lecycliste Posted May 26, 2018 Share #1 Posted May 26, 2018 Advertisement (gone after registration) Has anyone figured out a way to power the SL externally for extended time-lapse photography? Or should I simply use my EOS 5D mk IV instead (which I'd rather not do - love the look and performance of Leica 28/2.8 and 24/1.4 for night sky images)? Any thoughts? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted May 26, 2018 Posted May 26, 2018 Hi lecycliste, Take a look here External power for SL?. I'm sure you'll find what you were looking for!
Irakly Shanidze Posted May 26, 2018 Share #2 Posted May 26, 2018 Nope... Everyone who does video is also anxiously awaiting a solution. Link to post Share on other sites More sharing options...
vladik Posted May 26, 2018 Share #3 Posted May 26, 2018 Would be an extra battery in external grip p/n 16 063 be enough for your purpose? Link to post Share on other sites More sharing options...
darylgo Posted May 26, 2018 Share #4 Posted May 26, 2018 Haven't tried the 24/1.4 for night sky. Is it good? Coma? I gave up using Leica as my main camera for night sky, my Canon 6D has the feature set that works well. Link to post Share on other sites More sharing options...
lecycliste Posted May 27, 2018 Author Share #5 Posted May 27, 2018 A couple things - The 24/1.4 Summilux-M ASPH is OK for night sky work. There is coma in the corners at f/1.4, but that's true of most 24/1.4 lenses, except for the (sometimes de-centered) Samyang / Rokinon 24/1.4. The Leica SL is good for relatively short exposures, less than maybe 90 seconds or so. You wait for another exposure time while the long exposure noise reduction shoots a dark frame to cancel noise, so you wouldn't want to do a 30 minute exposure at ISO 100 and f/11. I love the depth of field scale on Leica lenses - it makes hyperfocal focusing very easy, unlike most lenses for Canon EOS. That said, I have used Sigma's 14mm f/1.8 Art on an EOS 5D mk IV for starfield shooting. It also has coma in the corners wide-open. ************* As for the 2-battery grip (https://tinyurl.com/y7leyv5k), it costs as much as a Sigma 25/1.4 Art lens I can put on my EOS 5D mk IV. I was hoping for a less-expensive external power source for the SL for time-lapse, but if the HG-SCL4 is the only alternative, I'd rather have the 24/1.4 Art lens. 1 Link to post Share on other sites More sharing options...
LD_50 Posted May 27, 2018 Share #6 Posted May 27, 2018 Leica produced an external power system for the S. I wonder if it could be modified to fit into the battery compartment of an SL. It is not something I need but it would be interesting. The shape of the battery shell is different but I would not expect many other required changes. Link to post Share on other sites More sharing options...
lx1713 Posted May 27, 2018 Share #7 Posted May 27, 2018 Advertisement (gone after registration) External power is not needed by most people but important. I will never say no if the system provided for such an option particularly if it's non proprietary like a USB-C port. 1 Link to post Share on other sites More sharing options...
Irakly Shanidze Posted May 27, 2018 Share #8 Posted May 27, 2018 External power is not needed by most people but important. I will never say no if the system provided for such an option particularly if it's non proprietary like a USB-C port. It is essential for video, and I wish SL had USB-C. While in most cases having three fully charged batteries and two chargers will do the trick, it is the absence of an external power option that makes me pass on assignments like long concerts, conferences, etc. 2 Link to post Share on other sites More sharing options...
lx1713 Posted May 27, 2018 Share #9 Posted May 27, 2018 It is essential for video, and I wish SL had USB-C. While in most cases having three fully charged batteries and two chargers will do the trick, it is the absence of an external power option that makes me pass on assignments like long concerts, conferences, etc. I think the 29 minutes limit does put a crimp on you too You can always change battery when that 29 min limit comes up I think a Video L camera this year is more likely than anything else. Better margins. So that external power port is not likely to be forgotten. 1 Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 27, 2018 Share #10 Posted May 27, 2018 (edited) It is essential for video, and I wish SL had USB-C. While in most cases having three fully charged batteries and two chargers will do the trick, it is the absence of an external power option that makes me pass on assignments like long concerts, conferences, etc. What battery life do you see when shooting UHD ProRes over HDMI to an external recorder? With 4K recorded to the chip in the camera I have no trouble getting over an hour of shooting on one battery. I'm now using external audio recording to bridge the need to insert a cut before 29 minutes are up. Edited May 27, 2018 by scott kirkpatrick 1 Link to post Share on other sites More sharing options...
