dau Posted February 28, 2019 Share #61 Posted February 28, 2019 Advertisement (gone after registration) 32 minutes ago, grahamhoey said: I seem to be only able to get focus peaking on the CL when I am in MF mode You turn the focus ring while keeping the shutter release half pressed. Link to post Share on other sites More sharing options...
Advertisement Posted February 28, 2019 Posted February 28, 2019 Hi dau, Take a look here CL FAQ ... "How do I do such and such?". I'm sure you'll find what you were looking for!
bags27 Posted March 26, 2019 Share #62 Posted March 26, 2019 Question: is it possible to use a non-Leica flash on the CL which works as well? If so, any recommendations? Link to post Share on other sites More sharing options...
Louis Posted March 26, 2019 Share #63 Posted March 26, 2019 13 minutes ago, bags27 said: Question: is it possible to use a non-Leica flash on the CL which works as well? If so, any recommendations? Ahhh, this is the reason why I did not upgrade from T to TL2! The lack of flash on TL2 and not being able to use a flash when you have EVF on! But I am glad I didn't do the upgrade as I love my CL! I made some tests with 3rd party flashes such as Nikon that I already had, but I was not convinced!... It seems some people use 3rd party manually. But somehow, it did not work for me and the result didn't seem sure to me. Leica uses other brands but makes a modification for leica camera. For instance, Leica flash made by Metz was modified for Leica and the same model of Metz is not working on Leica (CL). I found a very reasonable second hand but in perfect condition SF 24D. I am not using flash often, but it is good to have one just in case. SF 24D is working well and enough for my need.! Good luck Ken. 2 Link to post Share on other sites More sharing options...
rob_w Posted April 1, 2019 Share #64 Posted April 1, 2019 Question What is the best (fastest, largest capacity, brand) SD card for the Leica CL? Link to post Share on other sites More sharing options...
cirke Posted April 1, 2019 Share #65 Posted April 1, 2019 (edited) 25 minutes ago, rob_w said: Question What is the best (fastest, largest capacity, brand) SD card for the Leica CL? Lexar has realized a 1tb SD card but you can find many 128 or 256gb card with speed ip to 300mb/s ... not necessary for the CL I use sandisk 128gb 170mb/s https://www.amazon.de/gp/product/B07H9DVLBB/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 you can get a 256 or 512gb Edited April 1, 2019 by cirke 1 Link to post Share on other sites More sharing options...
bags27 Posted April 1, 2019 Share #66 Posted April 1, 2019 Could someone please explain Optical Image Stabilization (OIS) on the CL? How can it be turned off or put on automatic? On the Q that is an easy thing, but on every menu I try on the CL it seems to be set to "on". Many thanks. Link to post Share on other sites More sharing options...
WeiterWinkel Posted April 1, 2019 Share #67 Posted April 1, 2019 (edited) Advertisement (gone after registration) vor 3 Stunden schrieb bags27: Could someone please explain Optical Image Stabilization (OIS) on the CL? How can it be turned off or put on automatic? On the Q that is an easy thing, but on every menu I try on the CL it seems to be set to "on". Many thanks. Sorry, but to my knowledge the CL doesn’t have any OIS except your steady hand. Edited April 1, 2019 by WeiterWinkel 1 Link to post Share on other sites More sharing options...
bags27 Posted April 1, 2019 Share #68 Posted April 1, 2019 (edited) 14 minutes ago, WeiterWinkel said: Sorry, but to my knowledge the CL doesn’t have any OIS except your steady hand. thanks for responding. That's what I had thought, too. But it certainly appears in my menu system as "on" and non-selectable. And here from the CL manual. so, does this mean that its default is "on" but only with SL lenses? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited April 1, 2019 by bags27 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/279975-cl-faq-how-do-i-do-such-and-such/?do=findComment&comment=3713860'>More sharing options...
