ynp Posted September 28, 2022 Share #81 Posted September 28, 2022 Advertisement (gone after registration) 6 hours ago, sillbeers15 said: Write to Kiona Guo @ ‘servicesupport@godox.com’ of Godox Technical support, I hope they can help you. They responded well & fast to my queries. Thank you for your help again. I will try to contact them. Link to post Share on other sites More sharing options...
Advertisement Posted September 28, 2022 Posted September 28, 2022 Hi ynp, Take a look here New Godox trigger for Leica . I'm sure you'll find what you were looking for!
sebben Posted November 26, 2022 Share #82 Posted November 26, 2022 Any update on this? Does this all work properly now? Link to post Share on other sites More sharing options...
Photoworks Posted November 27, 2022 Share #83 Posted November 27, 2022 5 hours ago, sebben said: Any update on this? Does this all work properly now? nothing change Link to post Share on other sites More sharing options...
sebben Posted November 27, 2022 Share #84 Posted November 27, 2022 9 hours ago, Photoworks said: nothing change That is disappointing. I don't want to spend the 4 times the price on profoto as I hardly use flash... Link to post Share on other sites More sharing options...
Photoworks Posted November 27, 2022 Share #85 Posted November 27, 2022 2 hours ago, sebben said: That is disappointing. I don't want to spend the 4 times the price on profoto as I hardly use flash... in manual mode is very reliable 1 Link to post Share on other sites More sharing options...
Virob Posted November 27, 2022 Share #86 Posted November 27, 2022 On 9/26/2022 at 3:27 AM, sillbeers15 said: I have resolved my problem mentioned above after a couple of trials on TCM test shots. No more colour temperature & exposure variations. I had received the TCM instruction video from Godox after writting to their technical support team. They replied me the following day. Too bad I could not share the video in my post as it exceeded the allowable file size by the forum. I have the same experience you reported earlier. When switching from TTL to M, exposure is close, be colour temperature is different. What is the solution? thanks Link to post Share on other sites More sharing options...
sillbeers15 Posted November 27, 2022 Share #87 Posted November 27, 2022 Advertisement (gone after registration) 1 hour ago, Virob said: I have the same experience you reported earlier. When switching from TTL to M, exposure is close, be colour temperature is different. What is the solution? thanks The color shift problem I had encountered was resolved after I reset up the TCM setting with a final confirmation of pressing the ‘set’ button. Link to post Share on other sites More sharing options...
stout_trapdoor9 Posted November 27, 2022 Share #88 Posted November 27, 2022 On 6/19/2022 at 4:37 AM, Pelu2010 said: Hey , this is exciting! https://leicarumors.com/2022/06/18/just-announced-new-godox-xproii-l-ttl-wireless-flash-trigger-for-leica-cameras-s-sl-sl2-m10-q2-cl-and-more-to-come.aspx/ I have been waiting so long for this trigger. I am really happy that I choose Godox. and while I was able to flash with the system now I can use HSS which is very convenient sometimes ! I ordered one and received it last week, using it with my Flashpoint strobes. Works like a bomb, no issues. Not much else to say other than it works and it works well. 1 Link to post Share on other sites More sharing options...
Virob Posted November 27, 2022 Share #89 Posted November 27, 2022 6 hours ago, sillbeers15 said: The color shift problem I had encountered was resolved after I reset up the TCM setting with a final confirmation of pressing the ‘set’ button. Thanks, I will give that a try. Is there a way to save the TCM setting for a group? So if I have an ad300 in group A and an ad100 in group B, I can only have one flash setting under TCM, either 100j or 300j. Would be great if I could save 300j to A and 100j to B. Link to post Share on other sites More sharing options...
sillbeers15 Posted November 28, 2022 Share #90 Posted November 28, 2022 3 hours ago, Virob said: Thanks, I will give that a try. Is there a way to save the TCM setting for a group? So if I have an ad300 in group A and an ad100 in group B, I can only have one flash setting under TCM, either 100j or 300j. Would be great if I could save 300j to A and 100j to B. Unfortunately only one group and one type of light can be saved under TCM. Yes. Remember to press ‘set’ button after you hv selected the lighting type from Menu. Link to post Share on other sites More sharing options...
chris7273 Posted February 17, 2023 Share #91 Posted February 17, 2023 I am gradually switching from my Nikon DSLR system to Leica M. I was using two Nikon Speedlites SB-600 in wireless mode, piloted with the integrated flash of my D7200. Pretty good results and easy to configure the flashes from the D7200 user interface. For the M, the Godox trigger looks promising. But only the M10 is mentionned in the user manual pdf. Are there M11 owners using this ? I intend to use this with two AD100Pro units (for portability) or AD200Pro. Thank you Link to post Share on other sites More sharing options...
