Pyrogallol Posted February 24, 2022 Share #141 Posted February 24, 2022 Advertisement (gone after registration) I have two ltm copies 1694*** and 1629***. Both original 3’ 4” or 1 meter focussing. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/94959-summaron-35mm-f28-m-lens/?do=findComment&comment=4389869'>More sharing options...
Advertisement Posted February 24, 2022 Posted February 24, 2022 Hi Pyrogallol, Take a look here Summaron 35mm f2.8 M lens . I'm sure you'll find what you were looking for!
Keith J Posted November 21, 2024 Share #142 Posted November 21, 2024 HI FOLKS, Will a Summaron f2.8, 35mm, code 11306, factory bayonet mount lens display the correct 35mm Frame lines on a Leica M11? Link to post Share on other sites More sharing options...
pedaes Posted November 21, 2024 Share #143 Posted November 21, 2024 (edited) 1 hour ago, Keith J said: HI FOLKS, Will a Summaron f2.8, 35mm, code 11306, factory bayonet mount lens display the correct 35mm Frame lines on a Leica M11? Yes. Nearly all Leica M bayonet lens will work with any M camera ever made (there are one or two that need care, like the dual range Summicron 50). Edited November 21, 2024 by pedaes Link to post Share on other sites More sharing options...
Keith J Posted November 21, 2024 Share #144 Posted November 21, 2024 Thank you, I've read a huge volume of detail about the particulars of the 2.8 35mm Summarons, but have not found the answer to this very specific question. Link to post Share on other sites More sharing options...
Michael Geschlecht Posted November 22, 2024 Share #145 Posted November 22, 2024 (edited) 3 hours ago, Keith J said: Thank you, I've read a huge volume of detail about the particulars of the 2.8 35mm Summarons, but have not found the answer to this very specific question. Hello Keith, Welcome to the Forum. If the 11306 35mm f2.8 Summaron that you have still has its original factory installed bayonet adapter to key the 35/135 frame lines, then it should bring that pair up on an M11. If someone has switched the original adapter for an adapter that brings up other frame lines you simply need to: Remove & save the tiny screw from the side of the adapter, (Don't lose the tiny screw. They are hard to come by.) and replace the adapter with an adapter that brings up the 35/135 frame lines. Then it should work fine. The confusion exists because this lens is sometimes confused with its earlier version: The 35mm f3.5 Summaron. The 2 different aperture versions of the same focal length, with the same name, look somewhat similar. And the earlier 35mm f3.5 Summaron came in 2 versions. The first version of the 35mm f3.5 Summaron 11105 had a bayonet that keys the 50/75 frame lines because it was designed to be used on the M3, which was the first "M" mount camera & was the only "M" mount camera available for a number of years. This combination was used with an accessory viewfinder held in the accessory shoe next to the shutter speed dial. At a later date, when the M2 & M1 were released, a second version of the lens was released. The 11305. This lens keyed the 35mm frame in the M2 & M1. And it keyed the 135mm frame on an M3. On an M11 it keys the 35/135 frame lines. Best Regards, Michael Edited November 22, 2024 by Michael Geschlecht Link to post Share on other sites More sharing options...
Keith J Posted November 22, 2024 Share #146 Posted November 22, 2024 That is a specific answer and is exactly the information I have searched all day to find. Thank you very much! Keith 2 Link to post Share on other sites More sharing options...
wlaidlaw Posted November 22, 2024 Share #147 Posted November 22, 2024 Advertisement (gone after registration) Does not apply to Keith's lens but be very careful if buying the LTM version of the 2.8/35 Summaron. A number of sellers just remove the spectacles of the version designed to fit on an M3 (50 frame lines), where the spectacles removed the requirement to use an external viewfinder. This produces a lens with an L39mm x 26tpi thread mount but it will not RF focus correctly on a Barnack or on an M with a converter bayonet ring. The genuine LTM lenses are more valuable than the spectacles version, hence the temptation to present one as the other. The easy way to distinguish is that the genuine LTM version, only focuses to 1m whereas an unmounted spectacles version has focus marked to 0.7m. The 35/2.8 Summaron is an excellent lens and back before I swapped my 35 ASPH Summicron for an APO version, I took some comparative shots between the Summaron and ASPH Summicron on my M240 on a tripod. Other than very slightly softer corners, it was impossible to distinguish between the two lens' images. Wilson 2 1 Link to post Share on other sites More sharing options...
