It’s the new one without goggles. Odd, as it used to give the correct information with previous FW. I’ve not checked with my second body, but would be surprised if it was an issue with the 6bit reader as all other lenses are recognised.
Did you chose the 2.8/21 manually from the list before you attached the Macro-Adapter?
Even though the new adapter is coded, the camera does not recognize any code. So your manual selction from the list persists as no new code is detected.
I thought they had changed the detection of the the Macro-Adapter with the final version of 2.4.5.0 - but I was wrong. When you choose „Macro-Adapter-M -90 f/4 14409“ from the list it still indicates „uncoded“.When I tried before and thought something had changed I had chosen the detection for the 4/90 Elmar without the adapter - this works
  • 3 weeks later...
BUG REPORT
Maybe not a bug but I can’t find how I would adjust this in the menu. Basically since upgrading firmware the camera is not auto rotating the vertical shots, they stay in horizontal position even if shot vertically.
It does not matter what program I use to edit or process them with eiither. This is enough of a show stopper on a big job that I simply can’t use the camera. Anyone know if there is a menu setting that got turned off when I did the firmware upgrade, because if not, this is a real pain in the rear end.
BUG REPORT
It's not a setting as far as I know. My 'vertical' photos are detected (the latest) Lightroom CC. The camera not so much, but I think that was the case as well before the upgrades.
There could be an 'issue' with vertical photos when they are shot while facing (way) up (sky) or down (ground). The angle-sensory-thing might lose direction in those cases, and screw up the embedded orientation.
I think something might be up in the camera then, I will try resetting it next week but for now I have to stop using it.
And to the notion that rotating in post is totally easy, no, not when they are among thousands of images generated in a single day and then there is a deadline to hit before I can start my 5 hours of sleep and then do it all over again. All my software shows the same thing, CC LR, PS, Photo Mechanic, Capture One, etc.
Either the orientation sensor has gone out or something else because I am tens of thousands of images into this camera and it only just started after the FW update.
Edited by Reciprocity
Well bummer, I reset the camera, tried different cards and it looks like my orientation sensor has gone bad. At least it is under warranty.
I’ve had a few recent photos do the same thing. I’ve previously shot without the issue ever happening until the latest firmware update.
JB
Ahhh, now we are getting somewhere, let’s see if this pops up with more M10 users. Zero issues for me too with this until the latest firmware. Super annoying on this job to have to go through thousands of M10 photos and rotate all of the wonky ones before I can even pull an edit to export.
Thanks for chiming in!
Yes, definitely happening for me more regularly now.
I can shoot a sequence and a bunch will randomly rotate in the sequence.
Only seems to have started happening after the last firmware update.  When I put the card back into the camera they aren't rotated on playback. They're all as expected.
Strange.
JB
There have been reports about this the German part of the Forum as well.
I remember I saw the issue as well in the very beginning when the M10 was new. Though after a new version of Lightroom it did not occur again.
Which version of Lightroom do you use? Do you see the same problem with other tools for post - processing?
  • 2 weeks later...
  • 2 weeks later...
Just got back from an overseas assignment but before I left I was able to send a much larger string of images shot at slower than average pacing just to see if I were pushing the camera too hard in terms of outpacing the orientation sensor.
Sometimes it did ok but mostly not. But what I have also noticed in some of my faster paced shooting is that after the first frame in the sequence after a change to vertical from horizontal or vice versa is that the orientation sensor never corrects. For example, I switch to vertical and then start shooting and the first frame is off and then the rest follow suit until I change scenes or give it a break as if the camera is locking in the wrong value like some kind of exposure lock or at least very similar to it.
I have a few more assignments this month and going into the next and then the warranty is actually up at the end of the September so I will try to get it in right before then to claim warranty coverage.
It’s a great camera but my M8, M9 or M240 ( or any other brand ) never did this so something is up and will need to get resolved.
BUG REPORT
My M10 does not rotate the vertical shots, (I like this better because you get a bigger image on camera screen), but I download in Photo Mechanic, on a MAC, and all images come up rotated correctly.
Have u found a solution or has it been fixed yet?
BUG REPORT