Photoworks Posted February 17, 2023 Share #92 Posted February 17, 2023 6 hours ago, chris7273 said: For the M, the Godox trigger looks promising. But only the M10 is mentionned in the user manual pdf. Are there M11 owners using this ? I intend to use this with two AD100Pro units (for portability) or AD200Pro. M11 is not supported for TTL or HSS, so you can use any godox trigger in manual mode. Link to post Share on other sites More sharing options...
chris7273 Posted February 17, 2023 Share #93 Posted February 17, 2023 Oh 😞 Link to post Share on other sites More sharing options...
bennymod Posted February 17, 2023 Share #94 Posted February 17, 2023 Also sad that TTL does not work with older units. I have an AD600 (non pro) and the last firmware was in 2018. LIkely won't be updated to support Leica TTL. Sad because the site said "completely integrates with all Godox/Flashpoint units." Link to post Share on other sites More sharing options...
Jim B Posted February 18, 2023 Share #95 Posted February 18, 2023 I have this trigger and a ad100… I can not get it to ttl. If anyone has any luck on how to get this to work, please list the directions. Thanks Link to post Share on other sites More sharing options...
sometimesmaybe Posted February 18, 2023 Share #96 Posted February 18, 2023 On 9/24/2022 at 6:39 PM, sillbeers15 said: My XProIIL trigger & AD300Pro arrived. Initial trials to connect trigger/camera + flash worked in TTL/M & HSS worked well. how did you get HSS to work on the trigger? I recently picked up a used trigger for my ad300pro, but cant get the HSS going. i took a gamble just in case it works on the m246. the ad300pro works well in HSS with my GFX I just want to rule out operator error. many thanks 🙏 Link to post Share on other sites More sharing options...
Photoworks Posted February 18, 2023 Share #97 Posted February 18, 2023 1 hour ago, sometimesmaybe said: how did you get HSS to work on the trigger? I recently picked up a used trigger for my ad300pro, but cant get the HSS going. i took a gamble just in case it works on the m246. the ad300pro works well in HSS with my GFX I just want to rule out operator error. many thanks 🙏 the godox Leica trigger has only been tested with M10, q2 and SL2 1 Link to post Share on other sites More sharing options...
sometimesmaybe Posted February 19, 2023 Share #98 Posted February 19, 2023 15 hours ago, Photoworks said: the godox Leica trigger has only been tested with M10, q2 and SL2 i forgot to mention... that's why im doing my own experiment to see if i can get the HSS going, esp when it works on the m10 Link to post Share on other sites More sharing options...
Photoworks Posted February 19, 2023 Share #99 Posted February 19, 2023 2 hours ago, sometimesmaybe said: i forgot to mention... that's why im doing my own experiment to see if i can get the HSS going, esp when it works on the m10 godox said that is compatible with M10, m10R, m10m. the M11 was not tested by godox and is not compatible. the new light meter system may need some FW tweek. Link to post Share on other sites More sharing options...
sillbeers15 Posted February 22, 2023 Share #100 Posted February 22, 2023 On 2/18/2023 at 4:21 PM, sometimesmaybe said: how did you get HSS to work on the trigger? I recently picked up a used trigger for my ad300pro, but cant get the HSS going. i took a gamble just in case it works on the m246. the ad300pro works well in HSS with my GFX I just want to rule out operator error. many thanks 🙏 I cannot think of a reason why HSS did not work for you on SL2 as AD300Pro is relatively new from Godox. Write to Godox service support for an explanation. Link to post Share on other sites More sharing options...
