Photoworks Posted March 26, 2024 Share #281 Â Posted March 26, 2024 Advertisement (gone after registration) Over the last few days, I tested IBIS on and off on Tripot. Used the 75 APO and the 90-280 at different focal lengths. All images did not show any difference between IBIS turned on or off. zooming in 200% and 400%. I think the camera does detect when it is mounted on a tripod, and pick the best option. I was not able to try Multishot. Quote Link to post Share on other sites More sharing options...
Advertisement Posted March 26, 2024 Posted March 26, 2024 Hi Photoworks, Take a look here The Leica SL3 - A Review by Jonathan Slack. I'm sure you'll find what you were looking for!
MediaFotografie Posted March 26, 2024 Share #282 Â Posted March 26, 2024 vor 39 Minuten schrieb Photoworks: Over the last few days, I tested IBIS on and off on Tripot. Used the 75 APO and the 90-280 at different focal lengths. All images did not show any difference between IBIS turned on or off. zooming in 200% and 400%. I think the camera does detect when it is mounted on a tripod, and pick the best option. I was not able to try Multishot. same here, I can't tell any differences IBIS on/off on tripod when using SL2 or SL3Â Quote Link to post Share on other sites More sharing options...
SrMi Posted March 26, 2024 Share #283  Posted March 26, 2024 2 hours ago, Photoworks said: Over the last few days, I tested IBIS on and off on Tripot. Used the 75 APO and the 90-280 at different focal lengths. All images did not show any difference between IBIS turned on or off. zooming in 200% and 400%. I think the camera does detect when it is mounted on a tripod, and pick the best option. I was not able to try Multishot. I do not think that your tests are conclusive. The negative effect of IBIS on tripod is noticeable a) when framing and the sensor starts recentering itself b) with very long exposure, when sensor starts readjusting itself. At ‘regular’ shutter speeds, you may not notice any deterministic IBIS issues, though they may be there. Quote Link to post Share on other sites More sharing options...
Photoworks Posted March 26, 2024 Share #284  Posted March 26, 2024 35 minutes ago, SrMi said: I do not think that your tests are conclusive. The negative effect of IBIS on tripod is noticeable a) when framing and the sensor starts recentering itself b) with very long exposure, when sensor starts readjusting itself. At ‘regular’ shutter speeds, you may not notice any deterministic IBIS issues, though they may be there. bring the evidence and i will consider it.  36 minutes ago, SrMi said: a) when framing and the sensor starts recentering itself well, you frame it on a tripod and what is the recentering? I did the test with with IS lens and non-IS lens same frame with IBIS on and off.  38 minutes ago, SrMi said: b) with very long exposure, when sensor starts readjusting itself. My test was 1/60, 1/20/ 1s and 8s this is what I typically have on a tripod. Quote Link to post Share on other sites More sharing options...
SrMi Posted March 26, 2024 Share #285  Posted March 26, 2024 (edited) 26 minutes ago, Photoworks said: well, you frame it on a tripod and what is the recentering? I did the test with with IS lens and non-IS lens same frame with IBIS on and off. I have not tested with SL3, but with other cameras, when using geared tripod heads, once you have completed your adjustments, the framing continues to move as the sensor recenter. The long exposure issue has been documented with other cameras. Hoare’s famous saying: testing can only prove the presence of bugs, not their absence. The fact that your testing did not discover any issues, does not mean that there are none, especially as IBIS behavior is non-deterministic. I believe it is still a good recommendation to turn IBIS off when on tripod. Edited March 26, 2024 by SrMi 1 Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted March 26, 2024 Share #286  Posted March 26, 2024 My experience with the SL601 and 90-280 was not that images were adversely affected with IBIS on and the camera on a tripod, but just that I could watch the viewed scene (at 280mm in my case) drift in live view, as if the sensor was not properly secured. It made it impossible to frame a specific area in a scene. Is this behaviour visible in the SL3? (I suppose I could test it on my SL2-S and 90-280, but I'm sitting comfortably with a drink at the moment.  3 Quote Link to post Share on other sites More sharing options...
Slender Posted March 26, 2024 Share #287 Â Posted March 26, 2024 Advertisement (gone after registration) No issues on SL2 with IBIS and tripod in my experience. third party lenses with OIS can do damage however. Quote Link to post Share on other sites More sharing options...
Tailwagger Posted March 28, 2024 Share #288 Â Posted March 28, 2024 On 3/26/2024 at 2:21 PM, LocalHero1953 said: My experience with the SL601 and 90-280 was not that images were adversely affected with IBIS on and the camera on a tripod, but just that I could watch the viewed scene (at 280mm in my case) drift in live view, as if the sensor was not properly secured. Didnt own the 601, but I thought it was IBIS-less. OIS issue perhaps? Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted March 28, 2024 Share #289 Â Posted March 28, 2024 18 minutes ago, Tailwagger said: Didnt own the 601, but I thought it was IBIS-less. OIS issue perhaps? Sorry, yes - OIS-less. IBIS didn't come into it. 1 Quote Link to post Share on other sites More sharing options...
