Kwesi Posted March 29, 2023 Share #1241 Posted March 29, 2023 Advertisement (gone after registration) Just now, hdmesa said: I have the CV 75 1.9 inbound, arriving tomorrow or Friday. If my M11 works with the 75 without freeing, then I will know it's something about the 35 1.5 causing the problem. If that's the case, I will have to decide whether to just sell it or have it 6-bit coded. Since my M11 is not freezing during use, it absolutely has to be something the camera does at startup. Aside from it checking the SD card, I can't think of a more obvious culprit than the camera scanning for the 6-bit code. I also still need to try turning Lens Detection "off" every time before attaching the 35 1.5 to see if that fixes the issue. I tried that under previous firmware but not 1.6.1. Im surprised cosine put the text in that spot for that lens - clearly someone wasn't thinking Link to post Share on other sites More sharing options...
Advertisement Posted March 29, 2023 Posted March 29, 2023 Hi Kwesi, Take a look here M11 freeze issues [Merged] . I'm sure you'll find what you were looking for!
Qlan Posted March 29, 2023 Share #1242 Posted March 29, 2023 3 minutes ago, hdmesa said: I have the CV 75 1.9 inbound, arriving tomorrow or Friday. If my M11 works with the 75 without freeing, then I will know it's something about the 35 1.5 causing the problem. If that's the case, I will have to decide whether to just sell it or have it 6-bit coded. Since my M11 is not freezing during use, it absolutely has to be something the camera does at startup. Aside from it checking the SD card, I can't think of a more obvious culprit than the camera scanning for the 6-bit code. I also still need to try turning Lens Detection "off" every time before attaching the 35 1.5 to see if that fixes the issue. I tried that under previous firmware but not 1.6.1. I had similar freezes (at startup) with a Voigtlander 28mm f/2 Ultron II and a Voigtlander 50mm f/2 APO. Also Lens Detection Off doesn't matter, it will still try to read the code... I think I still had freezes when I set it to Off. Link to post Share on other sites More sharing options...
hdmesa Posted March 29, 2023 Share #1243 Posted March 29, 2023 Just now, Qlan said: I had similar freezes (at startup) with a Voigtlander 28mm f/2 Ultron II and a Voigtlander 50mm f/2 APO. Also Lens Detection Off doesn't matter, it will still try to read the code... I think I still had freezes when I set it to Off. Me, too, but I only tried turning it off under previous firmware versions. Did you try turning it off with 1.6.1? I'm not expecting any change, but you never know. Link to post Share on other sites More sharing options...
lct Posted March 29, 2023 Share #1244 Posted March 29, 2023 3 minutes ago, hdmesa said: Did you try turning it off with 1.6.1? Depends if the lens is hand-coded or not. If it is so, the camera will give priority to hand-coding. If it is not, the camera will keep the code it has in memory, if any, or will consider lens detection "Off". Link to post Share on other sites More sharing options...
hdmesa Posted March 29, 2023 Share #1245 Posted March 29, 2023 Speaking of lens detection: Is it normal to turn lens detection "off" and expect it to stay off? If I have a 6-bit coded lens attached, it's always back on Auto when I turn the camera back on. Link to post Share on other sites More sharing options...
Qlan Posted March 29, 2023 Share #1246 Posted March 29, 2023 6 minutes ago, hdmesa said: Speaking of lens detection: Is it normal to turn lens detection "off" and expect it to stay off? If I have a 6-bit coded lens attached, it's always back on Auto when I turn the camera back on. Yes, that is normal behavior (even though I and others disagree and would like it to stay off). It's explained in the manual. And this is in my opinion the source of all evils, since the camera continuously tries to read the code regardless of what setting you have. 1 Link to post Share on other sites More sharing options...
hdmesa Posted March 29, 2023 Share #1247 Posted March 29, 2023 Advertisement (gone after registration) Just now, Qlan said: Yes, that is normal behavior (even though I and others disagree and would like it to stay off). It's explained in the manual. And this is in my opinion the source of all evils, since the camera continuously tries to read the code regardless of what setting you have. That's what I thought. From now on, when I switch from a 6-bit coded lens to an uncoded one, I will turn off lens detection, turn off the camera, then switch lenses. I confirmed it stays in the "off" state when the next lens attached is non-coded. I don't know if this will stop the freezing with uncoded lenses, but I'll try and report back. So far so good on several on/off cycles with the 35 1.5. Link to post Share on other sites More sharing options...
lct Posted March 29, 2023 Share #1248 Posted March 29, 2023 15 minutes ago, hdmesa said: Speaking of lens detection: Is it normal to turn lens detection "off" and expect it to stay off? If I have a 6-bit coded lens attached, it's always back on Auto when I turn the camera back on. The camera is supposed to give priority to coded vs uncoded lenses in my understanding. Rightly so IMHO, because current Leica lenses are coded and current CV & ZM lenses allow for hand-coding easily. Link to post Share on other sites More sharing options...
