Jeff S Posted December 5, 2022 Share #421 Posted December 5, 2022 Advertisement (gone after registration) 40 minutes ago, charlesphoto99 said: In almost twenty years of using digital cameras, I've never had to use a formatter outside of the cameras. Let's face it, if this is the case with the M11, that one has to use a third party formatter, then it's a 'broken' camera. Same for all my 8 digital Leica bodies… from M8.2 through to M10-R and M10 M and SL2…never had an issue simply formatting in-camera after computer download. Jeff Link to post Share on other sites More sharing options...
Advertisement Posted December 5, 2022 Posted December 5, 2022 Hi Jeff S, Take a look here M11 freeze issues [Merged]. I'm sure you'll find what you were looking for!
Jeff S Posted December 5, 2022 Share #422 Posted December 5, 2022 2 hours ago, ianforber said: My approach seems so simple. I insert the card in the camera and format it. Job done. I’ve done this with all brands of digital cameras I’ve had over the years without any problems. I never delete an image in camera, just import them into my Mac and then put the card back in the camera and format it again. +1 Jeff Link to post Share on other sites More sharing options...
SrMi Posted December 5, 2022 Share #423 Posted December 5, 2022 2 hours ago, charlesphoto99 said: In almost twenty years of using digital cameras, I've never had to use a formatter outside of the cameras. Let's face it, if this is the case with the M11, that one has to use a third party formatter, then it's a 'broken' camera. You do not need to format it in the computer. However, if you suspect that your SD card has gotten out-of-whack, it may be good to format it with SD Memory Card Formatter before throwing it away. Again, this advice is independent of the camera band or model used. Link to post Share on other sites More sharing options...
SrMi Posted December 5, 2022 Share #424 Posted December 5, 2022 3 hours ago, ianforber said: My approach seems so simple. I insert the card in the camera and format it. Job done. I’ve done this with all brands of digital cameras I’ve had over the years without any problems. I never delete an image in camera, just import them into my Mac and then put the card back in the camera and format it again. I would not advise deleting individual images. For me, it is either "Delete All" or "Format." I switched from "Format" to "Delete All" when it was more convenient. I assume that the advantage of "Delete All" is that I could still recover images from a card I accidentally erased. Link to post Share on other sites More sharing options...
Pixeleater Posted December 5, 2022 Share #425 Posted December 5, 2022 Why is deleting an images(s) in camera not advised? Are there artifacts that affect card performance? Link to post Share on other sites More sharing options...
Jeff S Posted December 5, 2022 Share #426 Posted December 5, 2022 I shoot with my cameras, never edit with them; that’s what my PP is for. Only time I format a card in-camera is after files are successfully downloaded and safely backed up. No chance of accidental deletion/erasure. Simple. Jeff 1 Link to post Share on other sites More sharing options...
Pixeleater Posted December 5, 2022 Share #427 Posted December 5, 2022 Advertisement (gone after registration) Makes sense. Link to post Share on other sites More sharing options...
Kwesi Posted December 5, 2022 Share #428 Posted December 5, 2022 7 hours ago, charlesphoto99 said: In almost twenty years of using digital cameras, I've never had to use a formatter outside of the cameras. Let's face it, if this is the case with the M11, that one has to use a third party formatter, then it's a 'broken' camera. You don't have to change your sd card workflow to use the M11 Link to post Share on other sites More sharing options...
SrMi Posted December 5, 2022 Share #429 Posted December 5, 2022 5 hours ago, Pixeleater said: Why is deleting an images(s) in camera not advised? Are there artifacts that affect card performance? In my case: it is too easy to delete images by mistake, using LCD to evaluate an image is not optimal, and there is plenty of space on SD cards so that deletion can occur after import. There are not any performance impacts with SD cards, AFAIK. 2 Link to post Share on other sites More sharing options...
MikeMyers Posted December 6, 2022 Share #430 Posted December 6, 2022 (edited) Interesting to read all the above. What I learned to do ages ago, and have done on all my digital cameras for as long as I can remember, is when I'm done shooting for a day, to download all images to computer, then use the camera's "format" command to format the card. I was under the mistaken idea that this was a "slow format", but I accept now that it's essentially doing an "erase all". I'ts probably not necessary, but I have several digital cameras I now use (M8.2, m10, Fuji, Nikons) and I tend to re-use the same card in whatever camera I used it last time. My M8.2 cards are usually small and old, so the image counter is still useful. My M10 and Nikon cards are faster and larger. All of them nowadays are SanDisk. I doubt these are the best or fastest cards now available, but I've never had an issue with them (although they are way too big for my M8.2 camera). I've got an unrelated question I need to ask in this forum before I consider replacing my M10, especially with a Leica M taking 60-meg images. As to crashing with an M11, while it seems obvious that a poor memory card can crash a camera, is that really what is going on with these M11 crashes? Memory cards: this was my last order: https://www.amazon.com/gp/product/B07H9DVLBB/ref=ppx_yo_dt_b_asin_image_o06_s00?ie=UTF8&th=1 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited December 6, 2022 by MikeMyers Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/357248-m11-freeze-issues-merged/?do=findComment&comment=4590183'>More sharing options...
SrMi Posted December 6, 2022 Share #431 Posted December 6, 2022 2 hours ago, MikeMyers said: As to crashing with an M11, while it seems obvious that a poor memory card can crash a camera, is that really what is going on with these M11 crashes? Likely not the case. 2 Link to post Share on other sites More sharing options...
