sillbeers15 Posted August 2, 2019 Share #21  Posted August 2, 2019 Advertisement (gone after registration) 42 minutes ago, helged said: The largest difference between SL and S1R, in my view, is IBIS. It works very, very well for hand-hold photography. The ~5 stop longer shutter speed is more than Panasonic selling talk, it is real. That is interesting. Throughout my 3 + yrs of SL ownership, I never once missed stabilisation even thought the SL75 & 16-35 comes w/o stabilisation. 1 Link to post Share on other sites More sharing options...
Advertisement Posted August 2, 2019 Posted August 2, 2019 Hi sillbeers15, Take a look here Should I wait for SL 2 ?. I'm sure you'll find what you were looking for!
helged Posted August 2, 2019 Share #22  Posted August 2, 2019 24 minutes ago, sillbeers15 said: That is interesting. Throughout my 3 + yrs of SL ownership, I never once missed stabilisation even thought the SL75 & 16-35 comes w/o stabilisation. Two examples (the Nikkor 400mm f2.8E is a biggie...):  Link to post Share on other sites More sharing options...
sillbeers15 Posted August 2, 2019 Share #23  Posted August 2, 2019 1 hour ago, helged said: The largest difference between SL and S1R, in my view, is IBIS. It works very, very well for hand-hold photography. The ~5 stop longer shutter speed is more than Panasonic selling talk, it is real. Great to hear that. Technically, in body or in lens stabilisation works greatest on longer focal length lenses. On my past experience with SL and 90-280mm. Almost all usage of the lens was used to track moving subjects on 280mm end at F4. I had not once mounted the 90-280 on tripod and had not have shots with motion blur. So either I have been keeping shutter speeds & ISO up enough or the lens stabilisation worked well or both. Come to think about it, my experience had been very positive. I sure hope that the SL2 comes with in body stabilisation. But my hopes are not high. Link to post Share on other sites More sharing options...
helged Posted August 2, 2019 Share #24  Posted August 2, 2019 1 minute ago, sillbeers15 said: Great to hear that. Technically, in body or in lens stabilisation works greatest on longer focal length lenses. On my past experience with SL and 90-280mm. Almost all usage of the lens was used to track moving subjects on 280mm end at F4. I had not once mounted the 90-280 on tripod and had not have shots with motion blur. So either I have been keeping shutter speeds & ISO up enough or the lens stabilisation worked well or both. Come to think about it, my experience had been very positive. I sure hope that the SL2 comes with in body stabilisation. But my hopes are not high. Without any information whatever  - my feeling is that Leica may surprise us with IBIS in SL2... 2 Link to post Share on other sites More sharing options...
jaapv Posted August 2, 2019 Share #25 Â Posted August 2, 2019 If they do, this would be the camera do do it on... 1 Link to post Share on other sites More sharing options...
panoreserve Posted August 2, 2019 Share #26  Posted August 2, 2019 vor 3 Stunden schrieb helged: The largest difference between SL and S1R, in my view, is IBIS. It works very, very well for hand-hold photography. The ~5 stop longer shutter speed is more than Panasonic selling talk, it is real. Totally agree! IBIS is of great relevance not only for long focal lenghts... Working with S1 & Apo SL 75 (and SL 35)  was an astonishing experience to me. The results @ 1/30, 1/60 and even 1/125 sec. were visibly sharper than with my SLs... Even longer shutter speeds as 1/15 or 1/8 sec. (!!!) were possible without any problems. Ok -I suppose my hands are a bit "shakily" 😀. So, for me, the upcoming SL2 MUST have IBIS. The good news is: the SL2 WILL have IBIS😲... 3 Link to post Share on other sites More sharing options...
jaapv Posted August 2, 2019 Share #27  Posted August 2, 2019 Advertisement (gone after registration) 1 hour ago, panoreserve said: The good news is: the SL2 WILL have IBIS😲... Source? Link to post Share on other sites More sharing options...
panoreserve Posted August 2, 2019 Share #28 Â Posted August 2, 2019 vor 52 Minuten schrieb jaapv: Source? I'm not allowed to give detailed information... 1 1 Link to post Share on other sites More sharing options...
scott kirkpatrick Posted August 2, 2019 Share #29  Posted August 2, 2019 The discussion above on reasons for stabilization seems confused. Generally OIS is used for longer focal lengths because IBIS isn't sufficient to undo the image movement caused by wiggling a telephoto, and those long tubes have room for extra hardware. But OIS can only correct for pitch and yaw.  Adding bank corrections (rotation about the axis of the lens) requires IBIS. So IBIS is potentially more powerful than OIS but restricted to a smaller range of focal lengths. And IBIS + OIS is the best of all, with each component correcting the part they do best. It's unfortunate that the S1R can only do OIS or IBIS but not both with lenses not made by Panasonic. It's probably not controlled in the L-mount spec, thus requires further business and technical cooperation between the two companies. But it doesn't sound impossible. 1 1 Link to post Share on other sites More sharing options...
thighslapper Posted August 2, 2019 Share #30  Posted August 2, 2019 7 hours ago, sillbeers15 said: That is interesting. Throughout my 3 + yrs of SL ownership, I never once missed stabilisation even thought the SL75 & 16-35 comes w/o stabilisation. Like most of these things, until you have it, and regularly use it, you don't realise what you have been missing. 4 Link to post Share on other sites More sharing options...
