Franka373 Posted September 15, 2019 Share #1 Posted September 15, 2019 Advertisement (gone after registration) First post but not new to Leica. I have never used an LTM mount on Leica. Are there any drawbacks or concerns? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted September 15, 2019 Posted September 15, 2019 Hi Franka373, Take a look here LTM on M10. I'm sure you'll find what you were looking for!
jaapv Posted September 15, 2019 Share #2 Posted September 15, 2019 On a digital Leica, pick your adapter carefully (codable) Link to post Share on other sites More sharing options...
Ecar Posted September 15, 2019 Share #3 Posted September 15, 2019 (edited) No concerns IF the adapter is a quality product. Avoid the cheapest junk on eBay. Ability to code is indeed a good idea on digital, but not compulsory - and some high-quality adapters do not have coding pits anyway. Edit: some non-codable adapters (including vintage Leitz or Voigtlander ones) have a cutout in the area where the code should be. This will allow ambient light to hit the 6-bit sensor and prevent you from using LV or the EVF (if that's your thing) on the M10. No such problem with the M240. Edited September 15, 2019 by Ecar Link to post Share on other sites More sharing options...
Michael Geschlecht Posted September 15, 2019 Share #4 Posted September 15, 2019 (edited) Hello Frank, Welcome to the Forum. Some collapsible lenses should not be collapsed on certain Leica Digital Cameras. Some non- collapsible lenses that take certain accessories will sometimes not fit, or operate correctly, with or without those accessories, in some situations. Just ask specifically if you have a certain lens or 2 in mind. This is the Forum to ask questions like this on. Best Regards, Michael Edited September 15, 2019 by Michael Geschlecht 1 Link to post Share on other sites More sharing options...
farnz Posted September 15, 2019 Share #5 Posted September 15, 2019 To add to what Ecar has written, if your LTM lens(es) has an infinity lock you'll need the LTM to M adaptor with the cutout or the back of the infinity lock might grate against the adaptor and prevent you from focussing your lens. Pete. 1 Link to post Share on other sites More sharing options...
Dan Bachmann Posted September 15, 2019 Share #6 Posted September 15, 2019 I have great luck with all the LTM adaptors I've tried on a Leica M9 and Leica M10. On an M(240) it didn't read my 6 bit coding in most cases. The only concern to have is some collapsible lenses may push back to far on digital cameras. Link to post Share on other sites More sharing options...
jaapv Posted September 15, 2019 Share #7 Posted September 15, 2019 Advertisement (gone after registration) There is a good post on collapsible lenses in the M FAQ Link to post Share on other sites More sharing options...
jaapv Posted September 15, 2019 Share #8 Posted September 15, 2019 15 minutes ago, farnz said: To add to what Ecar has written, if your LTM lens(es) has an infinity lock you'll need the LTM to M adaptor with the cutout or the back of the infinity lock might grate against the adaptor and prevent you from focussing your lens. Pete. Yes, but on the original Leitz adapters the cutout is too wide for the code sensor. 2 Link to post Share on other sites More sharing options...
farnz Posted September 15, 2019 Share #9 Posted September 15, 2019 1 minute ago, jaapv said: Yes, but on the original Leitz adapters the cutout is too wide for the code sensor. I presume that you mean that the M10 doesn't think it has a lens mounted and generates an immovable error message about it? I don't have ant Leitz adaptors with cutouts so I can't say for sure about them but the Voigtlander type 2 LTM to M adaptors seem to be okay. Pete. 1 Link to post Share on other sites More sharing options...
Ecar Posted September 15, 2019 Share #10 Posted September 15, 2019 (edited) 40 minutes ago, farnz said: To add to what Ecar has written, if your LTM lens(es) has an infinity lock you'll need the LTM to M adaptor with the cutout or the back of the infinity lock might grate against the adaptor and prevent you from focussing your lens. Pete. Indeed. In this case, however, you may use a Rayqual adapter that's designed with a smaller cutout that covers the sensor AND allows the infinity lock to be operated. Only downside: these adapters are on the expensive side... Kenko also used to have a similar design, but they are increasingly difficult to find - except perhaps in Japan. Another option is to mount a small grindstone on a Dremel and make a cutout for the infinity lock on an adapter that provides full sensor coverage. Edited September 15, 2019 by Ecar 3 Link to post Share on other sites More sharing options...