Jeremy Bunting Posted December 6, 2022 Share #432 Posted December 6, 2022 My M11 crashed just before Thanksgiving and never recovered. I was formatting the internal memory to delete some old photos when the phone went dark. After that, it refused to boot up from the internal memory. It would still boot up from a memory card but would not connect to the Fotos app. The folks at my local store said they’ve never seen the problem before, and I had to send the camera back to Leica. They’ve told me they need to replace the mainboard and I’ve been quoted four weeks. It’s pretty annoying—I’ve only had the camera a couple months. I feel they ought to have just replaced it and sold the defective unit refurbished. In the interim I’m shooting a 60 year old M2. Go figure. Link to post Share on other sites More sharing options...
lct Posted December 6, 2022 Share #433 Posted December 6, 2022 1 hour ago, Jeremy Bunting said: I feel they ought to have just replaced it Indeed. I would have required a replacement or a refund. 1 Link to post Share on other sites More sharing options...
Jeremy Bunting Posted December 6, 2022 Share #434 Posted December 6, 2022 1 hour ago, Jeremy Bunting said: My M11 crashed just before Thanksgiving and never recovered. I was formatting the internal memory to delete some old photos when the phone went dark. After that, it refused to boot up from the internal memory. It would still boot up from a memory card but would not connect to the Fotos app. The folks at my local store said they’ve never seen the problem before, and I had to send the camera back to Leica. They’ve told me they need to replace the mainboard and I’ve been quoted four weeks. It’s pretty annoying—I’ve only had the camera a couple months. I feel they ought to have just replaced it and sold the defective unit refurbished. In the interim I’m shooting a 60 year old M2. Go figure. ^^ I meant "camera," not phone, clearly. I suppose I'm more used to these issues with smartphones than I am with cameras. The idea that a camera can crash and fail to "boot" seems wrong to me. Link to post Share on other sites More sharing options...
MikeMyers Posted December 6, 2022 Share #435 Posted December 6, 2022 21 minutes ago, Jeremy Bunting said: My M11 crashed just before Thanksgiving and never recovered. I was formatting the internal memory to delete some old photos when the phone went dark. In your update, I'm not sure what you mean, but from what you wrote, it got me wondering. When the M11 stores images on the internal memory, is that treated just like an external SD memory card, from which you can delete files at will, or "format" to get it clean again? Do firmware updates ever get written to that internal memory? Does camera software ever get written there? If that memory were to somehow get "corrupted", would the M11 ever even notice it, unless/until you tried to save images to it? Can you, whenever you wish to, "clean out" that internal memory so in effect it is "wiped clean"? Does the M11 even look at that memory when the camera is booting or being shut down? I understand that the people at the store didn't know what was going on, but if you live in the USA did you call the Tech Support technicians at Leica USA ? Link to post Share on other sites More sharing options...
Jeremy Bunting Posted December 6, 2022 Share #436 Posted December 6, 2022 19 minutes ago, MikeMyers said: In your update, I'm not sure what you mean, but from what you wrote, it got me wondering. When the M11 stores images on the internal memory, is that treated just like an external SD memory card, from which you can delete files at will, or "format" to get it clean again? Do firmware updates ever get written to that internal memory? Does camera software ever get written there? If that memory were to somehow get "corrupted", would the M11 ever even notice it, unless/until you tried to save images to it? Can you, whenever you wish to, "clean out" that internal memory so in effect it is "wiped clean"? Does the M11 even look at that memory when the camera is booting or being shut down? I understand that the people at the store didn't know what was going on, but if you live in the USA did you call the Tech Support technicians at Leica USA ? I had an incorrect word in my initial post. I said "when the phone went dark," rather than "when the camera went dark." I'm unclear on whether software is stored on the same 64gb that's earmarked for photos. I am inclined to think not given my camera was booting with an SD card in, but not from internal memory. Yes, you can format the internal memory whenever you want to wipe the photos from it. It was during a routine reformat that my camera crashed and the internal memory ceased to function. I left my camera with my store on the understanding they would phone Leica USA and run the troubleshooting. No dice. Leica USA has confirmed to me that the mainboard needs to be replaced, and the camera has a fault in its electronics. Link to post Share on other sites More sharing options...
Jeremy Bunting Posted December 6, 2022 Share #437 Posted December 6, 2022 By way of update, this thread inspired me to call Leica USA again today to check on the status of the repair and shout into the void. I expressed my frustration that I was not offered a replacement camera, and instead have to wait for the defective M11 I was sold to be repaired so soon after purchase. They're shipping me a loaner M11 while mine is being repaired. I am very pleased with this outcome, though I wish it had been offered to me initially. 1 Link to post Share on other sites More sharing options...
Viv Posted December 6, 2022 Share #438 Posted December 6, 2022 My M11 has never locked up. Link to post Share on other sites More sharing options...
MikeMyers Posted December 6, 2022 Share #439 Posted December 6, 2022 4 minutes ago, Jeremy Bunting said: Leica USA has confirmed to me that the mainboard needs to be replaced, and the camera has a fault in its electronics. Maybe this is related to all the other M11 users dealing with crashes. If that's the case, that would mean a lot of M11 cameras may need a trip back to Leica to be fully corrected. That they are loaning you a replacement is wonderful service! Link to post Share on other sites More sharing options...
Jeff S Posted December 6, 2022 Share #440 Posted December 6, 2022 5 minutes ago, Jeremy Bunting said: By way of update, this thread inspired me to call Leica USA again today to check on the status of the repair and shout into the void. I expressed my frustration that I was not offered a replacement camera, and instead have to wait for the defective M11 I was sold to be repaired so soon after purchase. They're shipping me a loaner M11 while mine is being repaired. I am very pleased with this outcome, though I wish it had been offered to me initially. Old saying..,”squeaky wheel gets the grease.” Speak up with the dealer, and/or change dealers. You should have been offered a new camera or refund, by the dealer. Jeff 1 Link to post Share on other sites More sharing options...
