Showing results for tags 'pre-asph'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 4 results
  1. Hi everyone, I just purchased this lens to shoot on both film and digital, I read forum posts and reviews online, but there's way more information on the V2 / V3 than the V1, which makes sense since this lens only lasted two years so not a lot of people out there actually using it I guess? I mostly bought this lens to shoot portraits and complement my favorite lens of all time, the summicron 35mm 8 elements (also a v1 lens :p). I tried the 50mm summilux asph and pre-asph v2/v3 but didn't enjoy the rendering of the pre-asph v2/v3 that much, nor the size of the asph. I think I've tried all 50s that Leica has made, and my favorite is the first Summicron collapsible, so by now I guess you can figure out I really like Leica's rendering from the 50s (and it also seems I have a thing for v1 lenses...) What do you think of this lens if you own it or have used one before? How's the performance at F1.4~F2, and also a bit closed down at F4~F8? Do you still shoot with it nowadays? If so, would love to hear your thoughts on it Thanks and to a 2020 with lots of great memories to be captured!
  2. Hi everyone, I recently purchased a type II Summilux 35mm and when I shine a light through the front I can see very clearly a large grouping of tiny bubbles and what looks like a streak of some kind opposite of it inside the lens. The coating on the front and rear are clean and the aperture blades are clean, and I can only see these when I tilt the lens in the light. When I shine a light through the lens it is very apparent. Can anyone explain what I'm seeing here? Any info would be greatly appreciated!
  3. I received a copy of the summilux 35mm pre-asph lens and noticed that it lacked a shroud or any metal rim to protect the rear element. While a "overly" protruding shroud may prevent proper function on some cameras, the lack of any protective shroud makes me concerned that the rear element will eventually be damaged. Looking at the back of the lens, I would not risk setting it down on a flat surface, but this may occur at some point. I am concerned that there was a shroud present at some point, but it was removed. If the shroud was removed it would be difficult to replace assuming that Leica does not stock parts for these vintage lenses. Having the part made would be challenging without the detailed specs and without knowing whether it threads into the space around the rear element. I'd just hate to start using this lens without adequate protection of the glass surface. Does anyone know if some of the summilux 35mm pre-aspherics were manufactured without any shroud or protective rim? I have not found any examples of this in my research, so I suspect its a missing part. Thanks for your thoughts.
  4. Hi Guys, Am fairly new to Leica (6 months in) and I would like to seek your advice on which 35mm lens to get. I currently use a M240 body with a 60mm F1.2 Konica Hexanon and a 50mm Summicron APO. I am looking to add a 35mm lens to compliment my existing collection (and will be looking at add a 28mm Elmarit when the new one releases end of the month). I am considering the follow: 35 Summilux Pre-ASPH 35 Summicron Pre-ASPH Version 1 35 Summicron Pre-ASPH Version 4 35 Summicron ASPH (2016 edition) After doing some extensive research, I feel like the 3 Pre-ASPH lens may be a better compliment as it is softer / has more of a leica glow (since my 50mm APO and the 28mm Elmarit are both bitingly sharp)? I was originally going to just get a 28 and 50 and NOT the 35 since it seems to be too close to the other 2 focal lengths, so I am now thinking maybe getting something with more of a unique characteristic). Just wondering what all your thoughts are and why you think so? Your kind assistance is very much appreciated. Thank you. Best Regards, J
