blum Posted July 3, 2014 Share #281 Posted July 3, 2014 Advertisement (gone after registration) I updated the firmware and noticed this problem: When I turned the auto exposure compensation from ON to OFF, I was no longer able to use the thumb knob to change EV (good). When I turned the auto exposure compensation back ON, it continued to register as OFF but the thumb knob was able to change EV (strange). However, changes in EV did not produce changes in the images (bad). Has anyone else had a similar problem? Link to post Share on other sites More sharing options...
Advertisement Posted July 3, 2014 Posted July 3, 2014 Hi blum, Take a look here Release of 2.0.1.5 Firmware Update. I'm sure you'll find what you were looking for!
r7photo Posted July 3, 2014 Share #282 Posted July 3, 2014 Image Quality pop good bad since upgrade ? Out shooting testing today Link to post Share on other sites More sharing options...
Peter H Posted July 3, 2014 Share #283 Posted July 3, 2014 Peter, I understood, but was only answering your direct question about getting the FW on the card, not preserving profiles, not preserving file number…or other issues covered in other comments, which prove you're not the only one. I don't set user profiles, content to work with basic camera settings. It took me less than a minute to scroll through my settings to get them back to my preferences. I had to go into settings anyway, since there are now some good new ones to choose. Jeff Yes, I didn't appreciate that the settings or anything else would be affected, so I didn't take any measures to prevent it from happening. I think that's the issue: if you're not aware of the potential problem you'll only find out about it when it's too late. I only set profiles for non-coded lenses and one basic profile to ensure the most common settings are preserved, so it wasn't hard to reinstate them. But some people may have a whole host of different features embedded in different profiles which could be a real pain to remember, let alone re-install. Link to post Share on other sites More sharing options...
gautier Posted July 3, 2014 Share #284 Posted July 3, 2014 13) I don't use GPS or the grip, but updates to the location issues with JPEG have been addressed. Other cameras delete the location when there is no GPS signal and leave the EXIF data field blank, Leica chose to use the last location instead. Now, the location is deleted after 5min if no GPS signal is present. Somebody else will have to comment on this.Bad news for me No option to change this delay of 5 min? 24h was certainly long but 5 min is not convenient Link to post Share on other sites More sharing options...
lct Posted July 3, 2014 Author Share #285 Posted July 3, 2014 When I turned the auto exposure compensation from ON to OFF, I was no longer able to use the thumb knob to change EV (good). When I turned the auto exposure compensation back ON, it continued to register as OFF but the thumb knob was able to change EV. Try SET menu / Exposure compensation / SET / Direct Adjustment: Off / SET Link to post Share on other sites More sharing options...
LocalHero1953 Posted July 3, 2014 Share #286 Posted July 3, 2014 I updated the firmware and noticed this problem: When I turned the auto exposure compensation from ON to OFF, I was no longer able to use the thumb knob to change EV (good). When I turned the auto exposure compensation back ON, it continued to register as OFF but the thumb knob was able to change EV (strange). However, changes in EV did not produce changes in the images (bad). Has anyone else had a similar problem? I had to check this to see what the issue is. In the SET menu, what you see at the top level is the EV compensation actually set: OFF (=0), +0.3, -0.3 etc. if you go to the next level down, you can also set Direct Adjustment to On (use the thumb wheel directly) or Off (use the thumb wheel only while pressing the button on the front). I suspect that in your penultimate sentence, the Off you saw simply meant the EV was set to Off (=0). I can't explain the fact that changes in the EV had no effect on the images: perhaps try again? Link to post Share on other sites More sharing options...
Rick Posted July 3, 2014 Share #287 Posted July 3, 2014 Advertisement (gone after registration) I updated the firmware and noticed this problem: When I turned the auto exposure compensation from ON to OFF, I was no longer able to use the thumb knob to change EV (good). When I turned the auto exposure compensation back ON, it continued to register as OFF but the thumb knob was able to change EV (strange). However, changes in EV did not produce changes in the images (bad). Has anyone else had a similar problem? This is working correctly. This is a discussion we had in beta. The fact that EV displays from -3.0 to OFF to +3.0. The zero setting is displayed as "OFF." The display of "OFF" doesn't mean that the EV function with the thumbwheel is off, only that the EV value is zero (or off). A user has to go into the settings to set the thumbwheel to OFF. These two uses of the word "OFF" in different locations, and having a different meaning, seems to be confusing. Some thought that the EV should read "0" instead of "OFF." Minor detail once you understand the way it is setup. Link to post Share on other sites More sharing options...
mirekti Posted July 3, 2014 Share #288 Posted July 3, 2014 Good: Lots of great stuff in this fw. Bad: WB still as it was, but I can live with it. Lightroom colors still suck. I wish Leica could do something with the latter. It is the software that is delivered with the camera after all. Link to post Share on other sites More sharing options...