Chaemono Posted August 2, 2019 Share #31  Posted August 2, 2019 vor 5 Stunden schrieb panoreserve: I'm not allowed to give detailed information... Actually, you could tell us but then you’d have to kill us. 😂 Link to post Share on other sites More sharing options...
MaBu Posted August 2, 2019 Share #32  Posted August 2, 2019 On 8/1/2019 at 4:29 AM, sillbeers15 said: A patient wait for SL2 , cause I sold my SL last weekend after 3+ years of use. Resisting hard against picking up an S1R before SL2 arrives. I have the SL and the S1R and I think the S1R is an amazing camera. I would assume that the SL2 will have a lot of the technology/features  you find in the S1R, but with the user interface of Leica. Link to post Share on other sites More sharing options...
sillbeers15 Posted August 3, 2019 Share #33  Posted August 3, 2019 2 hours ago, MaBu said: I have the SL and the S1R and I think the S1R is an amazing camera. I would assume that the SL2 will have a lot of the technology/features  you find in the S1R, but with the user interface of Leica. I am a satisfied SL user. I specific look forward to AF tracking improvements  in SL2 & S1R. I have made up my mind to pick up the SL2 and I can see it having all the features in S1R plus the unique Leica user interface less the Panasonic/Olympus flash protocol. I sold my SL now for two reasons. One is I do not like to keep camera bodies around which I do not forsee using them. Second intention is to swap for a S1R which I can keep it even when SL2 comes, provided I can use the Profoto, Elinchrome & Godox transmitters fully compatible on the S1R. Link to post Share on other sites More sharing options...
sillbeers15 Posted August 3, 2019 Share #34  Posted August 3, 2019 (edited) 21 hours ago, helged said: Two examples (the Nikkor 400mm f2.8E is a biggie...):  I can agree that IBIS is a very useful feature and it works well at especially low ISO and shutter speeds w/o tripod. Help me to understand why you struggle to use a 400mm f2.8 Canon lens on a good for nothing AFC tracking plus slow focus S1R (There will be no DFD database for non L mount lenses to aid CDAF focusing speed) on handheld shooting (handheld advantage is on flexibility to move camera freely)?  I would think a Canon PDAF DSLR or EOSR would be a perfect camera to use instead in your case. My rational for sticking to L mount cameras because I only use SL lenses. Therefore there is incentive for me to optimise the camera settings, select lighting condition rightly and practise BIF more to make up for the lack in best in class AF offered by L mount cameras. I must be missing something here? Edited August 3, 2019 by sillbeers15 Link to post Share on other sites More sharing options...
Jon Warwick Posted August 3, 2019 Share #35  Posted August 3, 2019 11 hours ago, MaBu said: I have the SL and the S1R and I think the S1R is an amazing camera. I would assume that the SL2 will have a lot of the technology/features  you find in the S1R, but with the user interface of Leica. It will be interesting if the SL2 has a similar high resolution mode, given the one in the S1R adds a very noticeable improvement in image quality (no false colour, no moire, less noise, and higher resolution) that works especially well for tripod-mounted scenes like landscapes and architecture. Link to post Share on other sites More sharing options...
hillavoider Posted August 3, 2019 Share #36  Posted August 3, 2019 On ‎8‎/‎2‎/‎2019 at 7:47 PM, panoreserve said: Totally agree! IBIS is of great relevance not only for long focal lenghts... Working with S1 & Apo SL 75 (and SL 35)  was an astonishing experience to me. The results @ 1/30, 1/60 and even 1/125 sec. were visibly sharper than with my SLs... Even longer shutter speeds as 1/15 or 1/8 sec. (!!!) were possible without any problems. Ok -I suppose my hands are a bit "shakily" 😀. So, for me, the upcoming SL2 MUST have IBIS. The good news is: the SL2 WILL have IBIS😲... it better have ibis and eye AF up the wazoo to compete with sony - I really hope it does, but being leica we'll see it in 2022 and it will be unobtainable …… Link to post Share on other sites More sharing options...
sillbeers15 Posted August 3, 2019 Share #37  Posted August 3, 2019 On 8/2/2019 at 2:03 PM, helged said: The largest difference between SL and S1R, in my view, is IBIS. It works very, very well for hand-hold photography. The ~5 stop longer shutter speed is more than Panasonic selling talk, it is real. Thanks. I really look forward to IBIS on S1R & SL2. 1 Link to post Share on other sites More sharing options...
Guest Posted August 3, 2019 Share #38  Posted August 3, 2019 On 7/31/2019 at 5:57 AM, Jeff S said:  And GAS knows no logic. Jeff  Whats that? Link to post Share on other sites More sharing options...
Guest Posted August 3, 2019 Share #39  Posted August 3, 2019 On 8/2/2019 at 2:38 PM, helged said: Without any information whatever  - my feeling is that Leica may surprise us with IBIS in SL2... Auto focus for M lenses as well maybe...................Im waiting for one Link to post Share on other sites More sharing options...
Jeff S Posted August 3, 2019 Share #40 Â Posted August 3, 2019 8 minutes ago, NW67 said: Whats that? I looked it up and there was a picture of you. Jeff 2 Link to post Share on other sites More sharing options...
