M 11 will be around in less than 4 years. The speculations and facts.
x
17 hours ago, jonoslack said:
Hmmm, I'm not sure that I agree with the first paragraph. I think that it would be quite possible to make a good L mount camera which was geared towards use with M mount lenses (possibly with a more elaborate adapter which could detect focus movement). . . . but could use SL and TL lenses as well. Whether Leica choose to do it is quite another matter.
Best
That L mount camera that could use SL lenses has to be big, heavy, with a good grip... SL lenses need that...
You can use that SL camera with M lenses but... it is not a M camera. It is not the best (or good) design for M lenses:
Imagine this on a M-size body:
The M system and SL system are completely different:
A good body for SL lenses is not good for M lenses.
A good body for M lenses is not good for SL lenses.
Adapters or removable grips are not a solution for that problem.
You can use S lenses on a CL body, with adapter and grip... but that is not a "solution" for S system users... It is a botched solution.
Edited by rosuna
  • Thanks 3
The problem with this thread is that it is attempting to design 2 M style cameras in tandem. Essentially trying to solve a minor focussing accuracy problem with complicated hardware. The solution is really quite simple. An EVF with the resolution and eye relief of the one on the SL as an add on to the M11.
  • Thanks 2
I think this thread shows why Leica always will think for themselves: what they actually want in a camera ( and read this of course 😉) . I think everything has almost been in subject. Maybe really time for them to show what they have invented and give us some slack.
Am 11.1.2019 um 09:06 schrieb adan:
(It's a tough job, but someone has to do it!)
-Leica M8 - no EVF
-M240 series - viewfinder used generally not mentioned
Please add a If digital.
Without IBIS, AF, RF, VF, AA-glass and flash. But with FF-sensor, M-mount, short focus mount, touchLCD, Visoflex- USB- and flash-connectors, long-times knob. 😇
Jan
Hi Rubén
Well - I simply don't agree I use SL lenses on the CL (which is much smaller than the M) Actually I use it a great deal with the 75 Summicron SL (great combination).
I understand that if you make an M sized L mount full frame body then it's going to be odd with the SL zooms (as your pics show) - but it won't be odd with the SL Summicrons (which are lovely lenses). And with a new adapter that detected focusing movement it would work really well with M lenses.
Best
On 1/21/2019 at 1:57 PM, rosuna said:
My point is this: a good L mount camera with L-M adapter is not a good solution for using M lenses with EVF... and a good M mount camera designed for M lenses would not be a good body design for using SL lenses on it.
Body and lenses are interconnected and a good system needs a balance between the lens and the body.
Exactly and i don't see why an M camera should need an adapter to use M lenses, let alone that such an adapter does not exist with auto image magnification and would not come for free in the package somewhat expectedly. Also the sensor of such a swiss army camera would be designed for both M and L lenses and would give inferior results with M lenses compared to sensors designed specifically for the latters inevitably. All this trouble to allow a couple of monstrous AF lenses to be used on a compact manual body...
43 minutes ago, jaapv said:
The sensor argument is simply incorrect. Enlarging the incidence angle has no negative  effect on smaller incidence angles.
Ah, but LCT's point on L cameras for L lenses and M cameras for M lenses remains a good one, Jaap.
While it is true that the SL remains a very good universal platform for all Leica lenses, that doesn't take away from the point that if you own M lenses, like the M camera system, but would like an EVF variant, the SL might not be the camera for you.  I see no point in making what is effectively an M camera (in form and function), with an EVF and L mount - what would be the point?  So you can use SL and TL lenses?  Why?
If you want an L mount camera, then there are three very good options.  We are told there is an even better SL2 option around the corner somewhere.  If L mount lenses are your thing, I see no reason at all for wanting an M camera with an L mount.  Think about it for a moment - this L mount M camera would need to cater for AF and in body aperture and shutter control and all the other functionality which makes the L cameras so very good, and you need to add an adapter to use M lenses (which was the whole point in the first place).
An M camera with an EVF is something quite different..
  • Thanks 2
On 1/11/2019 at 2:03 AM, rosuna said:
A compact SL for M lenses makes no sense (we already have that kind of "solution" from many camera makers).
A compact SL for L lenses makes no sense (ergonomics, size, balance).
I totally agree that I would not use large SL lenses on an M-style camera. I wouldn't use them on the CL either. Yet, Leica gave SL and CL the same mount.
But using M lenses on a compact body does make sense. However, those other makes are not optimal for M lenses. Leica can certainly improve on that. My CL wears M lenses half the time ;) I really don't notice the adapter, once it is on, it is on and the camera has an M mount. I prefer image magnification on demand anyway.
It may have been discussed before, but isn't it feasible to just make an SL quality Visoflex for the M10/M11? It would have been a good enough solution for me. – And kept the great design of the M cameras untouched.
Yes possible but it would be bulky, irrespective if the OLED screen is vertical or more probably horizontal. I assume from the shape of my SL, that the large 4+ MP EVF screen is horizontal with a pentaprism above it. However technology always advances and I would assume something better than the M10/M10-P's Visoflex EVF would soon be achievable. If you look how much smaller the current Visoflex with the same 2+ MP count is, compared to the older Olympus VF-4 screen, this demonstrates the advances in EVF technology.
Wilson
Wilson
Evkine, I agree that this would be the most effective solution. Perhaps the M10 would be able to use it, the M11 certainly.
Wilson, it may be a bit more bulky than the 020 but that's ok since it's not permanently attached.
On 1/22/2019 at 2:32 AM, Kwesi said:
I couldn't agree more. Leicarumors just posted avery interesting comparison between an M10 a Sony A7 and a Phase One.
The best part is when the 75/1.25 is mounted on the latest phase One with jaw dropping results.
Really makes you hope the M11 finally breaks away from the 24mp choke hold . Link below
https://leicarumors.com/2019/01/20/mega-shootout-best-of-the-best-sony-leica-and-phase-one-comparison.aspx/
... and Leica needs new back-illuminated sensors...
The problem is the volume of the order that Leica can place for such a back illuminated sensor, which also has the angled micro-lenses and shallow pits, that provide the current 24MP FF  Leica sensors with such good image quality, especially with wide lenses. A sensor maker may well say, give me an order for 100,000 of them and no problem at all. An order for 10,000 would be far less attractive for such a custom sensor. This is always going to be the problem with a boutique manufacturer, such as Leica, unless they can piggy back on another manufacturer's product, like they did with the CL sensor from Sony. Maybe the Panasonic S1R 47MP sensor (or a mildly customised version of it) will be the answer. I don't know if it has been disclosed as yet, whether this is back illuminated or not. It is also going to be very interesting to see if Sigma will bring out an FF camera with a Foveon type stacked array sensor rather than Bayer pattern sensor, in L mount. Could that be an alternative for Leica?
Wilson
Absolutely.
The M10 has finally brought Leica back to its proper size, but let's not forget that it was a combination of the best films available and the the M ergonomics and lenses that has made it what it is today. The only thing now that desperately needs improvement is the sensor. It's ok but not up to today's best and that's a shame. Hopefully Leica addresses this in the M11
