SrMi Posted May 5, 2023 Share #121 Posted May 5, 2023 Advertisement (gone after registration) 17 hours ago, Olaf_ZG said: With difference that 2s is cheaper than 2… doubt that it will be the case here… That would be the case only if Q3 uses a cheaper sensor with smaller resolution. That does not seem to be the case. Link to post Share on other sites More sharing options...
Advertisement Posted May 5, 2023 Posted May 5, 2023 Hi SrMi, Take a look here Leica Q3 ? . I'm sure you'll find what you were looking for!
thelivingyears Posted May 5, 2023 Share #122 Posted May 5, 2023 I would buy a Q3 with 40mm lens within seconds. I would add a Ricoh GRIII for the wide angle since it fits into a pocket easily. 40mm Leica q3 plus crop capabilities + Ricoh GRIII would be a sensational travel photography package. Currently I use a Ricoh GRIIIx which is also a 40mm camera and I loved it while traveling America last summer. 3 Link to post Share on other sites More sharing options...
T25UFO Posted May 5, 2023 Share #123 Posted May 5, 2023 Ah, still the same old discussions, a Q with 35mm or 40mm or 50mm or whatever. It won't happen. It's a 28mm lens and you achieve other effective focal lengths by cropping! That's it. 1 2 1 Link to post Share on other sites More sharing options...
thelivingyears Posted May 5, 2023 Share #124 Posted May 5, 2023 vor 44 Minuten schrieb T25UFO: It won't happen. It's a 28mm lens and you achieve other effective focal lengths by cropping! That's it. That it won’t happen (even though dealers recently said – as mentioned above –, it could) is one thing. But what I cannot understand is that photographers equate cropping with taking photos with a lens with a dedicated focal length. In addition, in a Leica forum. But well, to each his own. Different question: Is it likely that a Q3 Monochrom will be available right from the beginning? If not, how long do you expect we have to wait for the monochrome version? 1 Link to post Share on other sites More sharing options...
Le Chef Posted May 5, 2023 Share #125 Posted May 5, 2023 Cropping with a likely 60MP sensor and noise reduction software negates the need for other focal lengths. If you need to know what other focal lengths look like you can use the crop setting to cycle through and frame to your preferred focal length. If past is prologue then you have about 12 months before the Q3M appears. Link to post Share on other sites More sharing options...
thelivingyears Posted May 5, 2023 Share #126 Posted May 5, 2023 vor 3 Minuten schrieb Le Chef: Cropping with a likely 60MP sensor and noise reduction software negates the need for other focal lengths. If you need to know what other focal lengths look like you can use the crop setting to cycle through and frame to your preferred focal length. If past is prologue then you have about 12 months before the Q3M appears. I had a Leica Q2 for a couple of months so I‘m basically well aware of how it works. And still I personally see a difference between cropping and taking pictures with a lens featuring a certain focal length. But as I said, if out of a sudden cropping “negates the need for other focal lengths“ for you guys, so be it. No prob. Thanks for your estimation of how long it could take (judging from what happened in the past). So I might get a M Monochrome first even though it‘s very different camera to me. 1 Link to post Share on other sites More sharing options...
T25UFO Posted May 5, 2023 Share #127 Posted May 5, 2023 Advertisement (gone after registration) 24 minutes ago, thelivingyears said: That it won’t happen (even though dealers recently said – as mentioned above –, it could) is one thing. But what I cannot understand is that photographers equate cropping with taking photos with a lens with a dedicated focal length. In addition, in a Leica forum. But well, to each his own. Different question: Is it likely that a Q3 Monochrom will be available right from the beginning? If not, how long do you expect we have to wait for the monochrome version? Leica decided that cropping was the way to go with a fixed lens Q and that won't change. I doubt it would make commercial sense to manufacture a range of Qs with different fixed focal lengths. Of course, some dealers will always speculate, but they don't have to fund the R&D costs! Leica offer other interchangeable lens options if you want different focal lengths. Link to post Share on other sites More sharing options...
FrozenInTime Posted May 5, 2023 Share #128 Posted May 5, 2023 1 hour ago, T25UFO said: Ah, still the same old discussions, a Q with 35mm or 40mm or 50mm or whatever. It won't happen. It's a 28mm lens and you achieve other effective focal lengths by cropping! That's it. Two body problem : I want to crop a 28mm over 28 … 50mm and a 40mm over 40 … 135mm Link to post Share on other sites More sharing options...
Le Chef Posted May 5, 2023 Share #129 Posted May 5, 2023 5 minutes ago, FrozenInTime said: Two body problem : I want to crop a 28mm over 28 … 50mm and a 40mm over 40 … 135mm Just buy an SL2 with a 24-90 and be done with it. 1 Link to post Share on other sites More sharing options...
Casey Jefferson Posted May 6, 2023 Share #130 Posted May 6, 2023 Make a 40mm Q people will complain 35mm is a more useful focal length, make it 35mm people will complain it's too close to the original 28mm (to have alongside). 🤪 I'm still looking forward to the higher capacity battery and finger crossed it'll be backward compatible... 1 Link to post Share on other sites More sharing options...