WeiterWinkel Posted April 2, 2019 Share #69 Posted April 2, 2019 As I don't have any SL-lenses I didn't know that. Sorry, can't help you with your question. Link to post Share on other sites More sharing options...
dau Posted April 2, 2019 Share #70 Posted April 2, 2019 The CL does not do OIS. It's the lenses that do it, and obiously only those lenses that are so built. You can not change the setting in the CL if there is no lens that can do OIS. Once such a lens is mounted, I presume that you can disable or enable OIS. 1 Link to post Share on other sites More sharing options...
bags27 Posted April 2, 2019 Share #71 Posted April 2, 2019 thanks and interesting. and that will likely include the new Panasonic and Sigma lenses, I bet, part of the reason for yesterday's firmware upgrade. Link to post Share on other sites More sharing options...
rob_w Posted April 2, 2019 Share #72 Posted April 2, 2019 Question Is it necessary to update the firmware on Leica TL lenses (as well as the firmware in the CL camera, which I did today)? Both my lenses (23 and 35) show firmware version 1.0 Link to post Share on other sites More sharing options...
rob_w Posted April 4, 2019 Share #73 Posted April 4, 2019 Question Is it possible to have auto review only on the back screen? At the moment it seems to take place both in the EVF and on the back screen, so if I want to take several quick shots in succession my view through the EVF freezes. I do use auto review on the back screen habitually with my other cameras and I would like the CL to work in the same way. Thanks Link to post Share on other sites More sharing options...
lct Posted April 4, 2019 Share #74 Posted April 4, 2019 4 hours ago, rob_w said: Question Is it possible to have auto review only on the back screen? At the moment it seems to take place both in the EVF and on the back screen, so if I want to take several quick shots in succession my view through the EVF freezes. I do use auto review on the back screen habitually with my other cameras and I would like the CL to work in the same way. Thanks I don't think it is possible but even if it were, it wouldn't prevent your EVF issue i fear. Don't ask me why please but the only way i know of is to set auto review to off. All my digicams are set this way BTW. Not a big deal to me but i don't chimp much so YMMV. Link to post Share on other sites More sharing options...
rob_w Posted April 4, 2019 Share #75 Posted April 4, 2019 Thanks. It helps to know it can't be done - I'll stop searching the manual. This is my first mirrorless camera and I'm trying to set it up like the OVF on my M. I will need to change that particular habit. The Instruction Manual entry which confused me is on page 28 under Display Settings: EVF ExtendedEVF Extended: Photographs always with viewfinder, playback or menu control always on screen this sounds like what I need, but it does not work like that. When I set it, playback still works through the EVF. Link to post Share on other sites More sharing options...
rob_w Posted April 4, 2019 Share #76 Posted April 4, 2019 Question Is there any more detailed info about battery life than the dinky little 3 bars in the top window? Thanks Answer: No. Link to post Share on other sites More sharing options...
Guest Posted April 12, 2019 Share #77 Posted April 12, 2019 Would a Contax Hologon 8/16mm converted to Leica M fit a CL? (I guess not) Link to post Share on other sites More sharing options...
dau Posted April 12, 2019 Share #78 Posted April 12, 2019 On 4/12/2019 at 10:48 AM, Joachim_I said: Would a Contax Hologon 8/16mm converted to Leica M fit a CL A lens with an M mount must not protrude more than 11mm into the body. You must, of course, use an M to CL adapter. By Jaapv: 11 mm. plus the thickness of the adapter. Obviously the flange distance must be the same as an M camera (minus a safety margin) Link to post Share on other sites More sharing options...
LocalHero1953 Posted April 12, 2019 Share #79 Posted April 12, 2019 On 3/26/2019 at 11:25 AM, bags27 said: Question: is it possible to use a non-Leica flash on the CL which works as well? If so, any recommendations? You can use virtually any flash in simple manual or A (auto-thyristor) mode, but none except Leica's will work in TTL mode. 1 Link to post Share on other sites More sharing options...
geoffreyg Posted May 26, 2019 Share #80 Posted May 26, 2019 (edited) Just got the CL a week or so ago, been working well with both the 18-56 and manual M lenses just fine. Set it up for EVF only, with histogram and horizon line "on". They work well with the M lenses, in manual operation. When the zoom lens is put on, oddly neither the histogram and the horizon are visible, although both are still in the menus as "on". Any thoughts? Edited May 26, 2019 by geoffreyg Link to post Share on other sites More sharing options...
