cp995 Posted June 9, 2019 Share #41 Â Posted June 9, 2019 (edited) Advertisement (gone after registration) vor einer Stunde schrieb humerc: Got my 7Artisans 35/2.0 today, so far everything good. BUT: it has no 6Bit Coding! Have they changed anything? The are prepared for 6-Bit coding. You only have to colorize the fields with the desired code https://lavidaleica.com/content/leica-lens-codes#codes Edited June 9, 2019 by cp995 Link to post Share on other sites More sharing options...
Advertisement Posted June 9, 2019 Posted June 9, 2019 Hi cp995, Take a look here 7Artisans 35mm f2.0. I'm sure you'll find what you were looking for!
humerc Posted June 9, 2019 Share #42  Posted June 9, 2019 mine doesn’t have the fields...  Link to post Share on other sites More sharing options...
lct Posted June 9, 2019 Share #43  Posted June 9, 2019 41 minutes ago, cp995 said: The are prepared for 6-Bit coding. You only have to colorize the fields with the desired code Mine has the same black and white coding pits as the Summicron 35/2 asph. Link to post Share on other sites More sharing options...
Telemetric Posted June 9, 2019 Author Share #44  Posted June 9, 2019 Just now, lct said: Mine has the same black and white coding pits as the Summicron 35/2 asph. Like mine! I would like better 7Artisans instead of Leica. IMO is a bit fake. Well, not a bit, totally! 🤣 1 Link to post Share on other sites More sharing options...
jdlaing Posted June 9, 2019 Share #45 Â Posted June 9, 2019 Mine is coded. If yours is not you might send it back. Link to post Share on other sites More sharing options...
lct Posted June 9, 2019 Share #46  Posted June 9, 2019 38 minutes ago, Telemetric said: Like mine! I would like better 7Artisans instead of Leica. IMO is a bit fake. Well, not a bit, totally! 🤣 I have both lenses and prefer the smoother OoF rendition of the Leica but otherwise the 7art 35/2 is a sharp lens indeed. I suspect the coding of our copies does not comply with some German regulations but i may be wrong. Link to post Share on other sites More sharing options...
humerc Posted June 9, 2019 Share #47 Â Posted June 9, 2019 (edited) Advertisement (gone after registration) maybe I just code it with a sharpie, have to look at some instructions online Edited June 9, 2019 by humerc Link to post Share on other sites More sharing options...
humerc Posted June 10, 2019 Share #48  Posted June 10, 2019 Here is the feedback from 7 Artisans: “It had 6-bit coding before but lots of users said it didn't function so well. Therefore, we cancelled it.“  1 Link to post Share on other sites More sharing options...
anachronist Posted June 10, 2019 Share #49  Posted June 10, 2019 These were on eBay US a couple of weeks ago - gives some perspective on prices. 🤔 Not sure which one sold. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/296081-7artisans-35mm-f20/?do=findComment&comment=3757180'>More sharing options...
jdlaing Posted June 10, 2019 Share #50 Â Posted June 10, 2019 7artisans 35mm = $288.00 new. Summarit 35mm = $1,995.00 new. Â 1 Link to post Share on other sites More sharing options...
Ecar Posted June 10, 2019 Share #51  Posted June 10, 2019 (edited) 14 hours ago, humerc said: Here is the feedback from 7 Artisans: “It had 6-bit coding before but lots of users said it didn't function so well. Therefore, we cancelled it.“  I think they gave you a b****hit answer. The code on my (early) copy works fine across all generations of digital Ms. They probably got copyright pressure - and might at some point come up with a mount groove "à la Voigtlander" (unless there's already one on your lens?) to help users paint the codes themselves... Edited June 10, 2019 by Ecar Link to post Share on other sites More sharing options...
Telemetric Posted June 10, 2019 Author Share #52  Posted June 10, 2019 Mine works perfectly too Link to post Share on other sites More sharing options...
humerc Posted June 10, 2019 Share #53  Posted June 10, 2019 Yes, I also think they had problems with the copyrights, what should not work with 6bit coding, its not high end technology... But it does not really matter to me, the lens performs significantly better than my 50 year old summicon35 also without coding 1 Link to post Share on other sites More sharing options...
TomB_tx Posted June 14, 2019 Share #54  Posted June 14, 2019 Mine came coded, which I thought would go against Leica’s patents, and I’d guess that’s why they stopped. Perhaps China finally started clamping down on such things. I agree the lens is much better than the price suggests. I’ve again experimented with calibrating the focus cam, as I had adjusted per their instructions at 2 meters, and found it a bit off at 3.5 meters. Set it exact at 3.5, and it was off at 1.5. So the cam isn’t perfectly shaped, likely because it’s a sloped cam. But I’ve compromised between the two settings, and have it quite usable now, biased a bit towards the close range where I’m likely to shoot more wide open and close (indoors). Of course focus is no problem with the 020 and live view, but that’s not why I use an M. Link to post Share on other sites More sharing options...
Ko.Fe. Posted June 15, 2019 Share #55  Posted June 15, 2019 On 6/10/2019 at 4:59 PM, jdlaing said: 7artisans 35mm = $288.00 new. Summarit 35mm = $1,995.00 new.  Don't know why, but I'm keeping my Summarit as the only Leica lens I'm finding worth to keep and if I ever get another 35 it is going to be $700+ Nokton II. 1 Link to post Share on other sites More sharing options...
TomB_tx Posted June 15, 2019 Share #56  Posted June 15, 2019 3 hours ago, Ko.Fe. said: Don't know why, but I'm keeping my Summarit as the only Leica lens I'm finding worth to keep and if I ever get another 35 it is going to be $700+ Nokton II. I agree - after I try others (I have several 35s - don’t ask about 50s) it’s the Summarit that ends up on the camera. But I have enjoyed the Norton I, so I’ll try the II to see if it fixes the focus shift. 1 Link to post Share on other sites More sharing options...
Telemetric Posted June 17, 2019 Author Share #57  Posted June 17, 2019 Well, I didn't buy the Summarit 35mm because i have the 28mm and the 50mm so, in my opinion, it has no sense. But for less than $300 I bought the 35mm to play a bit with it. The point is I love the results and I think I will use it more often that I expected so if one day I have a project that needs to be done with that focal length I will use it. Link to post Share on other sites More sharing options...
TomB_tx Posted June 17, 2019 Share #58  Posted June 17, 2019 3 hours ago, Telemetric said: Well, I didn't buy the Summarit 35mm because i have the 28mm and the 50mm so, in my opinion, it has no sense. But for less than $300 I bought the 35mm to play a bit with it. The point is I love the results and I think I will use it more often that I expected so if one day I have a project that needs to be done with that focal length I will use it. Certainly makes sense. With the same logic I bought a Voigtlander 21 f4 as I seldom use a 21. The lens fits my needs, so I doubt if I'll ever "upgrade." 1 Link to post Share on other sites More sharing options...
Joska Posted June 3, 2022 Share #59  Posted June 3, 2022 On 6/10/2019 at 11:13 PM, Ecar said: I think they gave you a b****hit answer. The code on my (early) copy works fine across all generations of digital Ms. They probably got copyright pressure - and might at some point come up with a mount groove "à la Voigtlander" (unless there's already one on your lens?) to help users paint the codes themselves... Mine dont work at all, 4 black and 2 white but body and LRC don't got it Link to post Share on other sites More sharing options...
Viv Posted June 3, 2022 Share #60  Posted June 3, 2022 On 4/10/2019 at 11:13 AM, Telemetric said: Just arrived, right now! Hahaha. While I was posting this, the postman entered in my office haha.  Haha Link to post Share on other sites More sharing options...