scott kirkpatrick Posted March 28, 2024 Share #290  Posted March 28, 2024 (edited) On 3/26/2024 at 2:21 PM, LocalHero1953 said: My experience with the SL601 and 90-280 was not that images were adversely affected with IBIS on and the camera on a tripod, but just that I could watch the viewed scene (at 280mm in my case) drift in live view, as if the sensor was not properly secured. It made it impossible to frame a specific area in a scene. Is this behaviour visible in the SL3? (I suppose I could test it on my SL2-S and 90-280, but I'm sitting comfortably with a drink at the moment.  Don't have a drink in hand (although the sun crossed the yardarm some time ago), but I do have an SL3. I'll report back.  OK, here's a bookshelf at 7 feet, exposure a little over a second, cropped a bit, rendered in COne Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! click through to Flickr to see it in full res. Shot with the APO 35 SL, which doesn't have the conflict of an OIS with a mind of its own, but in-camera stabilization was on and the camera was on my desk, held by a Manfrotto table-top tripod. Edited March 28, 2024 by scott kirkpatrick 2 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! click through to Flickr to see it in full res. Shot with the APO 35 SL, which doesn't have the conflict of an OIS with a mind of its own, but in-camera stabilization was on and the camera was on my desk, held by a Manfrotto table-top tripod. ' data-webShareUrl='https://www.l-camera-forum.com/topic/390472-the-leica-sl3-a-review-by-jonathan-slack/?do=findComment&comment=5142009'>More sharing options...
jrp Posted March 29, 2024 Share #291 Â Posted March 29, 2024 The connection to the Lightroom Transform Guide setting seems to be transferred to the DNG whether or not the Guide is set to show on the camera or not. Â (This is a good thing, although sometime Lightroom's auto setting does an even better job of mangling your image; that's what 60Mpx is for...) Quote Link to post Share on other sites More sharing options...
jrp Posted March 29, 2024 Share #292 Â Posted March 29, 2024 The manual is very good at elaborating on obvious stuff but is rather more reticent on getting GPS to persist, and other tricky cases, where a lot depends on the precise (privacy) settings of your phone, eg. Quote Link to post Share on other sites More sharing options...
jrp Posted March 29, 2024 Share #293  Posted March 29, 2024 I like highlight exposure mode, but it seems that Lightroom still needs to be better tuned to the SL3: a temp of 18000/36 seems a little OTT. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  ' data-webShareUrl='https://www.l-camera-forum.com/topic/390472-the-leica-sl3-a-review-by-jonathan-slack/?do=findComment&comment=5143982'>More sharing options...
Ken Abrahams Posted March 31, 2024 Share #294  Posted March 31, 2024 On 3/29/2024 at 6:58 AM, scott kirkpatrick said: Don't have a drink in hand (although the sun crossed the yardarm some time ago), but I do have an SL3. I'll report back.  OK, here's a bookshelf at 7 feet, exposure a little over a second, cropped a bit, rendered in COne Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! click through to Flickr to see it in full res. Shot with the APO 35 SL, which doesn't have the conflict of an OIS with a mind of its own, but in-camera stabilization was on and the camera was on my desk, held by a Manfrotto table-top tripod. Outstanding collection of Photography books Scott!  3 1 Quote Link to post Share on other sites More sharing options...
scott kirkpatrick Posted March 31, 2024 Share #295  Posted March 31, 2024 (edited) 11 hours ago, Ken Abrahams said: Outstanding collection of Photography books Scott!  Thanks. That's about one quarter of the whole, which has trailed after me from NY to California to Jerusalem to Cambridge, MA. Still not sorted. Life's too short. Edited March 31, 2024 by scott kirkpatrick 2 Quote Link to post Share on other sites More sharing options...
Smogg Posted April 3, 2024 Share #296 Â Posted April 3, 2024 Does the SL3 have the same dual shutter sound as the M11? Quote Link to post Share on other sites More sharing options...
SrMi Posted April 3, 2024 Share #297 Â Posted April 3, 2024 35 minutes ago, Smogg said: Does the SL3 have the same dual shutter sound as the M11? It sounds differently. All mirrorless cameras have the same mechanical shutter operation like m11: close-open-expose-close-open. EFCS and electronic shutters work differently, but Leica has not implemented EFCS in any of its cameras. 1 Quote Link to post Share on other sites More sharing options...
Smogg Posted April 3, 2024 Share #298 Â Posted April 3, 2024 11 minutes ago, SrMi said: It sounds differently. All mirrorless cameras have the same mechanical shutter operation like m11: close-open-expose-close-open. EFCS and electronic shutters work differently, but Leica has not implemented EFCS in any of its cameras. Apparently Leica felt that perfect bokeh was more important and therefore did not implement EFCS Quote Link to post Share on other sites More sharing options...
SrMi Posted April 3, 2024 Share #299 Â Posted April 3, 2024 1 hour ago, Smogg said: Apparently Leica felt that perfect bokeh was more important and therefore did not implement EFCS Bokeh is only an issue with EFCS if shooting at very high shutter speeds and very wide open. Also, EFCS can be optional 3 Quote Link to post Share on other sites More sharing options...
Photoworks Posted April 3, 2024 Share #300 Â Posted April 3, 2024 IMG_6838.MOV Â Â 1 Quote Link to post Share on other sites More sharing options...
