Guest NEIL-D-WILLIAMS Posted September 26, 2013 Share #1 Posted September 26, 2013 Advertisement (gone after registration) Guys I am going to try and get a Diopter for my new M and have some questions to ask before I head over to the Leica Store; 1/. Should I test it in a bright room or a dark room 2/. Should I concentrate on getting the information in the viewfinder crystal clear i.e. shutter speed or should I concentrate on something at say 3,6 or 10 feet away I have good vision in my right eye, but wear glasses for reading Any help or other information would be much appreciated Quote Link to post Share on other sites More sharing options...
Advertisement Posted September 26, 2013 Posted September 26, 2013 Hi Guest NEIL-D-WILLIAMS, Take a look here Help needed selecting a Diopter. I'm sure you'll find what you were looking for!
thighslapper Posted September 26, 2013 Share #2 Posted September 26, 2013 Get a grip Neil. 1. Trying it in the dark might not be helpful 2. Are you taking pictures of the viewfinder LCD read-out ? I assume you were tanked up again (or hungover) when you posted this ..... Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted September 26, 2013 Share #3 Posted September 26, 2013 Get a grip Neil. WTFITAA..............I asked for help not a piss taking Quote Link to post Share on other sites More sharing options...
azzo Posted September 26, 2013 Share #4 Posted September 26, 2013 Just take some pics! Quote Link to post Share on other sites More sharing options...
Luke_Miller Posted September 26, 2013 Share #5 Posted September 26, 2013 I wear glasses for reading as well, while my distance vision is fine. I use diopters on my M9 and Monochrom to aid in focusing. I believe the Leica rangefinder has a built in correction of -0.5 diopters. I need a plus correction in order to see clearly enough to focus properly. With a Nikon DSLR I need the full correction of my reading glasses, but with my Leica much less correction is required. With the Leica I need a diopter that corrects my vision for objects at about 1 meter distance. I have no problem seeing the information displayed in the finder with or without correction, but I have no experience with the new M. Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted September 26, 2013 Share #6 Posted September 26, 2013 Just take some pics!Meaning take some pictures and see if what I am focusing on is what is in focus..........rightAnd if not try it with a Diopter Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted September 26, 2013 Share #7 Posted September 26, 2013 Advertisement (gone after registration) I wear glasses for reading as well, while my distance vision is fine. I use diopters on my M9 and Monochrom to aid in focusing. I believe the Leica rangefinder has a built in correction of -0.5 diopters. I need a plus correction in order to see clearly enough to focus properly. With a Nikon DSLR I need the full correction of my reading glasses, but with my Leica much less correction is required. With the Leica I need a diopter that corrects my vision for objects at about 1 meter distance. I have no problem seeing the information displayed in the finder with or without correction, but I have no experience with the new M. Thanks Luke When I mentioned in my first post about getting the information sharp in the Viewfinder that is exactly what I do when I get a new DSLR; so figured that is what I should do with the Rangefinder………….apparently not!!! I did try a few Diopters in the Leica store when I had my M9-P (6 months ago) but to be honest they didn’t make any difference unless I tried the +2 or -2 and then it was horrible The Leica store in KL is also dark so that was why I asked the question about dark and bright. I also noticed that when I got my M and looked at the rangefinder patch at night I found it hard to line up the rangefinder. Anyway thanks again for your help Quote Link to post Share on other sites More sharing options...
Luke_Miller Posted September 26, 2013 Share #8 Posted September 26, 2013 With a DSLR I think the image on the focus screen is very close, and my reading correction (+2.0) works well. With my M9/Monochrom the focus patch and the image of the subject seem more distant, so a +1 diopter works fine. I also use the Leica eyepiece magnifier to help with focus accuracy with my longer focal lengths. But with it I have to go to a +1.5 diopter. It does take some time to determine which diopter gives the desired result. If possible deal with a store that will let you return or exchange diopters. I ended up with a collection of +0.5, +1.0, +1.5, and +2.0 Quote Link to post Share on other sites More sharing options...
jaapv Posted September 26, 2013 Share #9 Posted September 26, 2013 (edited) Thanks LukeWhen I mentioned in my first post about getting the information sharp in the Viewfinder that is exactly what I do when I get a new DSLR; so figured that is what I should do with the Rangefinder………….apparently not!!! I did try a few Diopters in the Leica store when I had my M9-P (6 months ago) but to be honest they didn’t make any difference unless I tried the +2 or -2 and then it was horrible The Leica store in KL is also dark so that was why I asked the question about dark and bright. I also noticed that when I got my M and looked at the rangefinder patch at night I found it hard to line up the rangefinder. Anyway thanks again for your help The 0,5 dioptre that is built into the M rangefinder is there for optical reasons. The viewfinder is optimized for standard vision, so the value must be disregarded for correction lenses. If you are not in a position to use the tryout lenses of your optician to determine the correct value or even use over-the-counter reading glasses, the strength must be calculated for a distance of 2 meters, which Is the virtual distance of the viewfinder markings. For a magnifier deduct 0.5 dioptre. The image at infinity is at infinity in the viewfinder as well. Edited September 26, 2013 by jaapv Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted September 26, 2013 Share #10 Posted September 26, 2013 (edited) The 0,5 dioptre that is built into the M rangefinder is there for optical reasons. The viewfinder is optimized for standard vision, so the value must be disregarded for correction lenses. If you are not in a position to use the tryout lenses of your optician to determine the correct value or even use over-the-counter reading glasses, the strength must be calculated for a distance of 2 meters, which Is the virtual distance of the viewfinder markings. For a magnifier deduct 0.5 dioptre. The image at infinity is at infinity in the viewfinder as well. Jaap I have a very user friendly optician, so trying this or that is not an issue; so my understanding from what you say is that if my corrected vision for two meters is say + 1 then a +0.5 Diopter should be the best option for me and if my corrected vision is say +0.5 then just stick with what came with the camera Thanks in advance Edited September 26, 2013 by NDWgolf Quote Link to post Share on other sites More sharing options...
