vor 18 Minuten schrieb gteague:
tks. slim pickings on ebay unless you want to order from japan. but i have other places to check yet. /guy
The prices! Apparently, they went through the roof these last few months. I definitely remember having seen some offers in the USD 300..400 range.
However, you might fetch a better offer looking for a set (the "real" CL with one or two lenses, or even the two lenses without the body). I have seen offers in Germany, Austria and the US of A. I don't know which of those is the most useful for sending parcels to nowhere.
i actually have a voigtlander 40/2, but it's nikon mount. very nicely built lens and my only voigtlander ever. i guess the wise, although not the authentic choice, would be their 40/1.4 nokton at $400 new.
and yeah, i'm seeing the combo for $1k give or take (mostly give) a few hundred bucks. list near mint for under $400 and a combo for $800 if you're willing to order from japan. both sellers have 100-300 sales though and it might be a good gamble.
/guy
Edited by gteague
10 minutes ago, jaapv said:
What is wrong with buying from Japan? I have had only good experiences buying from legit Japanese sellers.
nothing at all. i've done it upon occasion. but i'm always more cautious when ordering from overseas. i remember buying a device which was still in manufacturing process from what i thought was a french company and got billed from bulgaria. or romania. i got a cold chill, but let the order continue. turns out every single 150 or so of us got burned with what was not even useful as a doorstop. i actually got two of them. i was able to stop payment even though it had been like 45 days and was going to offer to return them, but the guy (who was italian) had fled the country by then. so, as the saying goes, once burned, twice shy!.
in any case, i have too many lenses to use already, so i think i'll put this on the back burner and put the money towards a new ham radio being released next month. if the zombie apocalypse manifests (and i fully expect it to) a radio will be more use than a camera. :) :):)
/guy
Edited by gteague
No problem with either Summicron-C 40/2 or M-Rokkor 40/2 for Minolta CLE on the digital CL. Those are not WA lenses though due to the crop factor (60mm FoV). Never heard of tightening needs on those lenses but i may be wrong. Only issue i've got with the Rokkor is lens calibration on non Minolta RFs but it is not a problem on the digital CL. Filter size is 40.5mm on the Rokkor so no need to look for Series 5.5 filters contrary to the Summicron-C. A reason to prefer the latter is the smaller size of its rubber hood and hood cap though but they can be expensive in good shape. FWIW.
is there a valid comparison between the 50 summicron and the 40 rokkor when used on the cl? /guy
IQ wise, similar as Summicron 50/2 v3 or v4 more or less, or Summicron 35/2 v3 or v4 too. Bit soft at f/2, compared to modern lenses, but plenty sharp at f/4 and on.  As for FoVs better order a 35mm lens if you're after a similar FoV as that of 50mm lenses on FF cameras.
ok, i pulled the trigger on a lens for approx $400 with fedex priority shipping. says near mint and has a hood, although i don't know if it's the original hood--some of the lenses i looked at looked like they had that b&w rubber hood.
i was sorely tempted to double that amount for a lens/camera combo, but it's just way too much trouble to muck around with film. that's behind me.
is this the hood? looks exactly like the one b+w sells and i have at least 2-3 of those, although not in 40.5 size.
/guy Edited by gteague
4 hours ago, jaapv said:
There is a Minolta version with slightly better coating. Most are in good condition, but many need tightening of the ring that holds the optical cell to the   barrel - a 10-second DIY job. Try and find one with the original rubber hood - it has a weird filter thread (the Leica version). The lens hood takes a series 5.5 filter. The Minolta lens has a regular 36 mm filter AFAIK.
The Minolta versions use a standard JIS 40.5mm filter thread, both the Rokkor-M 40mm and Rokkor-M 90mm lenses. I have had both of them, still have the 90mm f/4. There's a vendor on Ebay who makes nice metal replacement hoods for the 90mm in either JIS 40.5mm or DIN 5.5 thread. I have them too. :)
G
what other famous camera has a 40mm lens? which one of you yahoos posted that shot of the beautiful little rollei a few months back? it's been in the back of my mind ever since and it's always a dangerous day when i'm loose on ebay. you can put these items together i'm sure and draw a conclusion.
of the hundreds of cameras i've owned, i've never owned a rollei, not even the famous tlr model because those things are the devil's toys and i cannot focus a ground glass. btw, i already got a fedex tracking # for the lens so that shipper is on the ball because i got it like 0800 tokyo time. that gives me every confidence.
[later note: i have batteries as i bought them for a classic sekonic meter, but when did film become $10 a roll? i think the last roll i bought was about $2.50. i bulk loaded of course for b&w and bought single rolls of color when i needed them.]
/guy
Edited by gteague
G
You're right there. 36 was memory fail ;)  If you mean Heavystar, be careful with his 5.5 adapter. I once had to call in Will van Manen with a hacksaw (or whatever tool he used ;) ) to cut the adapter ring out. Not only is it from Aluminium, which binds easily, the threads are quite imprecisely cut. If you get one  out of tolerance, you are out of luck, as I got some response  from fellow-sufferers on RFF.
38 minutes ago, lct said:
i literally saw this one and fell in love even deeper than when i saw your post of this before. i read that only 1500 of these were made for the american/canadian market. i love the oak wreath--there's a huge amount of symbolism attached to that in the military and paganism, to name just two.
what is the patch on top of the se? does the 'e' mean more electronics? i literally am starting from scratch with rollei. ah! newer and has led's in the viewfinder this says:
35 SE 1980-1982 f/2.8 Sonnar PX-27 Viewfinder LED metering
Edited by gteague
I haven't used mine for decades so i don't remember sorry. BTW my SE is black and when i used  it together with my M4-2 + 35/2 v4 i often preferred the Sonnar. Pity the Rollei has no focus aid though so f/2.8 pics were hit and miss to say the least. No crop factor and equivalent things then :D
  • Haha 1
