wizard Posted May 25, 2022 Share #21 Posted May 25, 2022 Advertisement (gone after registration) vor 21 Minuten schrieb Photoworks: in single mode I press shutter 3-4 times... only 2 images taken... Try a faster SD card, that could solve the problem. Link to post Share on other sites More sharing options...
Advertisement Posted May 25, 2022 Posted May 25, 2022 Hi wizard, Take a look here New Leica M11 Firmware Update with v.1.4.0.0 - Download Link and Improvements. I'm sure you'll find what you were looking for!
Photoworks Posted May 25, 2022 Share #22 Posted May 25, 2022 15 minutes ago, hmzimelka said: 🤦🏻♂️ That sucks. For me the Highlight Weighted metering isn't working properly. Useless for me when a scene has 3 clipped channels in a program mode intended to preserve highlight clipping. On my camera it seems heavily centre biased and anything dark fools it into overexposure. Single mode shooting I tested only once, but managed to shoot off some 5 frames without an issue. At least 1.4.0.0 is a step in the right direction, but it's still a long road. Sigh I will try to reset camera and see if anything improves... I agree with you on highlight Weighted metering... it is better, but I got similar results in of center highlights. Clipping to no recovery.. Link to post Share on other sites More sharing options...
hmzimelka Posted May 25, 2022 Share #23 Posted May 25, 2022 (edited) 7 minutes ago, wizard said: Try a faster SD card, that could solve the problem. This camera caps out at 99 MB/s write speed with every UHS II card I've tried. It shouldn't stop anyone from shooting off 4 consecutive shots even with the slowest SD card, since the buffer capacity is larger than four shots. Anyways, this is an example of highlight weighted metering not working... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited May 25, 2022 by hmzimelka Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/332787-new-leica-m11-firmware-update-with-v1400-download-link-and-improvements/?do=findComment&comment=4441681'>More sharing options...
Photoworks Posted May 25, 2022 Share #24 Posted May 25, 2022 8 minutes ago, wizard said: Try a faster SD card, that could solve the problem. resetting camera improves the shooting.. thanks 1 Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 25, 2022 Share #25 Posted May 25, 2022 where/how do you bring up the update process? I need to do this as I am travelling and left the card reader behind. Link to post Share on other sites More sharing options...
idusidusi Posted May 25, 2022 Share #26 Posted May 25, 2022 Once you have the file downloaded and copied to the root directory of the SD card, then all you need to do is put in a fully charged battery then go in the Menu to Camera Information, Camera Firmware Version, Firmware Update then follow the prompts. 1 Link to post Share on other sites More sharing options...
erudolph Posted May 25, 2022 Share #27 Posted May 25, 2022 Advertisement (gone after registration) 31 minutes ago, scott kirkpatrick said: where/how do you bring up the update process? I need to do this as I am travelling and left the card reader behind. For me, for some reason, connecting via Wi-Fi did not work at first try. I then deleted the M11 from Leica FOTOS and repaired. Then, in a boots-AND-suspenders moment, I connected via USB-C. The app wanted to have Bluetooth turned on which I did and the camera connected to the app. Scott, if there is an Update selection in the M11 section of FOTOS, just select that. If not, I guess you'll have to wait for the update to reach your part of the world. Link to post Share on other sites More sharing options...
Jewl Posted May 25, 2022 Share #28 Posted May 25, 2022 vor 34 Minuten schrieb scott kirkpatrick: where/how do you bring up the update process? I need to do this as I am travelling and left the card reader behind. Update the Fotos app, open it and below the M11 profile (the entry you press to connect in the list of cams you have added) it says „update available“ - press and follow the instructions on screen. Works over wifi. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 25, 2022 Share #29 Posted May 25, 2022 (edited) Thanks. I haven’t gotten thatmessage yet but I did connect to the m11. oh, ow there it is. operating in Berkeley for next three days. Edited May 25, 2022 by scott kirkpatrick Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 25, 2022 Share #30 Posted May 25, 2022 Problem solved. I thought you should first connect to the camera, then download firmware. No, it’s firmware first, and the you are connected. Don’t forget to upload profiles afterwards. Link to post Share on other sites More sharing options...
hdmesa Posted May 25, 2022 Share #31 Posted May 25, 2022 Update via the app was perfect: all profiles were still there, and the image file naming continued where it left off with custom prefix intact. Before updating, I did save all my profiles to the SD card just in case, plus I left my last few images on the SD in case that helped it continue numbering correctly. So far everything seems a bit more responsive. 1 Link to post Share on other sites More sharing options...
oka Posted May 25, 2022 Share #32 Posted May 25, 2022 Only major issue on M11 is the shutter which behaves erratically and doesn’t behave like it should on camera with this price point. Firmware 1.4 doesn’t solve the issue, makes some refinement at the best. I hope, they fix the issue in upcoming updates… 1 Link to post Share on other sites More sharing options...