Michael Geschlecht Posted November 24, 2024 Share #148 Posted November 24, 2024 Hello Everybody, The reason that what Wilson wrote about the focusing mechanisms of 35mm f2.8, f2.0 & f1.4 (But not all f3.5) lenses is correct is: The "goggled" lenses listed above were designed to allow the users of M3 cameras, which have a viewfinder which covers the field of a 50mm lens, to use & to present a viewing image for a 35mm lens. An M3 rangefinder measures from Infinity to more or less 1 meter. What The Wizards Of Wetzlar did was: Create an optical system to put on the front of any "M" camera which expands the angle of view by 1.5X. This is approximately 52 divided by approximately 35. A lot of Leitz/Leica 50mm lenses actually measure around 52mm. Doing this also multiplies the optical focusing range of the rangefinder by 1.5X. NOT 1.4X So, when the MECHANICAL focusing mechanism on the CAMERA is moving from Infinity to 1 meter along the rangefinder cam. The OPTICAL system in the RANGEFINDER measures from Infinity to approximately 0.65 meters. Which is adjusted for by a differential cam in the lens that moves the lens out from the Infinity setting 1.5X the distance that the rangefinder cam indicates. Which means: When the lens is used on an M3 focusing from Infinity to approximately 0.65 meters: The differential MECHANICAL mechanism inside the RANGEFINDER measures from Infinity to 1 meter: While, at the same time: The OPTICAL portion visible inside the range/viewfinder window moves from Infinity to approximately 0.65 meters. Which is what the engravings on the lens barrel are indicating. A differential mechanism inside the lens moves the lens unit as per the markings on the barrel. When these lenses are used on M2/1 cameras & the later derivatives of those cameras: Everything works fine. The 50mm frame lines "pop" up. The image captured in the 50mm frame will be the correct 35mm field of view. This is 1 of the reasons that people at Leitz/Leica are called The Wizards of Wetzlar. Best Regards, Michael 2 Link to post Share on other sites More sharing options...
Michael Geschlecht Posted November 24, 2024 Share #149 Posted November 24, 2024 Hello Everybody, The reason a lens as described just above does not focus accurately with the "goggles" removed is: The rangefinder ROLLER in the CAMERA is indicating a movement from Infinity to approximately 1 meter. While the OPTICAL UNIT is actually being moved from Infinity to approximately 0.65 meters. Which is also what the engravings on the lens barrel are indicating. Which means: The point that the rangefinder is focused on is DIFFERENT than the point the lens unit is actually mechanically focused to. Except when the lens is focused at Infinity. The lens with the "goggles" removed can be used correctly with a DIFFERENT focusing system. Such as a Visoflex. Best Regards, Michael 2 Link to post Share on other sites More sharing options...
jaapv Posted November 24, 2024 Share #150 Posted November 24, 2024 10 hours ago, Michael Geschlecht said: Except when the lens is focused at Infinity. Which is the reason that lenses with removable goggles (for reasons of easy storing in a camera bag) automatically lock at infinity when the goggles are removed. These versions can be identified by a flat "swallowtail" on the top of the mount with a locking pin in the middle. Take care, they are sometimes offered with the goggles missing and the locking mechanism forcibly broken. 1 Link to post Share on other sites More sharing options...
wlaidlaw Posted November 24, 2024 Share #151 Posted November 24, 2024 I think my 35/2.8 LTM Summaron has the neatest and most functional infinity lock of all LTM lenses. I was always surprised that when Leica issued the final LTM lenses in the special editions of 1999, they omitted incorporating infinity locks and in fact these lenses have no focus tabs at all not even bumps like Zeiss ZM lenses have. I have the two 50mm special edition lenses, the Summicron V-SE and Summilux III-SE and have put rather ugly but functional TAAB rubber rings with focus tabs, on the focus rings of both lenses. IMHO these very expensive when new lenses, should have been fitted with Summaron type focus tabs with integral infinity locks. It is quite difficult to mount and unmount an LTM lens without an infinity lock. Wilson 1 Link to post Share on other sites More sharing options...