Le Chef Posted May 6, 2023 Share #131 Posted May 6, 2023 9 minutes ago, Casey Jefferson said: Make a 40mm Q people will complain 35mm is a more useful focal length, make it 35mm people will complain it's too close to the original 28mm (to have alongside). 🤪 I'm still looking forward to the higher capacity battery and finger crossed it'll be backward compatible... I hope that the battery and grip etc. are all the same size rather than Leica “doing an Apple” and changing every accessory and connection every 10 minutes. To do so is poor design. 1 Link to post Share on other sites More sharing options...
thelivingyears Posted May 6, 2023 Share #132 Posted May 6, 2023 vor einer Stunde schrieb Casey Jefferson: Make a 40mm Q people will complain 35mm is a more useful focal length, make it 35mm people will complain it's too close to the original 28mm (to have alongside). 🤪 Sure there will be people who will complain. But of course this doesn’t mean a bit that there won’t be a lot more people who will be extremely happy about a 40mm Q3. 5 Link to post Share on other sites More sharing options...
Olaf_ZG Posted May 6, 2023 Share #133 Posted May 6, 2023 9 hours ago, Le Chef said: Cropping with a likely 60MP sensor and noise reduction software negates the need for other focal lengths. If you need to know what other focal lengths look like you can use the crop setting to cycle through and frame to your preferred focal length. If past is prologue then you have about 12 months before the Q3M appears. Iphone14 and/or AI negates the need for a Q… 1 1 Link to post Share on other sites More sharing options...
Ronaldraw Posted May 6, 2023 Share #134 Posted May 6, 2023 The people who are complaining have no Q 1 Link to post Share on other sites More sharing options...
T25UFO Posted May 6, 2023 Share #135 Posted May 6, 2023 1 hour ago, Olaf_ZG said: Iphone14 and/or AI negates the need for a Q… AI negates the need for life 😞 3 Link to post Share on other sites More sharing options...
LocalHero1953 Posted May 6, 2023 Share #136 Posted May 6, 2023 All I want is better low light/high ISO noise/colour, and the ability to record long video (so it will need USB-C charging and no 30min limit). Without those limitations, it's a neat alternative in small venues for video and stills of theatrical/musical productions. Its big advantage at the moment (for stills) is its near-silent leaf shutter, so it has none of the banding problems associated with a silent electronic shutter on other mirrorless cameras. I don't want an articulating screen, but would accept it if it improved heat dissipation for long video. And I'll stick with 28mm thank you very much! Link to post Share on other sites More sharing options...
Ronaldraw Posted May 6, 2023 Share #137 Posted May 6, 2023 15 minutes ago, LocalHero1953 said: All I want is better low light/high ISO noise/colour, and the ability to record long video (so it will need USB-C charging and no 30min limit). Without those limitations, it's a neat alternative in small venues for video and stills of theatrical/musical productions. Its big advantage at the moment (for stills) is its near-silent leaf shutter, so it has none of the banding problems associated with a silent electronic shutter on other mirrorless cameras. I don't want an articulating screen, but would accept it if it improved heat dissipation for long video. And I'll stick with 28mm thank you very much! And video in 4K😊 Link to post Share on other sites More sharing options...
LocalHero1953 Posted May 6, 2023 Share #138 Posted May 6, 2023 (edited) 9 minutes ago, Ronaldraw said: And video in 4K😊 My uses are specialised, but I agree. Most of my video deliverables (plays, musical performances, talking heads) have no need to be more than FHD, but 4k/6k/8k offer the opportunity to cut to zoom in post production, and the Q2(3) lens and resolution are easily capable of doing that. At present the ugly noise in low light is a bit inhibiting. Edited May 6, 2023 by LocalHero1953 Link to post Share on other sites More sharing options...
Lelmer Posted May 6, 2023 Share #139 Posted May 6, 2023 5 hours ago, Casey Jefferson said: Make a 40mm Q people will complain 35mm is a more useful focal length, make it 35mm people will complain it's too close to the original 28mm (to have alongside). 🤪 I'm still looking forward to the higher capacity battery and finger crossed it'll be backward compatible... I haven't seen complains from Ricoh users about their 40mm focal length...they seem to be happy with 28 and 40mm 5 1 Link to post Share on other sites More sharing options...
Simone_DF Posted May 6, 2023 Share #140 Posted May 6, 2023 12 hours ago, T25UFO said: It won't happen. It's a 28mm lens and you achieve other effective focal lengths by cropping! That's it. Yeah, so clever. Spend 8k on Q3 to crop to 50mm all the time 🙄 people that tend to shot most of their photos with a focal length over 35mm are much better served by a APSC camera if they still want to retain a compact weight / footprint, like a CL2, right? 1 Link to post Share on other sites More sharing options...
