John Hines Posted December 16, 2007 Share #1 Posted December 16, 2007 Advertisement (gone after registration) What should I use to keep dust off slides and negatives for scanning? Every time I scan I end up with dust somewhere. Thanks John Quote Link to post Share on other sites More sharing options...
Advertisement Posted December 16, 2007 Posted December 16, 2007 Hi John Hines, Take a look here Removing Dust for Scanning. I'm sure you'll find what you were looking for!
rafael_macia Posted December 16, 2007 Share #2 Posted December 16, 2007 John, Dust is always a problem. What I do is; Slides (when scanning,) just prior to putting the slide in its holder, I hold the slide by it's mount with two fingers in my left hand. Then finger snap the other side of the mount with my right hand. I have a small halogen table lamp on my desk, after snapping the mount to dislodge dust,I move the holder with the slide in it under the lamp, looking across the surface of the slide. Dust is easy to see when side lit. Depending on your scanner, you should have some kind of dust reduction program,("Digital Ice", is a popular one). It softens up the image a bit, (some scanners soften more than others because in the case of Digital Ice, there have been different generations of the program) Let us know what kind of a scanner you are using. Try working in a dedicated area. I have not scanned negatives, as of yet, and I have wondered what I would do. Should I scan the prints I have made in the darkroom, with all the hand dodging and burning in on a flatbed scanner, or scan the negatives on my film scanner and redo do in Photoshop, all the corrections? anyway, good luck! rafael Quote Link to post Share on other sites More sharing options...
Shootist Posted December 16, 2007 Share #3 Posted December 16, 2007 I find it almost impossible to get all the dust off a negative and even when I think I've done it and the scan is finished I see dust. Quote Link to post Share on other sites More sharing options...
Kent10D Posted December 16, 2007 Share #4 Posted December 16, 2007 It really is difficult to consistently make totally dust-free scans. I use a large blower to "air shower" my negatives before scanning, whether I can see any dust or not. If there's some persistent dust that I can see I'll use a soft brush as well. That gets most of it. Cheers, Quote Link to post Share on other sites More sharing options...
John Hines Posted December 16, 2007 Author Share #5 Posted December 16, 2007 I have been using can air but something always shows up. I just wanted to see if there was something more I could do. Rafael, I have a Microtek scanner that came with Silver Fast. I will try to use that program to help clean up the dust spots. Thank everyone and have a good day John Quote Link to post Share on other sites More sharing options...
tobey bilek Posted December 17, 2007 Share #6 Posted December 17, 2007 More than a brush and canned air, There used to be antistatic brushes. Some were single hand held. Some had double brushes and the film was passed through them. Prevention is the key really. Cover the scanner, Keep the holders in a dust free place, Cut up the neg as soon as possible and put then into a file folder which is kept clean, If you are taking the the negs out of a long 36 exp sleeve, clean the sleeve first. I have little trouble. I might add I never use scanner dust removal Quote Link to post Share on other sites More sharing options...