Michael Geschlecht Posted November 25, 2024 Share #152 Posted November 25, 2024 (edited) 13 hours ago, jaapv said: Which is the reason that lenses with removable goggles (for reasons of easy storing in a camera bag) automatically lock at infinity when the goggles are removed. These versions can be identified by a flat "swallowtail" on the top of the mount with a locking pin in the middle. Take care, they are sometimes offered with the goggles missing and the locking mechanism forcibly broken. Hello Jaap, The 35mm lenses with REMOVABLE "goggles" are SOME of the 35mm f3.5 Summaron lenses. ALL of the f2.8, f2.0 & f1.4 35mm lenses with "goggles" have "goggles" that are fixed in place that are NOT meant to be removed. Best Regards, Michael Edited November 25, 2024 by Michael Geschlecht Link to post Share on other sites More sharing options...
Michael Geschlecht Posted November 25, 2024 Share #153 Posted November 25, 2024 (edited) 12 hours ago, wlaidlaw said: I think my 35/2.8 LTM Summaron has the neatest and most functional infinity lock of all LTM lenses. I was always surprised that when Leica issued the final LTM lenses in the special editions of 1999, they omitted incorporating infinity locks and in fact these lenses have no focus tabs at all not even bumps like Zeiss ZM lenses have. I have the two 50mm special edition lenses, the Summicron V-SE and Summilux III-SE and have put rather ugly but functional TAAB rubber rings with focus tabs, on the focus rings of both lenses. IMHO these very expensive when new lenses, should have been fitted with Summaron type focus tabs with integral infinity locks. It is quite difficult to mount and unmount an LTM lens without an infinity lock. Wilson Hello Wilson, The 35mm f2.8 Summaron & the 35mm f2.0 Summicron, 8 element share similar lens barrels & other components. This means that pretty much of what you wrote about the 35mm f2.8 Summaron is the same on the 35mm f2.0 Summicron, 8 element. They even take the same lens hoods , filters, caps, etc. When you look at them side by side, pretty much the only difference is the diameters of the front & back optical components. Best Regards, Michael Edited November 25, 2024 by Michael Geschlecht 2 Link to post Share on other sites More sharing options...
jaapv Posted November 25, 2024 Share #154 Posted November 25, 2024 8 hours ago, Michael Geschlecht said: Hello Jaap, The 35mm lenses with REMOVABLE "goggles" are SOME of the 35mm f3.5 Summaron lenses. ALL of the f2.8, f2.0 & f1.4 35mm lenses with "goggles" have "goggles" that are fixed in place that are NOT meant to be removed. Best Regards, Michael Quite correct Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/94959-summaron-35mm-f28-m-lens/?do=findComment&comment=5712578'>More sharing options...
luigi bertolotti Posted November 25, 2024 Share #155 Posted November 25, 2024 (edited) 11 hours ago, Michael Geschlecht said: The 35mm lenses with REMOVABLE "goggles" are SOME of the 35mm f3.5 Summaron lenses. Michael, is it also correct to say that ALL the goggled f 3,5 Summaron have REMOVABLE goggles ? I think yes, but not 100% sure... 🤔 i have 1360096 - black paint removable goggles, and 1555644 - black crackle removable goggles - but later items also exist... have no pics of items from later batch... Edited November 25, 2024 by luigi bertolotti Link to post Share on other sites More sharing options...
wlaidlaw Posted November 25, 2024 Share #156 Posted November 25, 2024 I thought the only difference between removable and "non-removable" goggles was a set screw and possibly thread locking compound on the L39/26tpi joint. Wilson Link to post Share on other sites More sharing options...
Pyrogallol Posted November 25, 2024 Share #157 Posted November 25, 2024 This is my 35mm f3.5 Goggles Summaron that I bought in 1973. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/94959-summaron-35mm-f28-m-lens/?do=findComment&comment=5713080'>More sharing options...