CaptZoom Posted September 26, 2013 Share #11 Posted September 26, 2013 JaapI have a very user friendly optician, so trying this or that is not an issue; so my understanding from what you say is that if my corrected vision for two meters is say + 1 then a +0.5 Diopter should be the best option for me and if my corrected vision is say +0.5 then just stick with what came with the camera Thanks in advance I think what Jaapv is saying is to disregard the camera's built-in diopter completely and get what your normal diopter should be (determined by your optician or through experience). One more important thing to take into consideration: astigmatism. If you have astigmatism (I do), than the Leica diopter a will not work. There's a third party that makes diopter a for individuals with astigmatism. I don't have a link, but I'm sure a quick search will get you to it. Quote Link to post Share on other sites More sharing options...
jaapv Posted September 26, 2013 Share #12 Posted September 26, 2013 (edited) That is exactly what I am saying The viewfinder is optimally configured for persons with a standard normal vision. So it should be treated as a correctionless entity in any calculation, regardless of the values that are used to obtain the neutral vision that it has. If your correction for two meters is for instance + 2.0 dioptre, you should be using +2.0 dioptre. However, nature does not always follow theory,and there are intermediate values , so do use your optician's tryout lenses to check if your choice is optimal. Edited September 26, 2013 by jaapv Quote Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted September 26, 2013 Share #13 Posted September 26, 2013 That is exactly what I am saying The viewfinder is optimally configured for persons with a standard normal vision. So it should be treated as a correctionless entity in any calculation, regardless of the values that are used to obtain the neutral vision that it has.OK got it thanks Quote Link to post Share on other sites More sharing options...
Jeff S Posted September 26, 2013 Share #14 Posted September 26, 2013 Still a good idea to try different diopters in person; there's math, and then there's an individual's eye. Just see which one allows you to see and use the focus patch most clearly. If it's not in focus, the rest won't matter. I prefer glasses since I wear them anyway for sun sensitivity, distance and astigmatism. That way I don't have to keep taking them on or off. And I don't like contacts. Fortunately, for me, the same prescription that fixes everything else also lets me see the focus patch perfectly. Each person is different, and only trying will determine what's right for you. BTW, the diopter that corrects for astigmatism is the Walter RX eyepiece. Jeff 2 Quote Link to post Share on other sites More sharing options...
lct Posted September 27, 2013 Share #15 Posted September 27, 2013 Always added 0.5 to my corrected vision at infinity. Works fine for me. Quote Link to post Share on other sites More sharing options...
microview Posted September 27, 2013 Share #16 Posted September 27, 2013 Still a good idea to try different diopters in person; there's math, and then there's an individual's eye. Just see which one allows you to see and use the focus patch most clearly. If it's not in focus, the rest won't matter. Absolutely. Let's hope your stockist has a good selection. I bought a +1.0 dioptre three years ago but felt the view could be sharper, so last week I tried a +2.0. It was so much clearer in the shop and in full daylight I found things much easier to focus. So for the older person eyesight does deteriorate and it's worth checking dioptre strength from time to time. Quote Link to post Share on other sites More sharing options...
payasam Posted September 27, 2013 Share #17 Posted September 27, 2013 If you're going to the Leica store, just buy the one that works best. No need of an optician. As Jaap says, your target should be two metres away. Quote Link to post Share on other sites More sharing options...
Luke_Miller Posted September 27, 2013 Share #18 Posted September 27, 2013 My confusion comes the fact that I need no correction to clearly see an object at two meters distance, but I need a +0.5 or +1.0 diopter on my M9/MM to be able to see it clearly enough through the rangefinder to focus on it. Quote Link to post Share on other sites More sharing options...
payasam Posted September 27, 2013 Share #19 Posted September 27, 2013 Luke, when you look through the finder of a camera, you look through an optical system. It is bound to be different from looking at an object with your bare eyes. Quote Link to post Share on other sites More sharing options...
CaptZoom Posted September 27, 2013 Share #20 Posted September 27, 2013 To add to what payasam said, you're focusing at a set distance when looking through the viewfinder, and this distance is typically not the same as the object you want to focus on. My confusion comes the fact that I need no correction to clearly see an object at two meters distance, but I need a +0.5 or +1.0 diopter on my M9/MM to be able to see it clearly enough through the rangefinder to focus on it. Quote Link to post Share on other sites More sharing options...
