I’d like to get hold of a compact 21 or 18 for zone focussing when out on the street with my CL. Speed is not particularly important as I’ll only be using it outdoors, but compactness and image quality are.
I like the look of the Zeiss 21 f/4.5. Has anyone used it on this system? I’m also aware that the newer VM 21 f/3.5 is well regarded. The Leica variant is probably out of my reach but any other recommendations would be great.
Cheers.
No color shifts with the CV 21/3.5. It is a bit taller than the CV 21/4 but not by much. It is also sharper than the latter at f/4 with significantly less flare but it has more CA. See:
Well, given that there are two native lenses offering this focal length, I guess the answer is yes.
As they are AF, there is no need to revert to zone focusing either. I'm sure that you are aware that choosing the desired aperture and setting the camera to face recognition will give better results.
My experience with the 23 in busy street scenes in face AF mode is that it will often either be too slow to lock on, pick out the wrong face or revert to multi-field. None of which get me the shot.
I want to be in control of what’s going on not hoping for the best, hence interest in zone focussing.
I agree wholeheartedly with the last, but that is exactly why I dislike zone focusing - I am somebody who finds exact placement of the plane of focus essential. I tend to throw out images which depend on DOF to appear acceptably sharp. To my mind it is zone-misfocus.  Possibly that is why I am not an avid street photographer.
The quick manual correction possible in the CL will be of help, I'm sure.
https://www.exibartstreet.com/news/leica-cl-review-street-photography/
Thanks for that link Jaapv - not one I've read before.  One thing that had me scratching my head though was the sentence below,  as I'm sure I have never been able to achieve a magnified view in autofocus mode when moving the focus ring, even when half pressing the shutter button.   Am I missing a trick somewhere?
The auto to manual focus switching system is another brilliant implementation from Leica engineers since you just need to rotate the focus ring on your lens and you are in full manual control, assisted by a magnified portion of the framed scene or, if you prefer, by a color-customizable focus peaking system.
I agree, it’s an interesting article.
But my problem is with the idea of manual focus correction in fast-moving scenes, as opposed to preemptively getting it right.
Edited by ruskkyle
I'm missing the same trick -  I tried it for the first time without success just now- never used it with AF lenses, one loses the framing - I use blue focus peaking
Pretty sure that the CL does not do what was being described in the review.    Not a problem, just was slightly worried I was missing something.  I hadn't ever tried it myself, and even resorted to checking out the manual, but as you say, it is just focus peaking available as a manual assist when in autofocus mode, not magnified view.  If someone else knows differently hopefully they will let us know😃.
Edited by Boojay
vor 30 Minuten schrieb ruskkyle:
Anyone tried the 21 super Elmar M on APS-C?
I did it yesterday with my old Sony A6300 (CL should be even better)
Thinking about buying a CL and I'm acutally looking for a standard lens; 21mm might be a solution.
The SEM 21mm is a great lens, I'm using it for years on different Bodies.
Have a look at this article, should be right up your street: https://www.reddotforum.com/content/2018/08/using-m-lenses-on-the-leica-cl-new-city-new-camera-familiar-glass/
When I first got the M8, its 1.5 factor made wide angles a problem, so I got a Zeiss 21/2.8 to use as a ~35 mm equivalent.  I liked it and still have it.  It should also be good on the CL.  Fairly contrasty with clean shadows.  Back then the digitals had insufficient dynamic range so some folks argued for "sunny day" lenses that would fill in the shadows a bit with a boost from flare.  Now we just push on the shadow slider.  The Zeiss has clean shadows and wasn't a sunny day lens.
