Did they ever think about if releasing any special edition, that they also need to produce a battery for each of it? Like, the reporter would need a battery with a green cover etc.
How will they manage this? And doesn't it mean that these batteries will be very unique and maybe fast not be produced anymore?
The windscreen wipers on my 'limited edition' van are the same colour as the standard van.  So are the tyres, for that matter.
It has never occurred to me that I've been fooled by marketing until now.....
  • Haha 1
If Leica releases an M11 Reporter or Safari version at some point, they will simply make a run of batteries with the right color base to match the base of the camera.
It doesn't seem to be much of a problem IMHO.
Edited by Herr Barnack
vor 3 Stunden schrieb trequartista:
The color of the batteries doesn't matter; the question is, can we get new batteries in 15 or more years?
That's what I mean. With such unique requirements to a battery, probably nobody can reproduce them ever.
Yeah, so they will produce a few hundreds or thousands maybe, that's it.
Edited by trequartista
Black battery will look fine with Safari. We use black and silver lenses on Safari bodies.
Q2 Reporter uses a black battery.
Edited by hdmesa
  • Thanks 2
Another reason to get black M11 😉.
  • Haha 1
Hah, well now that I think about it, don't they usually do silver as the contrasting color on the safari? I guess there is always the M11 Reporter that will go well with the black. Now that the bottom plate is not removable on the M11, the Kevlar will not fuzz-up at the bottom edge like it did with the M10-P Reporter.
Silver is too strong in contrast to dark green. Black looks good on Q2 reporter.
4 minutes ago, hdmesa said:
Yes, they do black with Reporter, but silver with Safari. I'd rather they did black with both.
Are you sure? There is no Q2 safari. All other Safari models have hidden battery. AFAIK, all SL2/Q2 batteries are black.
I thought the context was M special editions, and I was speaking to what Leica might do specifically on an M11 Safari or Reporter. I used the Q2 Reporter as an example of how Leica did not need to use the special edition color on the battery cover. I couldn't reference a previous M special edition because they all have the removable bottom plate and the battery is hidden.
53 minutes ago, setuporg said:
I've seen M10-P Safari with silver lenses, gorgeous.  Certainly better than black ones.
Black doesn't look as good on the M10-P Safari because the body's metal accents are all silver 🙃 I'm sure they'll keep it that way –> Safari/silver -|- Reporter/black.
They don't need to; there are battery refurbishing places all over.