lx1713 Posted May 28, 2018 Share #11 Posted May 28, 2018 What battery life do you see when shooting UHD ProRes over HDMI to an external recorder? With 4K recorded to the chip in the camera I have no trouble getting over an hour of shooting on one battery. I'm now using external audio recording to bridge the need to insert a cut before 29 minutes are up. Thanks, sounds like a neat trick. I've been recording separately but never thought to use it as a bridge. Do you lay down the audio in editing stage first? Or drop in after your cuts? Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 28, 2018 Share #12 Posted May 28, 2018 Thanks, sounds like a neat trick. I've been recording separately but never thought to use it as a bridge. Do you lay down the audio in editing stage first? Or drop in after your cuts? Audio has to come first, if I have been creating an archive of a production. 1 Link to post Share on other sites More sharing options...
lx1713 Posted May 28, 2018 Share #13 Posted May 28, 2018 Thanks for the insight. Makes sense. Link to post Share on other sites More sharing options...
Irakly Shanidze Posted May 28, 2018 Share #14 Posted May 28, 2018 What battery life do you see when shooting UHD ProRes over HDMI to an external recorder? With 4K recorded to the chip in the camera I have no trouble getting over an hour of shooting on one battery. I'm now using external audio recording to bridge the need to insert a cut before 29 minutes are up. Approximately an hour 1 Link to post Share on other sites More sharing options...
Irakly Shanidze Posted May 28, 2018 Share #15 Posted May 28, 2018 Audio has to come first, if I have been creating an archive of a production. Audio always comes first, it's a backbone of a timeline. Unless, of course, it is some stock footage that is required to have no sound. 1 Link to post Share on other sites More sharing options...
Irakly Shanidze Posted May 30, 2018 Share #16 Posted May 30, 2018 I think the 29 minutes limit does put a crimp on you too You can always change battery when that 29 min limit comes up I think a Video L camera this year is more likely than anything else. Better margins. So that external power port is not likely to be forgotten. There is no limit when recording out via HDMI. It is only limited by the capacity of SL batteries, as the recorder can be connected to the outside power. 1 Link to post Share on other sites More sharing options...
lx1713 Posted May 30, 2018 Share #17 Posted May 30, 2018 There is no limit when recording out via HDMI. It is only limited by the capacity of SL batteries, as the recorder can be connected to the outside power. I forgot about your operational method. Thanks! So the limiting factor would be SL's battery endurance Link to post Share on other sites More sharing options...
Michael Hodges Posted June 1, 2018 Share #18 Posted June 1, 2018 Having a dummy battery with AC would be huge. The S has this option as a proper studio camera. I've been trying to use it more for video interviews with the Noctilux but this is the main limiting factor for attempting this in a professional capacity on location for long periods of time. Just as well I guess as it's not really meant for this type of work but I do enjoy doing it when I can. Link to post Share on other sites More sharing options...
omega1848 Posted July 7, 2021 Share #19 Posted July 7, 2021 I know it has been quite some time, but maybe there is somehow a solution to power the camera externally? What about if the camera is used in tethered shooting via USB Cable? Does that solve anything? Assume not, would be too easy I guess 😉 The reason I am asking is, for me 1080p for video would be enough and if I could use the camera (recording externally via HDMI Out) as my video camera for streaming/ conferencing, this would be great and a "valuable" and affordable solution. But of course that would require that the camera can be operated on continuous power and not via battery. Link to post Share on other sites More sharing options...
Paul2660 Posted July 8, 2021 Share #20 Posted July 8, 2021 There is the option to attach a USB-C external battery. This charges the main battery while the camera is in use. In effect acting like an external power source. You can run all day with one battery internal charging as the cell will never drop below 100 percent. Does not seem to add any extra heat. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/284996-external-power-for-sl/?do=findComment&comment=4234331'>More sharing options...
