that resets the LV cursor back to centre screen. Can't seem to find that "Centre Frame" option. Would you mind to explain how you got there? Link to post Share on other sites More sharing options...
Kim Dahl Posted October 29, 2023 Share #94 Posted October 29, 2023 long press the FN button - select the last option in the row of FN options - it says center frame - select it - 1 Link to post Share on other sites More sharing options...
elmars Posted October 29, 2023 Share #95 Posted October 29, 2023 If You turn LV off and on again it is centered too. 3 2 Link to post Share on other sites More sharing options...
hmzimelka Posted October 29, 2023 Share #96 Posted October 29, 2023 44 minutes ago, lct said: Can't seem to find that "Centre Frame" option. Would you mind to explain how you got there? As @Kim Dahl mentioned; Long press any of the FN buttons, and select "center frame" option right at the bottom of the list. 28 minutes ago, elmars said: If You turn LV off and on again it is centered too. This is good to know, thanks! Was it always like this or is it new to FW 2.0.1? 1 Link to post Share on other sites More sharing options...
Gigamesh Posted October 29, 2023 Share #97 Posted October 29, 2023 (edited) Started the firmware update on my M11. It's been no a good 15min of updating, did it take as long for you as well? What happens if it stalls somewhere in the update process? Will it go on until battery is drained? Should I plug in the usb to charge? When should I abort? Edited October 29, 2023 by Gigamesh Link to post Share on other sites More sharing options...
elmars Posted October 29, 2023 Share #98 Posted October 29, 2023 vor 34 Minuten schrieb hmzimelka: This is good to know, thanks! Was it always like this or is it new to FW 2.0.1? Sorry, I don‘t know. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted October 29, 2023 Share #99 Posted October 29, 2023 Tracking down the focus spot and dragging it back from whatever corner it was hiding in was the rule in 1.6 and it is solved in several ways in 2.0.1. A little thing, but a real advance! 4 Link to post Share on other sites More sharing options...
Smogg Posted October 29, 2023 Share #100 Posted October 29, 2023 4 hours ago, don daniel said: Same cameras, but white balance set to "sunny". The Leica picture has got even more magenta (temperature: 5100, tint: +25!) , both pictures are too cold, because I did not take them in the golden hour, but right now on grey morning. You can correct the Nikon file (temperature: 5150, tint: +14!) by simply adjusting the temperature slider. It then becomes warm, but there is no magenta or green cast. But in the Leica pictures I have to adjust both sliders: temperature and tint. This is annoying! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Unfortunately, this is a common behavior for m11, which it seems the manufacturer is not going to fix. I started carrying the Ricoh GRIII with me (it doesn't take up much space), first I take a quick frame using the Ricoh to get normal white balance values for the current lightning Link to post Share on other sites More sharing options...