Qlan Posted March 29, 2023 Share #1249 Posted March 29, 2023 8 minutes ago, hdmesa said: That's what I thought. From now on, when I switch from a 6-bit coded lens to an uncoded one, I will turn off lens detection, turn off the camera, then switch lenses. I confirmed it stays in the "off" state when the next lens attached is non-coded. I don't know if this will stop the freezing with uncoded lenses, but I'll try and report back. So far so good on several on/off cycles with the 35 1.5. Btw, when you test this, don't just turn the camera on and off, but also remove the lens and attach it (from time to time). In my experience (and yours as well it seems like), a freeze is more likely to happen after changing a lens, so maybe there's something to do with the lens detection contact point. 1 Link to post Share on other sites More sharing options...
hdmesa Posted March 29, 2023 Share #1250 Posted March 29, 2023 5 minutes ago, lct said: The camera is supposed to give priority to coded vs uncoded lenses in my understanding. Rightly so IMHO, because current Leica lenses are coded and current CV & ZM lenses allow for hand-coding easily. That makes sense. But also think about the person who wants to have their lens detection always off even with 6-bit coded lenses. They would have to turn lens detection off every time they turn on the camera. That seems like an odd way to engineer it to me. I guess Leica's ethos/intent is for corrections to always be on for their lenses if so coded. Link to post Share on other sites More sharing options...
Qlan Posted March 29, 2023 Share #1251 Posted March 29, 2023 Just now, hdmesa said: That makes sense. But also think about the person who wants to have their lens detection always off even with 6-bit coded lenses. They would have to turn lens detection off every time they turn on the camera. That seems like an odd way to engineer it to me. I guess Leica's ethos/intent is for corrections to always be on for their lenses if so coded. That doesn't work. You cannot turn it off if you have a lens with a 6-bit code. It will jump back to Auto. Link to post Share on other sites More sharing options...
hdmesa Posted March 29, 2023 Share #1252 Posted March 29, 2023 2 minutes ago, Qlan said: That doesn't work. You cannot turn it off if you have a lens with a 6-bit code. It will jump back to Auto. It stays off until you power it off and back on (or perhaps until it wakes from sleep), at least on 1.6.1. Link to post Share on other sites More sharing options...
Qlan Posted March 29, 2023 Share #1253 Posted March 29, 2023 Just now, hdmesa said: It stays off until you power it off and back on (or perhaps until it wakes from sleep), at least on 1.6.1. Hum that's new to me. I'll try it out. Does it stay off even after taking a picture, or letting the camera be idle for a few seconds? Link to post Share on other sites More sharing options...
lct Posted March 29, 2023 Share #1254 Posted March 29, 2023 (edited) 9 minutes ago, hdmesa said: That makes sense. But also think about the person who wants to have their lens detection always off [...] Happens to me with my few uncoded lenses (S-A 21/3.4, T-E 135/4, Konica 50/2). The camera will then keep the code it has in memory, if any, or consider lens detection "Off". Edited March 29, 2023 by lct Link to post Share on other sites More sharing options...
hdmesa Posted March 29, 2023 Share #1255 Posted March 29, 2023 Just now, Qlan said: Hum that's new to me. I'll try it out. Does it stay off even after taking a picture, or letting the camera be idle for a few seconds? Yes, but I also have all sleep settings turned off. Link to post Share on other sites More sharing options...
elmars Posted March 29, 2023 Share #1256 Posted March 29, 2023 vor 6 Stunden schrieb hdmesa: So far this morning I haven't had any freezes after trying some different things in combination. Not sure if it will last, but usually it would have already frozen on the first or second startup the morning: Coded lens Sleep settings off for display and camera Saved a user profile (realized I hadn't done that yet under 1.6.1) Went back to Multi-field metering instead of Highlight-weighted Not using the thumb grip (crazy, but could the thumb grip be hitting a contact on the hotshoe and causing a freeze?) Using the Sandisk 64 UHS-II while I wait on the Delkin Black I use sleep settings (formerly 10 min, now 30 min) and Multifield metering as well as Highlight weighted. These settings are imho not the reason for the freezes. 1 Link to post Share on other sites More sharing options...
hdmesa Posted March 29, 2023 Share #1257 Posted March 29, 2023 1 minute ago, elmars said: I use sleep settings (formerly 10 min, now 30 min) and Multifield metering as well as Highlight weighted. These settings are imho not the reason for the freezes. Thanks, yes, my next step is to now turn sleep back on. I think it's directly linked to leaving lens detection set to Auto when using a non-coded lens. Previous to 1.6.1, turning lens detection off didn't help, but it seems to now. 1 Link to post Share on other sites More sharing options...
hdmesa Posted March 29, 2023 Share #1258 Posted March 29, 2023 (edited) ^ Which begs the question, what difference is there between the Auto and Off settings for Lens Detection? They seem exactly the same to me except that when set to Auto and it doesn't detect a 6-bit coded lens, it will show "Uncoded" in the menu. What value is there in it displaying "Uncoded" versus "Off"? Edited March 29, 2023 by hdmesa Link to post Share on other sites More sharing options...
hdmesa Posted March 30, 2023 Share #1259 Posted March 30, 2023 New freezing, twice with the 35 1.5 with lens coding off. So setting lens detection to off does not fix the issue of freeze on startup with uncoded 35 1.5. After it freezes on startup with the 35 1.5 attached, switching lenses to a coded lens will cause a freeze the first time it's turned on, requiring another reset. Then after that it won't freeze with the coded lens. Will test the 75 1.9 when it arrives tomorrow to see if the issue is with all uncoded lenses or just my 35 1.5. Link to post Share on other sites More sharing options...
Qlan Posted March 30, 2023 Share #1260 Posted March 30, 2023 Did you ever get a freeze when only using Leica coded lenses? 1 Link to post Share on other sites More sharing options...
