I've searched with no luck to find what years (or serial number range) the Summitar had 10 aperture blades (round compared to 6 hexagon shape).
I'm looking for one with 10 blades made in 1949 or later.
Thank you in advance.
According to Laney and Van Hasbroek, the Summitar with six blades (and hexagonal iris) entered in 1951: so an item of 1949-50 should have the old blades which form a round iris.
  • 4 months later...
Excuse me for re-opening an old thread, but this info seems relevant to the discussion . . .
My Summitar --serial number 81211x--has 10 blades. I notice that the Summitar entry in the LeicaWiki states:
"Diaphragm setting /type - 10-blade / 6-blade after s/n 810001"
Perhaps there was some overlap during the transition from 10 blades to 6 blades? Number 810001 may have been the first to have 6 blades, but at least one Summitar with 10 blades was produced at a later time.
The batch of Summitars starting with s/n 810.001 was a very big one : 10.000 lenses !!! No strange that they made some with the old diaphragm... probably many semifinished parts, or replacements, were available in the factory.
And... Welcome to the Forum !!! If you'll continue to partecipate into this community, you will realize that "in the Leica world, exceptions are the rule"...
I have one from 1949 (round blades) 682 4xx
and one from 1950 (flat blades) 799 1xx
on my web site : IIIb page
Edited by jc_braconi
  • 2 weeks later...
Yes, that's what I thought also--someone found an old bin full of 10-blade kits under a workbench--or something like that.
Thank you for the welcome. I've been visiting here now and then for the last 18 months--since buying a IIIG and Summitar. You are all a great source of information.
  • 5 years later...
  • 4 years later...
My Summitar is from 1950 and it has 6 blades only.
  • 1 year later...
Mine is 1950 and after 8110xxx and has the round iris. Which I assume is 10 blade.
  • 11 months later...
  • 2 years later...
     My immaculate filter-protected Summitar, serial number 810448, also has a 10-blade diaphragm, so is another example of a lens out of sequence, or as someone suggested above, may have been made with parts that were found after the main assembly line was installing the six-blade diaphragm.
   My Leica III (267457) was modified by the Leitz shop in Shandwick Place, Edinburgh for flash and has a small co-ax flash socket on the top plate.  I suppose this affects the value for purists, but then again, since modified models are probably rare, it may not.  Even after I succumbed to the ease of SLRs, I still used my Leica as a back-up camera when I photographed weddings in Edinburgh back in the 60s and 70s, before moving to Africa.
   It saved my bacon once when my self-loaded-from-bulk-stock cassette was not properly connected in my Dixon SLR (a piece of junk!) and which I did not notice for more than 30 shots!  I will never forget the sinking feeling I experienced when I realised that the film was not advancing.
   Fortunately, I had taken about a dozen shots with the Leica and was able to salvage all the important groups from those negatives.  I did all my own processing back then.  Both families were very happy.
