Contrary to several of the above comments, this happens on a regular basis for me :( . Unintended shifting of the mode can be annoying, but since the viewfinder shows the shooting mode, it is quite quick to cycle back to the intended mode. I would, however, preferred a slightly stiffer pushing of the (rear) click wheel.
well it never occur to me, not even once. i have a fairly big hand. maybe it just a matter of habbit. maybe you have to buy the hotshoe thumbs grip on ebay. click here
Ditto, Helged
I manage this regularly and end up in 'P' mode which can go unnoticed as the photos superficially appear fine ..... only to find later they have bizarre shutter/F stop combos and unnecessarily high ISO's .....
It would be nice if there was an audible 'click' when the wheel is pressed in far enough to activate the mode change.
+1 Edited by helged
me too. I've also pushed some sequence by accident when working under pressure that locked it into recording video. I never record video. My fault of course, but I need to be able to recover from stuff like this quickly. In the end I took the battery out, then reset to a 'user' I had saved. My M9 doesn't do that!
New top features
Up to 35% faster writing DNG files to SD card
§ Optimization of the writing process allows to reduce the time needed for saving DNG files up to
35%. This allows to be quicker ready to continue shooting after a burst session.
Optimized Autofocus
§ MF-/AF-control optimized
§ Autofocus reaction time is shortened
§ Improved AF tracking of objects with SL lenses
§ Improved: zooming while recording video
§ Improved: AF field chances while recording video
§ Improved: AFc while recoding video
New firmware for lenses is included
§ Improved accuracy of the focus position
§ Improved AFc accuracy if an object moves towards the lens
§ New firmware for the VARIO-ELMARIT-SL 24-90 f/2.8-4 ASPH.
§ New firmware for the APO-VARIO-ELMARIT-SL 90-280 f/2.8-4
§ Bugfixes
Additional improvements
§ Store DNG and JPG on separated SD cards
§ Independent exposure control for video and photo mode
§ New vide frame rate 24fps for 4k resolution 3840x2160
§ White balance 'flash' improved for use with studio flash system's modelling light
§ Electronic shutter mode for shutter speeds from 1s - 1/16 000s for silent shutter release (ISO50)
§ Exposure preview in M-Mode improved for continuous preview
§ Improved usability in play mode when zooming to 1:1 (100%) , location gets stored to easy access
the same location
§ Improved flash behaviour for AutoISO setting
§ Improved behaviour of flash units in continuous burst shooting mode
New options for customization
§ Swap the dedicated exposure controls of the front and back dial
§ Current control setup of the front and back dial is shown on the top display
§ Renaming from T-Mode into S-Mode
§ New option for AF Tracking "RESET": Start position of the AF tracking is fixed on a specific
location which can be adjusted by the joystick.
§ Graphical User Interface of the multi selection and delete functions improved
§ AE-/AF-Lock Button can be assigned to magnification for a quick visual check of focus position
§ New option to show the focus distance in feet or meter
§ Automatic detection of Leica M and Leica R lenses can be turned off
§ Video resolution/framerate can be assigned to the personal favorite menu
§ User experience increased: the "OK" button on any keyboard input screens is touch sensitive
§ Audio in/out levels can be controlled directly by left/right joystick on the histogram screen
§ Several minor improvements made on graphical user interface
§ New default behaviour: the function "Access menu in EVF" is enabled by default. This function
enables the upper left button while looking through the electronic viewfinder. Either menu access
and quick access to custom functions is available now by default. For users experiencing
accidental presses of the upper left button by their nose - it is recommended to disable this
function in the "Customize Control" menu.
Bugfixes
§ Any shutter speed limitation for any manual focus lens is deactivated
§ Improved stability for tethered shooting with Leica Image Shuttle 3.6
§ If an USB connection is detected by the camera, the warning of a missing SD card is hidden. This
allows to use Leica Image Shuttle and Adobe® Lightroom® Plugin without an inserted SD card.
§ For Leica M and Leica R lenses the real-time display of the established aperture is hidden
What's in the update??
Sent from my iPhone using Tapatalk
Guest NEIL-D-WILLIAMS
New top features
Optimized Autofocus
§ Bugfixes
the same location
Bugfixes
allows to use Leica Image Shuttle and Adobe[emoji768] Lightroom[emoji768] Plugin without an inserted SD card.
cool thanks
