16 hours ago, Harpomatic said:
I’m using the Nitecore ULM10 Pro and I’m very happy with it: it charges 2 batteries in series, works off any USB-A charger and power bank.
No issues at all with it.
I use the Nitecore for travel as well.  With both an M10-R and an M10-M having the ability to charge 2 batteries overnight is convenient.
my experience with nitecore ulm10 wasnt as good, i think i got the first batch which actually discharged either battery when charging both at the same time so i gave up and bought a dc to usb adapter using the original charger
On 12/16/2017 at 10:27 AM, rent said:
I use the Apple “duck-head” plug that is part of their iPad or Mac power adapter. You can also get their World Travel Adapter Kit, which is a collection of these plugs. Any of these will plug directly into the Leica M10 battery charger.
great idea - I've just tried my australian & US Apple adapters (I must have other versions lying around somewhere too) on the M10 charger & perfecto - will use in future when travelling
A picture says more...
Edited by romualdo
Which is quite logical. The 8 shaped plug carries 110-240 V which no USB connection can supply.
On 12/29/2022 at 4:29 PM, marcelography said:
Has anyone tried using a USB C to power cable, to use the original Leica battery charger with a powerbank?
I've found no USB C to 8 shaped plug, though, only with the 5.5x2.5 pin.
  • 5 months later...
I'll second that.  A really useful resource - both for travel and just in general.  I've taken to using it rater than the standard M10 charger as it gives a useful indication of progress and battery health.
The problems reported from Nitecore chargers mostly stem from using too small an USB adapter or a computer with a limited USB power supply. They need at least 12A output.
Similar adapters can be bought from eBay for pennies.
I use some 'BolAAzul' branded IEC C7 90 degree plugs from amazon, 2 for around $10. They work better for me than the apple version as they are a bit longer so push the charger brick out an extra cm. This stops the charger from hitting the wall if not using raised power outlets.
The Nitecore option looks like a great shout if travelling further afield and needing USB!