ELAN Posted May 25, 2022 Share #33 Posted May 25, 2022 (edited) 13 hours ago, Leon_B. said: FIXED: No more shutter delay between shots Update via Fotos app was effortless and flawless, for the second time now. Kudos to Leica for getting this right! Shutter release is better now but still not quite right. I changed Auto Review from Shutter Button Pressed back to Off and tried the following drive modes: Single shot: multiple presses of the shutter button now takes a shot for every press. Thank you for that. However, if I press the shutter button as fast as I can no shots at all are taken after the first press. I can press very fast five or ten times and only the first press fires the shutter. Normally this is a non-issue, however… Continuous Low: On the M10 a single press of the shutter button takes one image and flaps the shutter once. Holding down the shutter button takes multiple shots. This was my default drive mode for years on the M240 and M10 series. In Continuous Low on the M11, on a single shutter button press the shutter sounds twice and one is image taken. This is different than the M10 and quite annoying to hear and feel the shutter flap twice. I suspect that second shutter sound is actually the shutter reopening after a short delay to re-enable the metering because the M11 continuous drive keeps the shutter closed after the first shot in anticipation of multiple shots. If the shutter button is released quickly and the subsequent shot doesn’t happen the shutter then flaps open to meter. Hopefully this isn't by design and can be changed. My default drive mode on the M11 is for now (unfortunately) single shot - a setback for me. Edited May 25, 2022 by ELAN Link to post Share on other sites More sharing options...
oka Posted May 25, 2022 Share #34 Posted May 25, 2022 5 minutes ago, ELAN said: Shutter release is better now but still not quite right. Yes, it’s most refined on single shots. I could take with Low mode single shots with one shutter sound. Sometimes it makes two as you mentioned and sometimes time between shutter sounds vary… As I could take multiple photos in single mode without extra shutter sounds, it should be possible on Low/High modes… 1 Link to post Share on other sites More sharing options...
THEME Posted May 26, 2022 Share #35 Posted May 26, 2022 Great, they fixed the Fn button metering mode, now doesn't just always jump to the next mode. 🤩 Link to post Share on other sites More sharing options...
lct Posted May 26, 2022 Share #36 Posted May 26, 2022 Shutter behaving erratically. Looks like auto review is still the culprit. Worse result when it is set to off or shutter button curiously enough. No problem at 1s, 3s or 5s apparently. Link to post Share on other sites More sharing options...
Eugene Young Posted May 26, 2022 Share #37 Posted May 26, 2022 I got my m11 firmware updated. But shutter delay between shots still existed. Pressed shutter 3-4times and didn’t work. What shall I do to fix this problem? Link to post Share on other sites More sharing options...
Viv Posted May 26, 2022 Share #38 Posted May 26, 2022 No shutter delay on my M11. Link to post Share on other sites More sharing options...
oka Posted May 26, 2022 Share #39 Posted May 26, 2022 …maybe Leica should ask Panasonic to help them out. It’s quite odd that they manage SL2(s) work flawlessly but on M it’s just disaster. I suspect that on SL2(s) base functions / basic firmware features are done by Panasonic and on M, Leica does it all by them self with poor results. Shutter is basically the most import core function on cameras and it should just work. There are no excuses to accept this even on Leica land. Link to post Share on other sites More sharing options...
Photoworks Posted May 26, 2022 Share #40 Posted May 26, 2022 3 hours ago, Eugene Young said: I got my m11 firmware updated. But shutter delay between shots still existed. Pressed shutter 3-4times and didn’t work. What shall I do to fix this problem? I had that too, but after resetting the camera it works much better.. 1 Link to post Share on other sites More sharing options...
