For four years I have waited for this day which has not come
M28
One simple thing and Leica would sell many many cameras: get the 240 package in the M6 footprint.
Otherwise my M9 is fine......except for that damn whirr....how do you stop that again?
What do you mean with " footprint " . The M 240 has the same footprint in my idea. It's an M and isn't more than a few mm bigger. Making the M 240 smaller is not going to happen for reasons already discussed in this forum.
  • Replies 339
  • Created
  • Last Reply
 It may not happen, but there is no technical reason. Compare closely a Sony A7 and M240. Do you really think the M240 is as small and light as it can be? Coolaid.
The thickness of film vs sensor has nothing to do with the issue. It's the thickness of skull LOL
If you think the digital Ms have the same footprint as M6, you are not holding both in your hands. The M6 is a dream. The M9 (which I love) is a pig. :)
Even the M6 is borderline, Barnack size would be better yet.
They can still make the big ones for those who "like the heft" :)
I made a comparison between an M (Typ 240) and a Sony NEX-5N. I attached an adapter to the Sony so that I could mount an M lens. From lens socket to the display surface, the Sony NEX was thicker than the M (Typ 240).
You can not shrink the distance between the lens socket and the sensor surface. It appears that shrinking the distance between the sensor surface and the display surface is not an easy task, either.
No amount of LOLing will make the Sony thinner or your post friendlier or better informed.
I made a comparison between an M (Typ 240) and a Sony NEX-5N. I attached an adapter to the Sony so that I could mount an M lens. From lens socket to the display surface, the Sony NEX was thicker than the M (Typ 240). [...]
When i hold my A7s mod it feels significantly thinner than my M240. The adapter is like an extension of the lens and can even be a real extension of it when it has a focus ring for closeups like the VM-E adapter.
Just for sake of illustration:
The Sony is in this particular respect better than the Leica M: it has the old-fashioned mark on top of the body which indicates the focal plane. You can clearly see that the distance from the focal plane to the back of the camera is quite a bit longer on the Sony than on the Leica. Hence, it's conceivable that the Leica body could indeed be shrunk by recessing the front of the body. However, in order to achieve the proper distance between lens and focal plane, the body would sprout a protrusion with the lens mount. How they would couple the lens to the RF is not quite clear; I presume the protrusion would have to be quite a bit wider than the mount. What would you gain? Would you have to add the ugly griplike body part which makes the actual girth of the Sony even greater?
Just give me the option for top and bottom in carbon fiber showing sexy weave pattern, saving 100-200 grams and I will open my wallet.
Edit: it may be a good business for accessory vendors. I guess there will be a market
For me there is no difference in holding the camera if it's a MP or an M240/M9/M8 because all are hold in the smae way, like mr. Frank demonstrates: http://precise-moment.com/wp-content/uploads/2015/02/robertfrank-at-moma.jpg
The few milimeters at the right hand don't make a difference to me.The fingers are easily capable to adjust between MP and M 240.  The camera is supported by the left hand.
I cannot make a comparisson with a Sony A7 , because it does not have an " M " viewfinder.
No. it is not. The sensor is as wafer thin as film.
But that is not exactly true if you include everything that makes up a functional sensor such as the glass and the electronics, is it?
Personally I don't find the size of the M an issue at all, given I can easily fit it, RSS L-grip attached, along with three of its best buds into the rather modestly sized Billingham Digital.  If anything, should the M happen to go on a diet, I'd far prefer a little less weight to a more svelte silhouette.
Or just the packaging of the chip. A sensor is much more than just a piece of silicon.
Makes not one bit of difference. The wafer is as thin or thinner than film. The ONLY difference is it is dead flat.
Yep. In fact they already did this, subtly. The M digital lens mount protrudes about 2mm more from the front than on the film bodies, which are almost flush. Epson's R-D1 lens mount protrudes about 4mm - but then, they were designing from scratch with their own RF mechanism, and could allow for that difference.
https://upload.wikimedia.org/wikipedia/commons/4/48/Epson_R-D1_Digital_Rangefinder_Camera.jpg
BTW - that Epson also has an image plane indicator between the dials - notice there is about 5mm of thickness behind the image plane even on the top plate (and the body steps out on the back to make it even thicker - just cosmetically disguised).
Yes, the image plane of a digital sensor (the front surface of the silicon) is only nanometers thick. What makes the cameras thick is the package for the sensor (casing and contacts), the circuit board behind it, the LCD and its CB, etc. etc. http://www.pcpulab.mydns.jp/main/images/ccd.jpg
(The cover glass and shutter are irrelevant, since they are in front of the image plane. They only affect lens clearance (which is why some collapsible lenses or the deep-seated Zeiss Hologon can be bad news for the shutters).
Basically, an M digital body must be about 28mm thick from lens mount surface to image plane - the standard since 1954. Plus the sensor thickness. Plus the sensor mount thickness. Plus the CB thickness. Plus back plate thickness. Plus the LCD thickness.
Plus any other considerations - in the M240 and its variants, the body thickness is set as much by the larger battery stacked with the SD card holder as by anything else.
https://www.ephotozine.com/articles/leica-m-typ-240-review-24007/images/highres-Leica-M-Typ-240-Black-7_1392224144.jpg
Trust me. Leica knows their customers want as thin an M body as possible. And they know the viewfinder needs as short a "tunnel" as possible. If Leica could make a thinner digital M body with today's materials and functional requirements - they'd have done it already.
But it doesn't hurt to keep asking. ;)