Michael Geschlecht Posted November 26, 2024 Share #158 Posted November 26, 2024 12 hours ago, wlaidlaw said: I thought the only difference between removable and "non-removable" goggles was a set screw and possibly thread locking compound on the L39/26tpi joint. Wilson 7 hours ago, Pyrogallol said: This is my 35mm f3.5 Goggles Summaron that I bought in 1973. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Hello Wilson, The small set screw you are writing about is the screw that holds a screw mount to bayonet mount adapter in place. The screws that hold the "goggles" in place are the 2 screws on either side of the lens where the "goggles " are attached to the lens. Shown here in Pyrogallol's very nice photo above. Best Regards, Michael Link to post Share on other sites More sharing options...
Michael Geschlecht Posted November 26, 2024 Share #159 Posted November 26, 2024 (edited) 13 hours ago, luigi bertolotti said: Michael, is it also correct to say that ALL the goggled f 3,5 Summaron have REMOVABLE goggles ? I think yes, but not 100% sure... 🤔 i have 1360096 - black paint removable goggles, and 1555644 - black crackle removable goggles - but later items also exist... have no pics of items from later batch... Hello Luigi, The references I looked at are not specific as to whether there are some lenses made with fixed "goggles", or not. They do write that black paint "goggles" are earlier. And "crackle" finish "goggles" are later. With NO dividing serial number. As per Lager - Leica Illustrated Guide III. Rogliatti - 60 years, writes that the last 35mm f3.5 Summarons of all types were made in 1960 with serial numbers above 1717000. Best Regards, Michael Edited November 26, 2024 by Michael Geschlecht Link to post Share on other sites More sharing options...
Sverker Ahrent Posted October 11 Share #160 Posted October 11 On 2/22/2022 at 12:45 PM, Mowgli said: Dear fellow members, I have been reading and researching here in the forum for years. Now it is finally time for me to contribute something. During my research on the Summaron-M 35/2.8 I noticed something that I would like to share here and verify. Generally we distinguish four versions of this 2.8 Summaron (I leave the 3.5 Summaron out of consideration here): 1st version: LTM (focuses from 1m, coarse thread); 2nd version: Dual Mount from M 39+BM (focuses from 70cm, coarse thread, with small screw); 3rd version: M3+goggles (focuses from 65cm, coarse thread, with small screw); 4th version: M2 (focuses from 70cm, fine thread, without small screw). However, there is another, late version from 1962: 5th version: M3+goggles (BUT focuses from 70cm, not 65cm and has a fine thread, but no small screw anymore). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! This leads to the following conclusions. At about the same time when the production of the LTM was stopped (sometime in 1962, approximately from SNr. 193...) there were logically no more new Dual Mounts. Even the original Variant 3 with goggles always had an LTM, so these lenses had the small screw just like the Dual Mount. From about 1962 onwards, this changed. The new 5th variant no longer has the small screw and now focuses from 70 cm. In addition, the thread for all Summarons was changed from coarse to fine (cfr. pictures). All in all, this means that LTMs were always used in all Summaron variants until 1962. Therefore, all Summarons with BM were Dual Mounts until 1962. A real non-dual mount variant M2 was only available from 1962 onwards. What do you think? Does anyone have a variant: M3+goggles+screw that focuses from 65cm or a dual mount with a SNr. larger than 193...? I am curious Pierre I have a Summaron 35mm 2.8 sn 19475** 1962 fine thread WITH small screw and removable adapter. As a side note: In 1977 I was invited to a closing down photo dealer to se if there was something of interest in the attic. I found a Minox A and a strange looking lens adapter (with a red dot). It looked like it could fit my newly aquired Leica M2 so I brought it home. The adapter did fit the M2 but I couldn’t understand what kind of strange lens it should fit. In 2017 I bought a damaged Summaron 35mm. It had been dropped and damaged the lens flange so I got it at a bargain price. When I opened the box and studied the lens my memory said that I have the damaged part in a drawer somewere. In less than an hour I had a perfectly nice Summaron 35/2.8. Now I frequently use it with my M11. It gives beautiful files and is one of my sharpest 35. 2 Link to post Share on other sites More sharing options...
