jaapv Posted July 28 Share #41 Posted July 28 Advertisement (gone after registration) 2 minutes ago, jaapv said: But It would not change the focus as such with an M lens? So what is the use? Nor do see I any evidence of such use in the images you posted. And what is a tilt-shift effect in a camera without tilt/shift lens or being a view camera? Or an SL with Perspective Control? I think you have lost me completely. Ah - Google helps. Using your lens detached from the camera. I don't think that use entered Leica's mind when designing the M11. (Nor mine reading this thread). Link to post Share on other sites More sharing options...
Advertisement Posted July 28 Posted July 28 Hi jaapv, Take a look here Focus point toggle or center or move . I'm sure you'll find what you were looking for!
charlesphoto99 Posted July 28 Share #42 Posted July 28 7 minutes ago, jaapv said: Ah - Google helps. Using your lens detached from the camera. I don't think that use entered Leica's mind when designing the M11. (Nor mine reading this thread). I had to look it up too. Very influencer-y and a technique I already tired of looking at a few examples. To me though, it seems like 'freelensing' with a $15k lens is less than optimal value. May as well just get a TTArtisan 90 f1.25 for $600. That way if you drop it (which is all I can think of reading about this technique) then one won't be so sad. 1 Link to post Share on other sites More sharing options...
Pelu2010 Posted July 28 Author Share #43 Posted July 28 2 minutes ago, jaapv said: But It would not change the focus as such with an M lens? So what is the use? Nor do see I any evidence of such use in the images you posted. And what is a tilt-shift effect in a camera without tilt/shift lens or being a view camera? Or an SL with Perspective Control? I think you have lost me completely. If I punch into the focus I see the shallow focus differences on the 90mm. Thats why I need the point in the center ; but sometimes the points moves because the camera moves and so the point gets lost in the corners up left or up right or down right and down left. This happens because I am using different cameras with different lenses and systems. So when I need the focus in the center I need a quick way to set it back (which with the help of the forum was achieved, so thank you) When I detach the lens and create the "tilt shift" effect which you can see in the image then I need the Screen to evaluate the effect and if the focus is at the wrong point I need to shift the focus > thus its important to a control over the part of the image that zooms into the image to see the amount of the sharpness or unsharpness. only her right eye is sharp. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/423311-focus-point-toggle-or-center-or-move/?do=findComment&comment=5839990'>More sharing options...
Pelu2010 Posted July 28 Author Share #44 Posted July 28 5 minutes ago, charlesphoto99 said: I had to look it up too. Very influencer-y and a technique I already tired of looking at a few examples. To me though, it seems like 'freelensing' with a $15k lens is less than optimal value. May as well just get a TTArtisan 90 f1.25 for $600. That way if you drop it (which is all I can think of reading about this technique) then one won't be so sad. Thats why I am using a TTartisan lens for this exercise. But it's not about the exercise. Its just that with the exercise the challenges gets bigger. And that's why I asked if there is a shortcut or any way I can look the center focus zoom. Link to post Share on other sites More sharing options...
jaapv Posted July 28 Share #45 Posted July 28 It is many decades ago that I tried it and gave up as useless for me. A misspent youth I suppose. Link to post Share on other sites More sharing options...
lct Posted July 28 Share #46 Posted July 28 2 minutes ago, Pelu2010 said: Thats why I am using a TTartisan lens for this exercise. But it's not about the exercise. Its just that with the exercise the challenges gets bigger. And that's why I asked if there is a shortcut or any way I can look the center focus zoom. Glad you found a solution. Did you try Perspective control with your M11? just curious. Link to post Share on other sites More sharing options...
Pelu2010 Posted July 28 Author Share #47 Posted July 28 Advertisement (gone after registration) 22 minutes ago, lct said: Glad you found a solution. Did you try Perspective control with your M11? just curious. I only use it for architecture. sometimes street. PC does not help you with close focus or Scheinflug and it generates only a jpg. for me its much easier to use standard lenses as macro tilt lenses or shift lenses. 1 Link to post Share on other sites More sharing options...
SrMi Posted July 28 Share #48 Posted July 28 3 hours ago, Pelu2010 said: I only use it for architecture. sometimes street. PC does not help you with close focus or Scheinflug and it generates only a jpg. for me its much easier to use standard lenses as macro tilt lenses or shift lenses. Perspective Control also works with raw files. The angles are embedded as metadata, and when using Adobe software, the leveling and tilting correction can be applied at import. What do you mean that it "does not help you with close focus or Scheimpflug?" 1 Link to post Share on other sites More sharing options...
Pelu2010 Posted July 28 Author Share #49 Posted July 28 44 minutes ago, SrMi said: What do you mean that it "does not help you with close focus or Scheimpflug?" You can't make this with perspective control. Or do you? The lens is tilted and free shifted. I can't see that PC can do this. Or? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/423311-focus-point-toggle-or-center-or-move/?do=findComment&comment=5840144'>More sharing options...
SrMi Posted July 28 Share #50 Posted July 28 1 hour ago, Pelu2010 said: You can't make this with perspective control. Or do you? The lens is tilted and free shifted. I can't see that PC can do this. Or? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! No, you cannot do that with LPC. LPC can only simulate the shift (hence the name, perspective correction), not the tilt. Lensbaby is probably best for the effect above. Link to post Share on other sites More sharing options...