Rick Posted July 3, 2014 Share #289 Posted July 3, 2014 Good:Lots of great stuff in this fw. Bad: WB still as it was, but I can live with it. Lightroom colors still suck. I wish Leica could do something with the latter. It is the software that is delivered with the camera after all. Good: DNG Colors are still great! WB daylight is good/great, mixed and tungsten, meh. Link to post Share on other sites More sharing options...
viramati Posted July 3, 2014 Share #290 Posted July 3, 2014 Just to demonstrate the difference here's one from the M and one from M8. Both taken with an iphone, no editing. The M framelines was "clearer" than my M8 and M6 but now I find it distractingly bright. I have noticed no change in the brightness levels between the old and new firmware and have been using the updated version for a while. Link to post Share on other sites More sharing options...
lct Posted July 3, 2014 Author Share #291 Posted July 3, 2014 Just to demonstrate the difference here's one from the M and one from M8. Both taken with an iphone, no editing. The M framelines was "clearer" than my M8 and M6 but now I find it distractingly bright. M240 framelines are not the lit the same way as M6 and M8 and do appear more contrasty in most circumstances. I did not notice any difference between firmwares 2.0.0.12 and 2.0.1.5 though. Link to post Share on other sites More sharing options...
chris_tribble Posted July 3, 2014 Share #292 Posted July 3, 2014 +1 Link to post Share on other sites More sharing options...
sillbeers15 Posted July 4, 2014 Share #293 Posted July 4, 2014 MENU/Light Metering Mode/Classic/LV disables Thanks RickLeica. Link to post Share on other sites More sharing options...
wlaidlaw Posted July 4, 2014 Share #294 Posted July 4, 2014 Just to demonstrate the difference here's one from the M and one from M8. Both taken with an iphone, no editing. The M framelines was "clearer" than my M8 and M6 but now I find it distractingly bright. You might find the framelines in red less distracting. I know I do. Wilson Link to post Share on other sites More sharing options...
ski542002 Posted July 4, 2014 Share #295 Posted July 4, 2014 After update, 2 issues. -Using the MF grip. After update, my gps will not auto-set my time/timezone. Turned camera off/on, removed/installed battery. With gps on, I can still manually change date/time. Before update, with gps on date/time was greyed out because control defaulted back to the gps. -After update, I can no longer change my file name prefex. Default is "L". I need t change it to "M" to allow me to sort files when shooting M9 & M20 for the same job. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted July 4, 2014 Share #296 Posted July 4, 2014 I've now got video OFF in both M240s, direct exposure correction ON in both, and one of them otherwise turned into a nice CMOS M9, (classic exposure metering and LV OFF as well). The other is the LV mostly on machine. But it still takes 1-2 sec between shots, even when I set review OFF. What's the trick to getting faster shooting with LV on? scott Link to post Share on other sites More sharing options...
digitalfx Posted July 4, 2014 Share #297 Posted July 4, 2014 I've now got video OFF in both M240s, direct exposure correction ON in both, and one of them otherwise turned into a nice CMOS M9, (classic exposure metering and LV OFF as well). The other is the LV mostly on machine. But it still takes 1-2 sec between shots, even when I set review OFF. What's the trick to getting faster shooting with LV on? scott no trick, its a hardware limitation. Just use a fast card, but otherwise its slow. Link to post Share on other sites More sharing options...
jaapv Posted July 4, 2014 Share #298 Posted July 4, 2014 After update, 2 issues.-Using the MF grip. After update, my gps will not auto-set my time/timezone. Turned camera off/on, removed/installed battery. With gps on, I can still manually change date/time. Before update, with gps on date/time was greyed out because control defaulted back to the gps. -After update, I can no longer change my file name prefex. Default is "L". I need t change it to "M" to allow me to sort files when shooting M9 & M20 for the same job. Menu>file numbering>change filename>M Link to post Share on other sites More sharing options...
scott kirkpatrick Posted July 4, 2014 Share #299 Posted July 4, 2014 no trick, its a hardware limitation. Just use a fast card, but otherwise its slow. Faster than a 45 MB/sec Extreme? scott Link to post Share on other sites More sharing options...
digitalfx Posted July 4, 2014 Share #300 Posted July 4, 2014 Faster than a 45 MB/sec Extreme? scott I use Extreme Professional 90MB/s...it might help a bit. Link to post Share on other sites More sharing options...