Ecar Posted September 15, 2019 Share #11 Posted September 15, 2019 (edited) 18 minutes ago, jaapv said: Yes, but on the original Leitz adapters the cutout is too wide for the code sensor. Correct. 12 minutes ago, farnz said: I presume that you mean that the M10 doesn't think it has a lens mounted and generates an immovable error message about it? I don't have ant Leitz adaptors with cutouts so I can't say for sure about them but the Voigtlander type 2 LTM to M adaptors seem to be okay. Pete. Also correct. Voigtlander Type 1 adapters are essentially identical to the Leitz ones, while Type 2 covers the sensor and allows for 6-bit coding. With a Leitz or a Voigtlander Type 1 on the M10, you'll get a "no lens mounted" message and LV/EVF will switch off. On the M240, on the other hand, LV/EVF will work. Of course, on both cameras, the lens will not be recognised. Edited September 15, 2019 by Ecar 1 Link to post Share on other sites More sharing options...
Franka373 Posted September 15, 2019 Author Share #12 Posted September 15, 2019 Thanks all for the help. The lens is a 50 lux pre asph. Model 11621 if that helps. Link to post Share on other sites More sharing options...
TomB_tx Posted September 15, 2019 Share #13 Posted September 15, 2019 Just to note: if you have a VERY old ltm lens that has an “11-o’clock” position infinity lock, the adapters with cutouts for the later “7-o’clock” position infinity lock will still not allow it to focus full range, as the cutout is in the wrong position. I recently got a nickel, non-serial 11 o’clock 3.5 Elmar 50 for my 1A (converted to II), and found this when I wanted to try it on digital. I may pick up another adapter and mill a special cutout for it. 1 Link to post Share on other sites More sharing options...
lct Posted September 15, 2019 Share #14 Posted September 15, 2019 2 hours ago, Franka373 said: Thanks all for the help. The lens is a 50 lux pre asph. Model 11621 if that helps. It is a Summilux v3 then so no infinity lock thanksfully . I have no experience with this lens but its 6-bit code is 000101 if you are interested. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/301529-ltm-on-m10/?do=findComment&comment=3820794'>More sharing options...
jaeger Posted September 15, 2019 Share #15 Posted September 15, 2019 7 hours ago, jaapv said: On a digital Leica, pick your adapter carefully (codable) which 6bit-able LTM to M mount adapter would recommend? Link to post Share on other sites More sharing options...
jaapv Posted September 15, 2019 Share #16 Posted September 15, 2019 I hear that Jinfinance adapters (sold through eBay) are quite good. No personal experience, I have a collection of Dremeled ones. Link to post Share on other sites More sharing options...
lct Posted September 16, 2019 Share #17 Posted September 16, 2019 (edited) 1 hour ago, jaeger said: which 6bit-able LTM to M mount adapter would recommend? Tried Metabones, Kipon and a China made i don't recall the name 6 bit LTM to M adapters on my M240 and digital CL, to no avail for whatever reason. Got finally a Rayqual which works fine on both bodies. Only cons it is all black and the coding pits are not drilled on it so i had to use a template to paint them (in white) on a recessed part of the adapter. Otherwise it fits perfectly but none of my lenses have an infinity lock so i don't know how it works on such lenses. Edited September 16, 2019 by lct 1 Link to post Share on other sites More sharing options...
Franka373 Posted September 16, 2019 Author Share #18 Posted September 16, 2019 (edited) Cameraquest sells a rayqual. Is that what you are referring to? Will it work on an M10P? Edited September 16, 2019 by Franka373 Link to post Share on other sites More sharing options...
Ko.Fe. Posted September 16, 2019 Share #19 Posted September 16, 2019 Stephen Gandy is very alive person. Why not ask him? Link to post Share on other sites More sharing options...
Ecar Posted September 16, 2019 Share #20 Posted September 16, 2019 (edited) In my experience, the Jinfinance adapters are the only inexpensive adapters that work for most (but not all) LTM lenses, although the recent ones are a bit too tight when new. Fotodiox are slightly more expensive and also come with the 6-bit pits already milled. I've had mixed results with Kipon. Otherwise, Voigtlander Type 2 (now discontinued) or Rayqual should work flawlessly. The "Type III" Rayqual adapter on the Cameraquest website is the one I was referring to in an earlier post and will be perfectly fine on the M10P. Edited September 16, 2019 by Ecar Link to post Share on other sites More sharing options...
