Hello!
I am looking for a reliable solution to make the images from the Leica Q3 28mm wider. An adapter or converter? I do not want a software solution (stitching, panoramas).
I often take pictures of architecture or interior.
I have read that Ricoh or Fuji offers wide-angle adapters, but I have also read that they do not work properly on the Q3 (???).
Does anyone have personal experience? What would definitely work?
Thank you very much!
x
Posted (edited)
I had and still have the Leica Dlux-4 with the WA-adapter from Panasonic. This combination results in a 24mm (FF-speech) view.  The quality of the pictures is very good. In this combination, the only difficulty was of mechanical nature. The screw thread of this PanaLeica, where the adapter has to be mounted, is made of plastic.
Edited by jankap
2 hours ago, -MR- said:
Hello!
I suspect you would be better looking at a different camera as I think IQ would be badly affected . This maybe more so due to the Q3 distortion control.
3 hours ago, Leslie22 said:
I know you say you don’t want stitching , But I have recently discovered Pano with Lightroom ….. with practice it works brilliantly with my Q3 43 , solved that too narrow problem. (Just saying)
I've had the same experience, although I haven't used it with my Q2.  I was shooting a cross-country fun run when a group of four participants stopped and asked for a for a group shot.  Unfortunately, they were much too close for my 300mm lens. The most I could capture in a single frame were two of the individuals.  I took a three-shot panorama and Lightroom produced a very nice group shot that was indistinguishable from a single image from a wider lens.
14 minutes ago, -MR- said:
Thank you very much for your help ... but what about these Ricoh or Fuji Adapters? Does nobody use them?
I have a friend who has used both and they are very good, if a little inelegant in use. They are also camera specific (and crop sensor ones) sadly, so are no use to a Q user
One other way to have an ultra wide on hand when you need one, is a modern phone. The .5 camera on the iphone equates to about a 13mm FF and is surprisingly good.
Someone here tested the Fuji one on a Q a while back and reported on it.  Apparently the results were not that great.  I had the Q3 28 and never got along with that focal length - always preferring something tighter or wider.  So now I have the q3 43 and the SL3/21 APO.  Not recommending that as a solution, though.
I have experience with many either macro, wide angle lenses and glass domes, but for underwater use what does not change anything on the principle.
I believe that it's possible to build a wide angle screw on lens what is (under normal) circumstances not degrading the photo,
but the add-on lens (or dome on a underwater housing as well) must be designed for a given lens and will work only on this lens, obviously also using the best manufacturing materials and techniques.
Unfortunately there is no acceptable optical quality WA add-on lens for the Q series i am aware of.
Chris
Posted (edited)
Leica would earn trillions of deutsche mark if they would build a wide angle converter for Q3  instead of soft release buttons for 80 euro.
Edited by -MR-
On 3/13/2025 at 8:57 AM, -MR- said:
Hello!
A different camera and lens would be a better solution. The Fuji XT series comes to mind.
Posted (edited)
Too many buttons and dials. Too confusing for german brain.
Edited by -MR-
  • Haha 1
I imagine both demand would be very low, size bigger, camera heavier and quality affected. Also a higher price : so I don't think so....
Trillions?  Really?  Leica annual revenue was € 554 million in 2023, so I doubt they would earn trillions from producing a small adaptor.
Oh, and Germany stopped using the Deutsch Mark on January 1st, 1999 🤣
  • Haha 2
Posted (edited)
Perhaps he should wait for the Q21 or even the Q15.🤩
Here a 4 images stitch. Handheld!
On the right side of the picture, my friends (of the left side) were waiting for me.
Edited by jankap
Long ago, friends planned a voyage to Italy. They calculated to take a sum of 800 to 900 Dmark with them. At the bank HE discovered, that with somewhat more Dmark, they could travel as millionaires (in Lire). That was a nice feeling, they said.
